Old Oct 03, 2009, 04:20 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Build Log
GAUI tiger Shark Delta w/MMX fan
Hi guys,
As promised here we go. Start by cutting a gap in the ring that fits over the fan. This is for the wires to feed through. Then thin CA the ring to the fan and attach the fan/motors wires to the esc. This is the 3s version so I'm using a CC-60 but the Pentium-60 will work just as well.
Next dremel out the spots I marked on both fuse sides so the fan fits snug but the fuse half join without forcing them.
Take a file and open a hole for the servo wires to go into the fuse.
hole digger is offline Find More Posts by hole digger
Old Oct 03, 2009, 05:11 PM
hole digger
Joined Aug 2002
HS-65MG servos glued in with foam safe. The fan is secured with 5 minute epoxy. I use 30 minute epoxy to glue the fuse together.
Old Oct 03, 2009, 05:23 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Subscribed....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Oct 03, 2009, 05:54 PM
2qwik4u is offline
Find More Posts by 2qwik4u
Kits are where the real fun is
Indian Head, MD
Joined Nov 2006
subscribed
2qwik4u is offline Find More Posts by 2qwik4u
Old Oct 03, 2009, 09:01 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I found it too.
Hey Digger. Is it my imagination or is the esc not going to be getting much cooling air in that location?
bill34207 is offline Find More Posts by bill34207
Old Oct 03, 2009, 09:20 PM
hole digger
Joined Aug 2002
Originally Posted by bill34207
I found it too.
Patience Oby Wan! We arn't there yet.
Old Oct 04, 2009, 05:56 AM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
hehehe...Ah So Grasshopper... ..Thanks for the Build Thread Pete...Ida shorely screwed this up....Billy...
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Oct 04, 2009, 02:08 PM
hole digger
Joined Aug 2002
OK look for a mold circle just in front of the servo. Push a small Phillips through the center to start the hole.
Take the CF tube and file one end so it is sharp. Push and twist the CF until you have a hole in the side of the fuse. Do the same thing to the other side then insert the rod but don't glue it.
Old Oct 04, 2009, 03:39 PM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
What is a MMX fan?
ozzi supercub is offline Find More Posts by ozzi supercub
Old Oct 04, 2009, 03:48 PM
hole digger
Joined Aug 2002
Originally Posted by ozzi supercub
What is a MMX fan?
www.rchobbyintl.com
Old Oct 04, 2009, 07:36 PM
WiggleWiggleWiggle
South Australia
Mines got cheapo Hobbycity fan and motor and its quick. This is going to be ballistic!
Cant wait.
Old Oct 05, 2009, 12:54 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
subscribed!!! w.
Waltjg is offline Find More Posts by Waltjg
Old Oct 06, 2009, 11:00 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
OK Digger it's time to get back to "work" in here. Mine just showed up at work today via Fedex so I'm ready to start building.
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Oct 07, 2009, 07:16 AM
Rogersville, Mo
Joined Jun 2008
Got mine painted red..(Fuse)...Servos installed...Motor area Reamed out...I'm gonna try some epp Foam as an additional liner inside..These are very fragile Fuselages..that should be reinforced one way or another....Does anyone Know if 3M Super 77 will attack this Foam...I know its OK on EPP..was thinkin of Makin a Liner inside with 3 mil EPP.. ...or 1/64 Plywood strips..Billy..
Old Oct 07, 2009, 09:31 AM
Rogersville, Mo
Joined Jun 2008
Never Mind..I just tried it..does'nt attack this Foam Gaui..gonna try to laminate some EPP to it..
Discussion Tiger-shark Delta simonwu Foamy EDFs 449 Aug 09, 2014 02:43 PM
Sold GAUI TIGER SHARK DELTA w/MMX fan hole digger Aircraft - Electric - Jets (FS/W) 112 Oct 09, 2009 07:56 PM
Discussion GAUI Tiger Shark Delta druegeme Foamy EDFs 3 Jun 21, 2009 09:36 PM
Sold GAUI Tiger Shark (PRICE REDUCED) hole digger Aircraft - Electric - Jets (FS/W) 1 Feb 16, 2008 12:13 PM
Sold Tiger Shark W/Retracts and Fan termite Aircraft - Electric - Jets (FS/W) 2 Oct 29, 2007 09:00 PM
