Old Oct 03, 2009, 03:33 PM
nick_cool is offline
Find More Posts by nick_cool
y chucu, chucu, chuuuu...
nick_cool's Avatar
Argentina, Buenos Aires
Joined Apr 2003
Cool
1940’s Thermic 70 flight report
First things first: why building a plane from a kit instead of buying an RTF one?
There are several reasons about why this time I wanted to build from a kit an old-timer free flight model.
The first is because several senior pilots have similar models in the field, and I have been always fascinated with their flying and their look. They have this kind of magic only achieved by hand made models.
The second reason is that I have been building planes since I was 11 years old (long time ago), and for me it is a relaxing and healthy activity that makes me feel a kid again.
Nostalgia apart, an electric power plant and RC equipment updated the Thermic 70, making it more practical and enjoyable. Sorry to the purist, but I believe that planes are to be flown.
The building log is here:
http://twoscenarios.typepad.com/adrin_muios_build_log/
nick_cool is offline Find More Posts by nick_cool
Old Oct 03, 2009, 04:18 PM
nick_cool's Avatar
Joined Apr 2003
The day was gusty, with average wing of 9km/hr, certainly not the best conditions to maiden this fragile model.
So I check everything and metered the power plant that sweetly amazed me with these results:
AXI 2212-20
Jeti Spin 22
Polyquest XQ 11.1v 1200mAhr 30C or 700mAhr
Prop : Robbe 8x5 folder
The results:
Voltage 11,4v
Current 9,4A
Power 107W
RPM 12.300 !!!
Ready to flight the model is bellow 500g, so the power is more than enough for a the sailplane, and it is at the most efficient point for the power plant.
Here is the blog about the power plant selection:
http://www.rcgroups.com/forums/showt...9#post12995341
Old Oct 03, 2009, 05:49 PM
markie is offline
Find More Posts by markie
Charleston, SC, USA
Joined Jan 2001
Very cool....I too like these old freeflights and recently built the Aerocente Thermic 50 for electric power....Flys great too.....Good luck
markie is offline Find More Posts by markie
Old Oct 03, 2009, 06:11 PM
Buran is offline
Find More Posts by Buran
Buran's Avatar
Huntington Beach
Joined Aug 2000
A huge Ziac fan here; your model looks great.
Buran is offline Find More Posts by Buran
Old Oct 03, 2009, 06:38 PM
starzak is offline
Find More Posts by starzak
Tye
starzak's Avatar
Chacotoma, NM
Joined Jan 2004
" The day was gusty, with average wing of 9km/hr, certainly not the best conditions to maiden this fragile model. "
Well ......... Don't keep it a secret. How did it fly ? ? ?
starzak is offline Find More Posts by starzak
Old Oct 03, 2009, 06:44 PM
nick_cool's Avatar
Joined Apr 2003
Wind went worst with the time and I wanted to maid this bird, so two alternatives were evaluated. To launch it as sailplane and let it sail from 2m to see the behavior, or to launch it with full motor and flight against the wind.
A friend told me to choose the second option because of the wing, and I did it.
My friend ran letting the Thermic abandon his hand, the +100W were sweet but powerful!
Sustaining a gently pull, the plane started to climb at 25° facing the wind, very stable. I pushed the stick to level the model and put the power at 60%. No trim in elevator was needed. Then I gave some rudder to see its effectiveness. The response was very good.
So I started to turn with some concern, because the wind speed increased and I did not know if I could let it out of the downstream. But the behavior of the Thermic couldn’t be better, it turned first to downstream, I let it take some speed, and then to upstream perfectly.
Despite the wind, I turned the motor off and I realized that again no elevator trim was needed to pass from power on to power off, cool!
My Futaba 7UAF Super plus the 2.4Ghz Assan module were great too providing a strong link.
But the wings were not passing a great moment, the flexed a lot, very elegantly, but a lot. So I decide to land.
I made a turn, trim 3 clicks down the elevator to keep the nose down, and got the runaway smoothly ending at 2m of me feet. Mission accomplished!
End of the day. The wind got even worst, so I have to put the model inside my car, I did the same with my Extra 330 that did not leave the land, and returned to home to drop these lines.
The wing incidence was 1°, the CG at 35% and motor at +5°. In a better day I will fine adjust the CG to soar
Old Oct 03, 2009, 06:45 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Beautiful model....Well done!! My you and her have many happy hours in the sky together!!
Leadchucker is offline Find More Posts by Leadchucker
Old Oct 11, 2009, 06:11 PM
nick_cool's Avatar
Joined Apr 2003
I did the second flight with the wing at 2° and the CG at 40%, and I needed 5 clicks down to trim the model.
Again, with variable wind the wings flexed a lot.
So, I moved back to 1° and 35%, and the flight was faster but smoother.
Old Oct 18, 2009, 11:02 AM
nick_cool's Avatar
Joined Apr 2003
The third day I confirm that the incidence al 1° makes the Thermic go faster and more steady, at least in windy conditions, it produces less stress to the structure, making the flight more enjoyable. The model can be flown with steady wind or no wind, but variable wind makes it suffer, maybe because the huge dihedral.
Hand launch is not an issue for this slow plane, the best way to climb is to let it advance “fast” instead of pulling the stick and making it loose speed at a high AoA.
I am happy to have the motor in the nose, and not in a cabana, it makes the transition from powered/no powered condition very natural. With the Polyquest 1200mAhr the autonomy is near 20 minutes with motor, so in calm days the 700mAhr pack will be perfect.
The Assan module is great, I am using the small Rx with short antenna, and it has no glitches even flying far and with other 2.4Ghz radios working at the same time. It feels as PCM and it let me use the friendly programming of the Futaba 7UAF.
Old Oct 18, 2009, 11:21 PM
mlbco is online now
Find More Posts by mlbco
Palo Alto, California, United States
Joined Jan 2003
Nick,
It looks like there is spar damage inside your wing. The dihedral angle at the wing root should not be that large in level flight. You might want to remove some of the wing covering and look for damage to the spars. If you don't fix it soon, the wing will break! It must be difficult to fly with so much extra dihedral. Your model is too nice to crash because of a damaged wing!
Steve
mlbco is online now Find More Posts by mlbco
Old Oct 19, 2009, 11:54 AM
starzak is offline
Tye
starzak's Avatar
Chacotoma, NM
Joined Jan 2004
Originally Posted by mlbco
Nick,
Steve
Definitely a lot less dihedral in posts #1 & #2. Steve is right Nick.
Be careful !
zak
Old Oct 20, 2009, 06:55 AM
nick_cool's Avatar
Joined Apr 2003
Thanks for the advice. I will take a look again.
I tested the wing without the covering putting a 400g in the center and it did not break.
The bending is distributed along the wing, and not concentrated in a single point. The reinforcement is stepped, meaning stronger in the center, and lighter in the tips.
So next time I will use harder balsa in the spars and maybe C.F. too.
Old Oct 28, 2009, 04:55 PM
nick_cool's Avatar
Joined Apr 2003
This plane turns the birds crazy because they see it as a fellow bird flying over their “homes”. I have to deal with tero’s angry at every landing.
I prefer the CG between 35% and 40%, it is windy here. With the cg at 40~43% I mixed throttle with elevator (down) 10%.
If you are used to flight with ailerons (I am used to use both coordinated, rudder ands ailerons), it is friendlier to mix ailerons with rudder.
To keep the plane in land, I tied the winds the way I show; it avoids stressing the stab because even light wind makes the Thermic roll.
With the structure reinforced (wings and fuse), this plane is ideal to learn to flight with a minor help. Fact that it is not surprising been a free flight model.
Intheswamp's GL Maiden Flight Report!!!!!! intheswamp Thermal 0 Mar 29, 2005 07:37 PM
Newbie's ZERO first flight report =) jayboy Parkflyers 15 Apr 27, 2002 04:11 PM
Top Flight's Nobler Flight Report fbw4 Sport Planes 7 Apr 22, 2002 01:18 AM
Astro Flight 020 with Li-ion's Flight Report! ls77 Sport Planes 2 Mar 18, 2002 03:11 PM
Dymond's Flipper-flight Report!!! tnsfrk Electric Sailplanes 16 Jan 02, 2002 03:53 PM
