Old May 14, 2010, 12:00 PM
MakMov is offline
Find More Posts by MakMov
Excellence is Expected
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Originally Posted by Add1ct3dd View Post
ok that's a fair few weaknesses! i've already got the feather shaft and the belt on the way, in terms of the shafts, will the Align ones be ok for all the tail, inter and main? i'll probably just try it with how i have it once it comes and then see what needs doing!
The main shaft is a bolt in.
The tail shaft will not work unless you shim it or replace the whole tail box with Align.
What I did on the inter shaft is take the clone and an Align set and put the Align pulley on the clone shaft and used the clone metal blocks. The clone pulley isn't very true and round.
Or you can just use the the entire Align set with the plastic blocks.
When I was trying to use the black belts and the metal boom block it ate bearings like crazy on the inter shaft, but with kevlar belt and a plastic boom block it's been a lot better. Probably because I don't need to run the belt as tight. With the stock clone set up I could never get the belts to stay tight and in one or two packs it was so loose it would slip. So I would tighten again and again and again and again.
It's been fine since the Kevlar belt replacement.
MakMov is offline Find More Posts by MakMov
Old May 14, 2010, 12:07 PM
Add1ct3dd is offline
Find More Posts by Add1ct3dd
Add1ct3dd's Avatar
United Kingdom, England, Worcester
Joined May 2010
ok thanks, and where can i get one of those from for cheap? preferably HK or UK
Add1ct3dd is offline Find More Posts by Add1ct3dd
Old May 14, 2010, 12:10 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
What? a Kevlar belt?
www.Infinity-hobby.com
Old May 14, 2010, 12:11 PM
Add1ct3dd's Avatar
Joined May 2010
yea, apologies for the very short post didn't even say what i was after haha
Old May 14, 2010, 12:12 PM
Add1ct3dd's Avatar
Joined May 2010
by the way, is it this one: http://www.infinity-hobby.com/main/p...oducts_id=4560 ? that's the only kevlar one i found, but there's a hell of a lot of belts on that site!
Old May 14, 2010, 12:15 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
it is also on the front page under top selling items. Look #1 seller. Go figure.
Old May 14, 2010, 12:17 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Yup. That is the one.
They have a lot of stuff for Gaui and Trex. It's a good place to deal with I get a lot of parts from them.
www.flying-hobby.com is another good one.
Old May 14, 2010, 02:34 PM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Fast-Lad do them as well
MikeHRC is online now Find More Posts by MikeHRC
Old May 14, 2010, 03:06 PM
chipbutty is offline
Find More Posts by chipbutty
Sunny Sheff, UK
Joined Jul 2008
Giant Cod sell some HK250GT spares. Not the full range like Hobby King. Still cheap like HK though.
http://www.giantcod.co.uk/hk250-spar...0_225_232.html
chipbutty is offline Find More Posts by chipbutty
Old May 14, 2010, 03:20 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Yeah, well you can't get a Kevlar belt from them, and some HK250 spares are a waste of time money and effort. You are better off with a Trex part.
Old May 14, 2010, 03:40 PM
Sunny Sheff, UK
Joined Jul 2008
I agree some HK parts are crap. I was really pointing out to a fellow UK resident that some HK parts are available cheaply here. We pay a hell of lot for stuff here so 53 pence for a pair of tail blades isn't to be sniffed at.
Also Sonix stuff for the 250 is good value and decent quality.
http://www.sportsmoto.co.uk/acatalog..._Upgrades.html
Old May 14, 2010, 03:43 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Not all of it is bad, just some of it is horrible and you are better off with an Align part.
Old May 14, 2010, 04:00 PM
Sunny Sheff, UK
Joined Jul 2008
Seeing as I'm catching up in this forum I though I'd post a few pics of my 250. I've tidied the heli up a little since taking these pics.
Carbon pushrod made with two Walkera 4/3B booms
Old May 14, 2010, 04:46 PM
clicky is offline
Find More Posts by clicky
UK
Joined May 2007
Fantastic pictures! I like the last one the most!
clicky is offline Find More Posts by clicky
Old May 14, 2010, 04:54 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Becareful. That little bugger is a wire eater if you don't secure those wires far enough away from the motor or main gear.
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
