Espritmodel.com Heli Air
Old Feb 09, 2013, 04:38 PM
Rabidmonkey234's Avatar
United States, MA, Sutton
Joined May 2012
What good receiver should I pick for beginner-moderate 3D flying? I have set up a post at http://www.rcgroups.com/forums/showthread.php?t=1827322 . I don't know if I should use an AR6115e or an AR600 with an additional remote carbon fuse receiver because of this heli's frame... Please help
Link to post: http://www.rcgroups.com/forums/showthread.php?t=1827322
Rabidmonkey234 is offline Find More Posts by Rabidmonkey234
Old Feb 09, 2013, 05:37 PM
Joined Feb 2013
Im using AR6115e ok on mine and a DX6i, you will be fine with that especially as a reasonably cheap investment for beginners. No need for anything else..
timmy1234 is offline Find More Posts by timmy1234
Old Feb 09, 2013, 08:23 PM
Joined May 2012
The carbon fiber doesn't mess with your RF signal?
Old Feb 09, 2013, 11:25 PM
Low rates are for wimps
bwoollia's Avatar
Canada, AB, Edmonton
Joined May 2008
The frame is mostly open, and if you get it far enough away for the carbon to shadow the receiver, you won't be able to see the model well enough to orientate it anyways!
bwoollia is offline Find More Posts by bwoollia
Latest blog entry: Dynam Me-262 Schwalbe in Flight
Old Feb 10, 2013, 07:23 AM
Joined Feb 2013
yeah, its only small after all you shouldnt be able to go far enough to lose the signal and still see it! With the AR6115e I put one of the aerials vertically one horizontally similar to what you would do with the satellite, but i dont think it will ever be an issue.
Old Feb 11, 2013, 04:40 PM
Joined Feb 2013
I suggest checking and gluing in the screw securing the swashplate ball with the extension that fits into the anti reverse bracket. Its secured by a screw that goes through the whole lot. Somehow i missed that screw and after about 5 batteries its worked out never to be seen again...luckily i was on the ground and spinning down, happened when i flicked throttle hold on
Old Feb 13, 2013, 02:04 PM
Joined Feb 2013
Tail drive gear and mount got binned even after gluing the actual gear in place to stop it moving up the top bearing in the mount disintegrated totally! Guess that align replacement is now enforced rather than optional! TBH this part always looked unlikely to last...
Old Feb 13, 2013, 02:47 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Am I screwed? I don't have a screw extractor small enough.
tonyastro is offline Find More Posts by tonyastro
Old Feb 13, 2013, 03:39 PM
Yep
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
No good
pitchp is offline Find More Posts by pitchp
Latest blog entry: tgz
Old Feb 13, 2013, 04:04 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Originally Posted by pitchp View Post
No good
Oh man
Old Feb 13, 2013, 05:15 PM
Joined Feb 2013
heat it up for ages with a soldering iron then try and twist it out with something. Perseverance or buy another...
Old Feb 14, 2013, 07:41 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Thanks I'll try that. I was able to drill out the same screw from my 450 hub but that was a lot bigger. I don't have a drill bit small enough for the 250. As for buying I can't find a FBL hub anywhere.
Old Feb 14, 2013, 07:45 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Is the tail drive gear shaft the same in the front of the boom and at the tail? Are they interchangeable?
Old Feb 15, 2013, 03:42 PM
Joined Feb 2013
managed to dump it again today. Snapped the feathering shaft in 2 as it hit the ground, resulting in the blades seperating and 1 blade obviously striking the boom - smashed off one of the boom supports and folded the boom where the little fin is attached! Also bent the flybar, gouged a flybar paddle and took a chunk out of the end of a blade...amazingly destructive those carbon blades if they are loose
Basically managed to get the flybar and boom straight again (although several spares). Reattach the boom support. The ball links for the blade grips also flew off but found 1 again somehow!
So end result luckily only 1 lost ball link, replacement feathering shaft and a chipped blade (prob just fill it with epoxy as its right at the tip do you think that is safe?).
Old Feb 18, 2013, 08:29 PM
Joined Jun 2012
Help please
Im new to this forum and helicopter flying. I have a blade nano and think that I am ready to go a little bigger. I'm not looking for a 3d flyer, just one that I can get into cheap and continue learning. That being said,I just purchased the hk250gt fom hobby king. Quick question, where is the best place to order replacement parts and also upgrades for the hk250gt? Any help would be appreciated.
mgaston is offline Find More Posts by mgaston
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10570 Apr 12, 2013 12:23 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 37 Oct 24, 2009 07:43 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
