Old Mar 28, 2010, 06:03 PM
frebou is offline
Find More Posts by frebou
frebou's Avatar
St-Hilaire,Québec,Canada
Joined Sep 2001
Originally Posted by Brettw View Post
So my question to everyone is what is the most used and functional tail setup on this beast? i.e HKGT250 tail, Align 250 tai or the micro heli tail.
Cheers
Bret
For my part, the overpriced (IMHO) Micro heli tail ... works wonder, but cost more than the price of the heli
frebou is offline Find More Posts by frebou
Old Mar 28, 2010, 06:31 PM
microkites is offline
Find More Posts by microkites
I HOOVER because I SUCK!
Portland,Oregon U.S.A.
Joined Sep 2007
I hate micro heli tails- alu is like soft clay, and most of their parts are not compatible with other tails- and over priced
mk
microkites is offline Find More Posts by microkites
Old Mar 28, 2010, 07:31 PM
Brettw is offline
Find More Posts by Brettw
Joined Sep 2007
mk
So what would/are you using?
Cheers
Brett
Brettw is offline Find More Posts by Brettw
Old Mar 28, 2010, 07:51 PM
Joined Sep 2007
Cheers
Brett
like I said- I havent maidened it yet
I have used a few of their tails on my gaui's and they were horrible- the alu wears in a flight or two, the screws strip easy and they seem naturally sloppy to me
my nicest tail setup was the gaui v2 tail- very nice and almost slop free
my 250gt tail is almost as nice- but again it depends on wear- and the pitch slider ball is a touch loose
I cant say squat till I fly it a while, but it is about the 6-7th cp I have set up and is looking good so far
mk
Old Mar 28, 2010, 07:58 PM
Joined Sep 2007
question-
blade grip bolts-
on the hk250gt kit the main blade bolts that secure blades to grips just screw into bottom of blade grips
I am used to using bolts that go thru and have nylock nuts on the end
since I dont have any that fit at this time, do any of you run the main bolts as is- as the kit comes??
and do you have them backing out in flight??
loc-titing blade grip bolts seems unusual to me- curious as to what others do
mk
Old Mar 28, 2010, 08:07 PM
ChrisWNY is offline
Find More Posts by ChrisWNY
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
Microkites - they should be loctited. When you get the bolt through the blade and threaded into the other side of the grip, apply a small drop of loctite, then tighten the screw using the proper amount of torque until the blade tension is correct, wipe up any excess loctite. If you're using plastic blades, know that loctite can eat through and weaken plastic, so be very careful with loctite regardless.
The other option is to buy longer bolts of the same diameter, and use nylon lock nuts to secure the bolt within the blade grips, just like a 450 or any other larger heli model.
ChrisWNY is offline Find More Posts by ChrisWNY
Old Mar 28, 2010, 08:09 PM
Joined Sep 2007
Originally Posted by ChrisWNY View Post
Microkites - they should be loctited. When you get the bolt through the blade and threaded into the other side of the grip, apply a small drop of loctite, then tighten the screw using the proper amount of torque until the blade tension is correct. If you're using plastic blades, know that loctite can eat through and weaken plastic, so be very careful with loctite regardless.
thanks- I think I can get the nut and bolt at local hardware store- just wanted to try it mostly stock first
mk
Old Mar 28, 2010, 09:00 PM
J Fonseca is offline
Find More Posts by J Fonseca
Barcelos - Portugal
Joined Apr 2003
Pinion
Hi,
I already built the hk 250 gt heli, but I have a problem. I want to use a 2900kv motor with a 2.3mm shaft. If I'm not mistaken I need a 17T pinion. Where can I get one? Any 17T 2.3mm pinion will do, or the teeth pitch maybe different from pinion ro pinon?
JFonseca
J Fonseca is offline Find More Posts by J Fonseca
Old Mar 28, 2010, 09:56 PM
Joined Sep 2007
Originally Posted by J Fonseca View Post
Hi,
JFonseca
http://www.venom-group.com/storeitem...txtkey=pinions
here is the ones I bought-
9t to 20t .4 mod and 2.3mm
cheap too
mk
Old Mar 29, 2010, 02:20 AM
clicky is offline
Find More Posts by clicky
UK
Joined May 2007
Cheers
Brett
Complete HK tail with align arm and slider, + double (HK) bearings on align or HK blade holders.
The latest (before stupid disaster) was HK tail, with micro heli arm and slider, align blade holders with double (HK) bearings. Very smooth and virtually without slop!
clicky is offline Find More Posts by clicky
Old Mar 29, 2010, 11:34 AM
Barcelos - Portugal
Joined Apr 2003
cheap too
mk
Thank you!
Old Mar 29, 2010, 02:11 PM
chipbutty is offline
Find More Posts by chipbutty
Sunny Sheff, UK
Joined Jul 2008
I've spent the past two hours trying to fit my Turnigy 4200kv and come to the conclusion that it does not fit. The larger screws (3mm?) are too big for the mount and even then the motor is too wide for the mounting points. Same story if I try and mount using the smaller holes. The smaller screws do fit the motor mount but again the motor is too wide. I don't hear of anyone else having issues. The 4200 has the same dimensions as the 3800
chipbutty is offline Find More Posts by chipbutty
Old Mar 29, 2010, 02:25 PM
ChrisWNY is offline
Gone Flying.
ChrisWNY's Avatar
Western NY
Joined Nov 2006
chip - this is not uncommon, you'll need to dremel out and widen the motor mount slots in order to make your motor fit. As long as your motor fits within the confines of the small 250GT frame it should be fine.
Old Mar 29, 2010, 02:32 PM
Joined Sep 2007
I am actually thinking of putting mine up for sale before I maiden it
she is all setup and waiting for her maiden
probably sell it bnf
still not working, so might try and recoup as much of my investment as possible
and they do take some money to set up
I worked out how much it cost me to build- not including all the shipping from hk- was aprox $300
and that is using inexpensive equipment!
so if anyone wants a bnf,everything new, with lots of spares- lmk-sure would get it alot quicker than from hk!
this heli built really nice!
mk
Old Mar 29, 2010, 02:54 PM
Sunny Sheff, UK
Joined Jul 2008
Thanks Chris. My rotary tool is on the blink so I'll have to think of someway of widening those slots.
Just checked the so called 2.3mm pinion and it measures 2.1mm. My Turnigy shaft measures 2.35mm. I can see this is going to be a frustrating build!
Calm....
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
