Old Dec 30, 2012, 09:45 AM
BladeScraper is offline
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
Originally Posted by pitchp View Post
get a quark
I am 13... I can't spend $130 on a gyro...
BladeScraper is offline Find More Posts by BladeScraper
Old Dec 30, 2012, 05:10 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Here are two cheap options if you're just learning and on a tight budget. But you still have to order it online. I have used the first one, but not the second. Don't get the gy48 for the 250, it's also a little too big for it. It works better on a 450 not so great on the 250. You may want to try the second one for 3d since some guys weren't too crazy with the first option here. I'm not doing 3D though. In any case, you said budget so these are budget.
http://www.hobbyking.com/hobbyking/s...EMS_Gyro_.html
http://www.myrcmart.com/rcx-420-mems...en-p-4620.html
efx is offline Find More Posts by efx
Old Dec 30, 2012, 11:07 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Okay, I'm doing it...one 250 kit is for sale now.
http://www.rcgroups.com/forums/showthread.php?t=1798641
Old Dec 31, 2012, 01:34 AM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
http://www.ebay.com.au/itm/Spartan-Q...item257924db3b
pitchp is offline Find More Posts by pitchp
Old Dec 31, 2012, 08:51 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
efx , the second one you linked to looks like the e-flight mems gyro they sell for 65.00. From what I have read , it's a real good gyro.
jombo is offline Find More Posts by jombo
Old Dec 31, 2012, 10:31 AM
mugen 1 is offline
Find More Posts by mugen 1
Joined May 2011
efx in your for sale post you said you glued the 250's tail gear? What do you mean by that? I have a tail issue with one of my 250s and that might the fix.
mugen 1 is offline Find More Posts by mugen 1
Old Dec 31, 2012, 02:19 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
The belt gear that meshes with the main gear tends to eventually come lose and shifts up making you lose tail control. So I use 5 minute epoxy to glue them down. Don't use CA, that doesn't work and will just come off again. Ask me how I know. Now they work fine. It happened on both helis for me so I just glued all of them.
Old Dec 31, 2012, 02:33 PM
mugen 1 is offline
Joined May 2011
Thanks efx. Is there anyway of checking? I think my belt gear could be slipping, but when I try to spin the main gear when holding the tail rotor it will not move. I'm losing
my tail and I can't figure out why.
Old Dec 31, 2012, 02:34 PM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
Perhaps this is the problem with my heli, where I lose tail authority a few seconds after takeoff. I don't have it in front of me now though and am just trying to picture how one can glue a gear to prevent it from sliding up. Is there an easy way to check on the workbench if this is my problem?
eltreato is offline Find More Posts by eltreato
Old Dec 31, 2012, 02:45 PM
mugen 1 is offline
Joined May 2011
Is the spin counter clock wise?
Old Dec 31, 2012, 02:57 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
You test for a slipping tail gear by holding the head and rotating the tail rotor by hand.
You should (with some force) be able to get it to jump a tooth on the belt. But it should not move smoothly without the belt jumping.
If it is bad replacing with an Align part is a good idea.
Other possibility is a bad belt.
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 31, 2012, 03:05 PM
mugen 1 is offline
Joined May 2011
Did the test and everything checks out, so that rules that out. I'll keep playing with it, hopefully I'll figure it out.
Old Dec 31, 2012, 03:50 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
If you're still losing your tail after checking the gear, the problem is your tail boom holder. I had one that was tighten all the way, but was still lose and that's the reason the belt felt like it was either stretched or bad. Check this after flight test to see if the belt losens up after that. If it does then you need to sand one side of the tailboom holder to make sure it really holds the boom tight. Both my helis use all the stock parts. They work fine after you get all the kinks taken cared off, if you have problems with your kit. Don't forget to put a screw on the tail between the fin as well to keep that from turning on you and snug in those fin screws. This takes care of the tail, but if you bump it hard on the ground it will losen it. So just keep an eye on it.
Old Dec 31, 2012, 04:23 PM
eltreato is offline
eltreato's Avatar
Joined Oct 2011
Roger that, I've been hesitant up until now to try this thinking it could lead to belt damage. For the record I'm running a kevlar aftermarket belt as I've heard bad things about the stock ones. I will give this a try, without applying too much force.
I believe so, though to be honest it happened in the blink of an eye, I was just trying to bring it down as right side up as possible.
Will do, thanks!
Old Dec 31, 2012, 04:32 PM
pmackenzie's Avatar
Joined Dec 2002
Yeah, don't over do it to the point of breaking something.
It is pretty obvious when they are slipping.
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 02:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 11:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 06:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 02:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 09:54 PM
