Old Oct 14, 2012, 09:52 AM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Yeah, I understand. I have a 450 size fp helicopter and just wanted a small one to have a bit of fun with. Is flybarless more stable? What are the flying characteristics like compared to the 450?
Cheers
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Oct 14, 2012, 11:59 AM
mugen 1 is offline
Find More Posts by mugen 1
Joined May 2011
You mean, you have a 450 CP right? I can't help you with FBL characteristics because the 450 FBL I have is still in the box (unassembled), but I would imagine
that a 250 FBL helicopter would be more stable than a 250 with a FB. I know that is not much help.
mugen 1 is offline Find More Posts by mugen 1
Old Oct 14, 2012, 12:18 PM
mugen 1 is offline
Joined May 2011
One more thing, because the 250 is so small, there is only so much space for wiring. I could barely fit the wires in with a regular gyro, the FBL system is bigger and has more wires, making it harder to install, although I heard it could be done.
Old Oct 14, 2012, 12:58 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Flybarless is very sensitive as is the 250 size helicopter. My guess is this would be even more sensitive, but you can always turn everything down on the transmitter whether it is flybar or flybarless. The learning curve will be more with flybarless if you never have set one up. I think it is a good thing to learn the regular flybar heli and how things work on it first, this gives you a good idea on how to set up the flybarless because it's base on the same principle but works a bit different, specially the settings. Whether you get a 250 or 450 just use the kit as is, I know you can buy either type now, but I would still rather get a flybar heli for a beginner, then move on to flybarless later on. You can however buy the flybarless gyro and use it just as a gyro for a flybared heli. This will get you the new gyro you still need, and allow you to move to flybarless head later if you really want to. Just another option. I just noticed you do have a 450, so getting a smaller heli should be fine, just remember they are a bit harder to fly but not impossible. The HK kit comes in a flybar type, so the flybarless head is something you still have to buy separate at the moment. Just get something like that and use it the way it is. Let me see if I can find the video where I used my flybarless unit as a gyro on the 250. I had and still don't have a flybarless head on my 250s.
I was still having problems with my tail but at least you can see that it can be used as a regular gyro. I didn't even plug in the programmer just the receiver and the servo. I have my receivers under the mount and the gyro was on top with velcro and fit just right with the wires facing the rear of the heli. Although it is bigger than a regular gyro unfortunately, but works just the same and you have extra wires you have to tie if you're not using it with a flybarless head.
250GT Copter X Flybarles Gyro only Flight 1 today (3 min 1 sec)
efx is offline Find More Posts by efx
Old Oct 14, 2012, 01:56 PM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
https://www.youtube.com/watch?v=FstsXLvrUnI
Thanks for the help guys. Very helpful indeed!
I'm still debating over which size to get but the flybarless case is now closed!
Jim
Old Oct 14, 2012, 07:34 PM
gandal is offline
Find More Posts by gandal
FPV NooB (crashing since 1985)
gandal's Avatar
Canada, BC, Kamloops
Joined May 2011
Get a 450 more room to add FBL and screws/parts are a little bigger and easier to repair
easier to see and fly
parts are comparable in price to a 250
My 250 is cool but i fly my 450 way more..its better in wind and i can repair it 3x faster then my 250
gandal is offline Find More Posts by gandal
Old Oct 14, 2012, 08:58 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
that is true, but the 250 is just a totally different bird compared to the 450. both birds are awesome to fly
as for fbl yes the 250 is just too small for all those components. May be i'm getting older, but i think i prefer the simplicity of FB.
pitchp is offline Find More Posts by pitchp
Old Oct 14, 2012, 11:22 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Just got back from hovering the flybarless and Pitchp, you're right, I still like the flybar a little bit more still. It's working fine, but i think I need night blades as I'm always out there in the dark. Too bad they don't make any cheap night blades. The flybarless feels much more sensitive than a flybar heli. Anyway I'm still having a problem with the tail as it's not moving smoothly on this heli. Not to mention the included arms on that 306 servo kind of suck. The short star shaped feels a bit short and I can't seem to get even angle on both sides of the slider. The big ones are too long. Does anyone know what other arms fit those servos? I think I really need to find me arms that are in between. I'll try the bigger ones and see if I can make them work better.
I think I just found why the tail feels slow. I just checked the other heli and the tail linkage is plastic, this flybarless is aluminum and it looks like the screw was a bit tight. Seems to move much better now. I just have to add a bit of loc tite and not tighten it all the way down. Big difference as there is nothing else binding. It's always the little things. Loc tight on the little bearing doesn't help either.
Old Oct 15, 2012, 02:23 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
efx,
If the FBL has made your 250 too twitchy for you, you can easily tune it down to make it less sensitive by reducing the agility settings.
MikeHRC is offline Find More Posts by MikeHRC
Old Oct 15, 2012, 02:32 AM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Thanks Mike, but I got the flybarless unit on the 450. I have managed to test hover it now, but I'm still getting a feel for it. My tail slider was a bit tight so I had to take that apart, scrape out the extra loc tite from the bearing, add oil on both sides of the bearing. I also added loc tite from the top of the screw hole instead of the bearing side and snug the screw to make sure it wasn't too tight as before. It seems to work much better now, but now I need to find some other servo arms for these two servos. The arms are too big and the small one seems one bit too small. I can use them as they are, but I'm really not liking the current arms. I can set the rate mode perfectly or the HH with these arms but not both. I remember I was able to do both before with my orange servos. Not that you need both, but I like to have everything working the way it should be, just in case.
Originally Posted by MikeHRC View Post
efx,
Old Oct 15, 2012, 08:34 AM
geekystar is offline
Find More Posts by geekystar
Joined Jul 2012
Last night I replaced the slightly bent HK feathering shaft with stock align shaft. Also put on stock align tail blade holder and took a flight.
The tail definitely improved from the HK tail. I can go to higher tail gain without wag. And it feels more responsive too.
Not sure what happened next. Maybe a breeze or failed cyclic, the heli flew side ways and I couldn't correct it. It smashed into a hand rail and exploded.
So the 2 blades separated. One blade holder screw snapped in the shaft. However the shaft still appears to be straight! It's much much harder than the HK shaft. But the screws aren't.
Also the right cyclic servo HXT900 failed. I think that maybe the cause for the crash as it was flying towards left.
Looking back I may actually prefer the HK feathering shaft as it will bend and break first, without damaging other parts.
I'm still using the stock plastic blades. They scuffs but don't break. Better than CF which breaks into small bits upon the tiniest crash. Bad for beginners.
geekystar is offline Find More Posts by geekystar
Old Oct 15, 2012, 09:28 PM
Sabin is online now
Find More Posts by Sabin
Every pilot has his crash
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
I've got most of the parts in queue to finish the build.
the tx will either be a dx6i or dx7i
esc: http://www.hobbyking.com/hobbyking/s...ng_2s_4s_.html
batteries: http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
tail servo: http://www.hobbyking.com/hobbyking/s...g_07s_9kg.html
I'm not sure what motor I should pick up because it's pretty hard to tell from the part numbers on that site. anyone with any advice?
Sabin is online now Find More Posts by Sabin
Old Oct 15, 2012, 10:20 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
we were just discussing that on the last page .
the 2627 size motors work with the 250 ... i think thats the size
http://www.rcgroups.com/forums/showt...20372&page=522
jombo is offline Find More Posts by jombo
Old Oct 15, 2012, 10:40 PM
Sabin is online now
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
yeah I had a look at that motor and it almost made it into the basket... but it's only rated for 2s. I'd like one that's rated for 3s
Old Oct 15, 2012, 11:57 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Sabin if you're looking for a gyro this one is a good one to get apparently
http://www.ebay.com.au/itm/US-Stock-...item2a23521c46
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
