Old Oct 10, 2012, 06:07 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by efx View Post
Mike, all the parts on the heli were new, so I wasn't getting anything, since I had never flown or tried to fly this thing. One of the links came off too so I'm not sure if that also had something to do with it this second time. I just finished putting in the new main shaft, gear, and servos. I readjusted my links as they are not very strong from what it looks like, so I put screw the end links all the way down and moved the base up near to top to get the same movement up and down. This part is something I think making it tough too since I have to look at the blades to make sure they are about the same. I'll have to adjust the servo links but I rather do these than the two long ones now after that. Oh I also moved the gyro on the top of the tail boom and will change that setting too. As for the correction, well it looks like it corrects fine, but it's after I spooled up that it decides to go to one side without any input from me instead of straight up.
How are you mounting the FBL unit - which tape? The wrong tape can cause issues.
Also I saw a picture of your 450 where you were using a cable tie to hold it - this will transfer vibes into the unit (unless you have the cable tie in fuel tubing or similar), also your FBL unit was not perpendicular to the main shaft
MikeHRC is online now Find More Posts by MikeHRC
Old Oct 10, 2012, 06:43 AM
r3dskull is offline
Find More Posts by r3dskull
almost hovering
r3dskull's Avatar
United States, FL, Homestead
Joined Feb 2012
efx, I prefer to swap the RX and gyro locations (gyro inside frame, rx out) and like Mike says don't use tie with this gyro, I just use the double side foam tape.
Also have you check the gyro corrections on the bench, just move it hard to each side and check. I don't know if that gyro is like the zyx with an option for pirouette optimization also.
r3dskull is offline Find More Posts by r3dskull
Old Oct 10, 2012, 11:21 AM
geekystar is offline
Find More Posts by geekystar
Joined Jul 2012
Hi does any one know the dimensions of the screws used on HK250GT? I'm thinking of replacing them with good quality steel screws, but don't want to order the wrong type.
Also any one know the source for good screws in the UK?
geekystar is offline Find More Posts by geekystar
Old Oct 10, 2012, 12:01 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
The HK 250 (as does the Trex 250) uses a bizarre size called 0-80, I haven't found anyone in teh UK that does them, but Microfasteners in teh US does and will ship for sensible prices http://www.microfasteners.com/catalo...cts/SSCSCA.cfm
these are MUCH better than the Align or HK screws as they have a proper deep socket dead
Old Oct 10, 2012, 02:09 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
I like to use velcro and velcro straps usually and here a cable tie because I like to be able to move things around. Double sided tape is nice, but a pain if I have to take the heli apart. I have been doing this with all my gyros and haven't had a problem. I think the mounting location may also help. I had this inside the 250 and that was working fine just as a gyro but perpendicular to the main shaft, so we'll see. I would like to keep it inside, but I prefer the receiver inside. I rather loose the gyro and at least have some control just in case. Now I'm finding that this thing has the orientation in a way that makes mounting it a bit harder. It shows the connections towards the front which I don't like. So on top the connections are away from where the blades would hit if that happens. I'll test it like this and see how it goes. Will let you know.
skull, yes it's similar to that one, and I did check before, but will triple check again.
Geekystar, I got a list of suppliers for small screws somewhere on my blog here, but I think you'll have to look through it. I can't remember if it's in the shopping sites or the heli where I put it. Most are here in the US, but I think you will have better luck finding metric where you are probably at any local hardware store there.
efx is offline Find More Posts by efx
Old Oct 10, 2012, 02:31 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Can you tell me if your swash moves back very slow or fast on yours when you tilt it yourself on the bench? Mine seems to go in slow motion unless I move the stick.
Old Oct 10, 2012, 03:05 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
i use the blackwidow FBL , it moves slowly if i tilt it myself . i also use mg90 servos and its on my 450 pro
jombo is offline Find More Posts by jombo
Old Oct 10, 2012, 03:13 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Sounds like mine has been working fine. I'm wondering if putting it on the side may have affected it, but I use the programmer to choose one of the three placements. At this point I'm not sure what's going on but I'm making sure things are tighter for next time on the head. I don't need anything coming loose. I'll just adjust the servos to make sure things are even. Still working on it.
Old Oct 10, 2012, 04:00 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Sorry, but that just won't work with these - they are much more susceptible to vibes than normal gyros - you will need to firmly mount it using double sided tape to get it to work properly
Old Oct 10, 2012, 04:45 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Thanks Mike, I will let you know how it goes, now I want to try it because you said it won't work. See what you did...lol. Uploading video of the head setup now...I'll let you guys know when it's done. Now I have to go check that tail because that servo just hasn't felt right since I got it. I hope I don't have to return it. Ugh...
Old Oct 10, 2012, 04:48 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
I think I agree with you Pitchp, these things requires too much mocking around and helis already have enough of this as they are. If this flybarless doesn't work out, I don't think I'll bother buying anything more related to flybarless.
Phew! I put the servo tester on the servo and the servo looks good. I need to check the connections I guess and settings on the gyro.
Originally Posted by pitchp View Post
yeah I'm also going back to FB on the 250 actually i'm thinking of just dissin this FBL all together. Just FB all the way
Old Oct 10, 2012, 05:16 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
I just noticed one big difference on the manual from the programmer. Maybe someone can help. The programmer only has one setting which shows 90 as the default. The manual has a collective range pitch range and compensation of pitch to tail which there's only one compensation setting on the programmer and numbers are different from each other. In any case thanks guys, I've checked everything again and things seems to be up again, but we'll see. I apologize for those looking for 250 stuff, but the same thing applies on a 250 if you're using this same unit. Might as well see if I can make it work.
Also someone mentioned the computer program. I have that, but don't have the usb programmer, I use the big programmer on this unit. So I don't have to use a computer.
Old Oct 10, 2012, 05:37 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Here's the video, let me know if I got this right, or not.
Setting up the HK cheap flybarless arms and copter x flybarless gyro (5 min 28 sec)
Old Oct 10, 2012, 06:04 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
http://www.youtube.com/watch?v=jvXIs1Kjzmw
Ok , thats too slow . mine is slow but not like that .
on takeoff mine wants to tip over too but i just adjust it like a flybar heli. then after it takes off it flys fine . try upping the gain , and with mine it says it needs 8 degrees of cyclic . i just tame it down with dual rates and expo . i will post a vid of mine later .
Old Oct 10, 2012, 06:22 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
I set mine to beginner and it's 40 on pitch and roll and 100 on yaw. I have no idea why this thing is so slow either. I was just staring at the heli and you got me thinking about the servos. I don't know if these systems don't like analog servos. I'm only using them since I'm testing, but now I'm wondering. I'll test the other settings on the programmer first to see if that movement changes on them.
I tried all the settings from the programmer and they still move the same when I move the heli. Weird because when I move the sticks they move fine though.
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
