Jombo, I think I found a servo for your 250, or was it pitchp...LOL
http://www.hobbyking.com/hobbyking/s...sec_22_5g.html |
Latest blog entry: NH airshow
Looks good, too bad they have those large mounting holes. I've learned to hate those things because you need to find washers and make sure it doesn't fall out when you crash. It was more of a pain to get them installed that's all. But HK has some of the orange/white now that come with metal gears too and I think they're like 3 bucks or less.
Okay I was off by .98 cents. It looks like yours is a bit faster though. http://www.hobbyking.com/hobbyking/s...5kg_0_08s.html Quote:
for that price I might aswell buy a DS95i
Latest blog entry: tgz
It's my very first flybarless system, so I'm still trying to see if I can make it work but I have no previous experience with any so it's harder to know if it's just me or I need to check something else. I just realized while typing that earlier, these systems are supposed to help you by uprighting itself, but mine likes to tip over really fast and smack itself on the ground instead even though it looks like it's working correctly. Everything is new on the heli. I'm currently moving it from the side to the top of the tail boom. Trying to match the manual. The manual also has it on the left side if you are behind the tail, but I had it on the right side, which shouldn't really be a problem I don't think, but who knows. I will also be bringing the links in more as that seems to also be a problem. I was going by what gave me equal movement, but still need to bring them in and start over setting that up later. Maybe it was just that that cause the tip over this time, hard to say. I know the gyro works as I used it on the 250 by itself and it was working just fine as a regular gyro.
This is what I have... http://www.rcgroups.com/forums/showthread.php?t=1680830 Quote:
Joined Jul 2012
I bought the HK FBL head together with the kit, and put it on straight away. I am so glad I went for fbl as it's so much easier to set up. Just level the swash with a swash levelling tool, and pop on the blade holder and adjust pitch.
Most settings are done on a nice computer interface, not on the TX. I mounted the zyx with 2 double sided tape. It lifts off nicely and hoovers ok. The main problem is still the tail. Think the 9g hk digital servo is just not strong enough. Could someone recommend a strong (prone to crash) and powerful servo that won't break the bank please? Think around $20 is my limit. |
This servo feels nice and fast on my flybar heli. Not so much on my flybarless though, but I just noticed I bent the screw on the tail holding the slider so I'm getting some binding. I thought I killed it earlier but nope, it's fine. It's about 22 bucks if you wait, but check for a buddy code if there is one. I have also used the cheap orange digital servos without a problem, but I am only hovering around.
http://www.hobbyking.com/hobbyking/s...05sec_21g.html Mike, all the parts on the heli were new, so I wasn't getting anything, since I had never flown or tried to fly this thing. One of the links came off too so I'm not sure if that also had something to do with it this second time. I just finished putting in the new main shaft, gear, and servos. I readjusted my links as they are not very strong from what it looks like, so I put screw the end links all the way down and moved the base up near to top to get the same movement up and down. This part is something I think making it tough too since I have to look at the blades to make sure they are about the same. I'll have to adjust the servo links but I rather do these than the two long ones now after that. Oh I also moved the gyro on the top of the tail boom and will change that setting too. As for the correction, well it looks like it corrects fine, but it's after I spooled up that it decides to go to one side without any input from me instead of straight up. |
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
So far I like my 250 a lot better than the Flybar'ed ones. I might be assembling a 250 FB this coming Christmas to see if I still like the FB feel. Generally, FBL has a lot less to set up, just the parameters needs to be tweaked to perfect before even try to hover, else it'll be fubar.
So I think it depends on if you like mechanical setup (FB) or electronic setup (FBL). |
| Thread Tools | |
| Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. | darklyte24 | Micro Helis | 10570 | Apr 12, 2013 12:23 PM |
| Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review | The Don | Foamy EDFs | 37 | Oct 24, 2009 07:43 PM |
| GWS Spitfire Build thread (with glassing tutorial) | David Winter | GWS (Grand Wing Servo) | 156 | Sep 14, 2009 05:42 AM |
| Discussion Build log or review for BulleT? | raycsr | Electric Sailplanes | 3 | Jan 30, 2009 01:03 PM |
| looking for build thread with upclose photos | HIGHFLYER99 | Foamies (Kits) | 13 | May 21, 2005 08:54 PM |
