I just added some buddy codes for some 250 parts. I can never find any when I need them so I thought I let you guys know so you can at least save a few cents since I think they only let us use 3 codes now. Dumb, but what can we do.
http://www.buddyprice.fr.nf/index.php |
Joined Jun 2008
NEW, MUCH "LOWER PRICE" FOR GIANT 250GT PARTS PACKAGE.......!!!! http://www.rcgroups.com/forums/showthread.php?t=1730393
Latest blog entry: tgz
Sweden, Helsingborg
Joined Jun 2012
![]() Btw, if one were to build a FBL 250. Would it be possible to reuse everything later for a FBL 450? Or you would need to get new servos/motors/ecs? |
I'm not sure there is one single place to read everything, but over time you can find the information on here and all over the net I'm sure. As for the 250 since you're just starting, the hk 250 is not bad for the price. I would recommend no more than two kits because later you just want to get the parts as I think is what you'll need anyway. I think one kit will be fine and then just get parts you need so you don't spend too much and the parts for them from hk are not that bad. But you'll be crashing and I have prett much broken those parts I mentioned so you don't want to spend too much on other parts that you don't change that often, specially on the 250. It's just a good start and will keep your cost low. I use the cheapest orange servos as I'm still learning and now I'm not breaking them as much, later on you can move up to other parts if you like, but keep it simple at the beginning since you will be crashing if you don't know how to fly.
I started looking at the videos from finless bob just like everyone else , and they were helpful too. There are many more on youtube now so you can check those out. There was not much info posted on the radios when I started so I started my own blog on here so you can find information on that. Just click on the name and you can read stuff on there that I think will be helpful. There are many good people on here that will also help so just post and someone I'm sure will be able to help. You will get many different suggestion, but I just went with it and tried what I was comfortable with. I like to sometimes learn by doing so I never used a simulator, but did crash a lot. But eventually I got off the ground. We all learn in different ways. Just start slow and don't try to learn it all at once, you will get frustrated. It does take time, well at least for me it has, but eventually you'll figure it out. Believe me if I did, so can anyone. ![]() Now back to the heli, I would try the heli stock beause it will take time to figure out what works and doesn't work on the heli. I'm still learning but it gets easier as long as you can get a little bit of flying in. When you feel like throwing that thing out the window, just put it down and take a break, then go back to it when you're calm. There are times when the helis will do this if you are new at this stuff. It's a lot to learn, but keep trying and you'll see. FYI, a 450 is much easier to fly than a 250 though, but crashing the 450 sucks more than a 250. Literally and figuratively. Right now I do feel more comfortable trowing the 250 around than the 450. Bigger blades still kind of scares me a bit. So before anything, safety first. Try to figure out your components on the bench without blades first just to be safe. Remember even those tiny blades are dangerous if they hit you just right. Quote:
| Thread Tools | |
| Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. | darklyte24 | Micro Helis | 10570 | Apr 12, 2013 12:23 PM |
| Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review | The Don | Foamy EDFs | 37 | Oct 24, 2009 07:43 PM |
| GWS Spitfire Build thread (with glassing tutorial) | David Winter | GWS (Grand Wing Servo) | 156 | Sep 14, 2009 05:42 AM |
| Discussion Build log or review for BulleT? | raycsr | Electric Sailplanes | 3 | Jan 30, 2009 01:03 PM |
| looking for build thread with upclose photos | HIGHFLYER99 | Foamies (Kits) | 13 | May 21, 2005 08:54 PM |
