Old Aug 13, 2012, 04:10 PM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
What do you think it might be? I haven't put on the main rotors yet
zanek is offline Find More Posts by zanek
Old Aug 13, 2012, 04:17 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Could be a lot of things. Is this a clone or align? usually the flybar can be close and even bent a little and not cause to much trouble. The HK shafts are not that great. You could try putting the blades on and running it up. Every thing on the head of the 250 is so light compared to the blades.
mhills51 is offline Find More Posts by mhills51
Old Aug 13, 2012, 04:18 PM
zanek is offline
Agressive driver
Joined Jun 2011
Okay. I will balance the blades and put them on.
Old Aug 13, 2012, 11:18 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Weigh the paddles. I have had some from HK that were vastly different in weight.
(One was poorly "packed" in the mould and had visible shrinking).
Added a bit of tape to it till it weighed the same as the good one and it was fine.
pmackenzie is online now Find More Posts by pmackenzie
Old Aug 14, 2012, 08:32 AM
zanek is offline
Agressive driver
Joined Jun 2011
I will try that. I did notice that their main blades were hugely off balance
Old Aug 14, 2012, 05:00 PM
ipjodan is offline
Find More Posts by ipjodan
Gloves are awkward
ipjodan's Avatar
Preston, UK
Joined Dec 2004
Run it up without the paddles on? does it still vibrate?
ipjodan is offline Find More Posts by ipjodan
Old Aug 14, 2012, 08:15 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Some have said that they have that much power that they can break the pushrods.
Welp here they are side by side.
pitchp is offline Find More Posts by pitchp
Old Aug 14, 2012, 08:31 PM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
I've crashed with my 215's 3 times and each time it broke the plastic servo arms but nothing else on the servo( the largest arm)!Im running all four on my Beam at 7v.
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Aug 17, 2012, 08:00 PM
Hellysmack is offline
Find More Posts by Hellysmack
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Wow sounds like a good servo.
Hey all, Posted last of my parts for my HK-250 on flee bay for any interested.
I must cut back and the 250 was a blast but times are hard and need cash.
Hellysmack is offline Find More Posts by Hellysmack
Old Aug 17, 2012, 10:14 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
URL please for the guys here that may be interested in getting a bargain!
Old Aug 17, 2012, 10:51 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Welp I just tried the EXTREME Tail Boom Mount and the screws that they provided was no good. I couldn't even screw them in. Luckily I had some spare screws(HK250GT) and they seem to work fine
Old Aug 18, 2012, 09:15 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Well got my second one all set up with the flybar and all Align parts. Only problem I that I used a align screw for the bottom main and they strip so easy I got it all but one mm in and the head stripped. Aahh! So now I either live with the play or take the whole frame apart and try needle nose or the dremel trick. Just a recap Tarot uses the best screws for a 250. They use a 6-T, HK use a 5-t, Value a philips, and Align 1.3 butter.
Old Aug 18, 2012, 01:26 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Here are the new canopies I got
Old Aug 18, 2012, 09:32 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
If you measure the screw threads on that piece, they are not even a standard metric size. I ended up just sanding the align one using it.
BThirsk is offline Find More Posts by BThirsk
Old Aug 19, 2012, 07:12 PM
mayday1 is offline
Find More Posts by mayday1
rancho san antonio, CA
Joined Sep 2005
Flybarless Rotor Head Assembly Trex 250 / HK250
http://www.hobbyking.com/hobbyking/s...250_HK250.html
This is a complete flybarless rotor head assembly for the Trex 250/HK250 helicopter. It's made from lightweight black anodized CNC alloy, and features high quality bearings ensuring smooth and accurate operation. Includes all linkages and hardware.
Specs:
Main shaft diameter: 3.5mm
Price: $20
RJX?? I thought they would of cloned the DFC and the new Tail slider! May be that's later on???
Got mine a couple days ago. Mounted it today. It uses the same feathershaft
as regular flybarred align.
If you mount it as is, and use a beastX, you'll only get purple in step J (6 degrees
cyclic setup). I swapped the swash balls for longer ones and now I can get
red in step J. There is a huge amount of collective and cyclic pitch before there
is any binding, so should be good for hardcore 3D, but I'm a 2D guy.
Waiting for some tail parts and then I can maiden it.
mayday1 is offline Find More Posts by mayday1
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
