Old Aug 05, 2012, 03:29 AM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
The one thing I like about the belts is that they are more forgiving than the gears I'm sure. I have crashed a lot so I'm just surprised it didn't break at all. Then again I only snug them tight so that they are not too tight. I think this is the key for the belt to work correctly. Too much tension is not good, too little and the thing wonk work or slip.
efx is offline Find More Posts by efx
Old Aug 05, 2012, 05:30 AM
Busher is online now
Find More Posts by Busher
Joined Apr 2011
HI there.
I wonder if anybody could help me with my new zyx -s installation on my HK250GT. I have built it in Flybarred mode, but I am now a proud owner of the new FBL head from HK.
Basically I am looking for installation pics of were you would put the ZYX on the heli. and the pro and cons of the position. I will now not need a receiver as the new zyx comes with satelite connector.
Busher is online now Find More Posts by Busher
Old Aug 05, 2012, 03:07 PM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Originally Posted by Busher View Post
HI there.
I'm going to copy these setup and install it on the gyro mount
http://www.rcgroups.com/forums/showp...postcount=7351
and I'll also put my rx like thloh's
http://www.rcgroups.com/forums/showp...postcount=7409
pitchp is offline Find More Posts by pitchp
Old Aug 05, 2012, 04:05 PM
Joined Apr 2011
Originally Posted by pitchp View Post
Thanks for that, I was wondering how it was best done. The choices I have were pretty much what you have posted. I wondered if side mounting to the frames was favourite but wherever I placed it it seemed vulnerable to crash damage. The only problem I saw with mounting under the gyro mount was the gyro mount cannot be easily removed without taking the bottom frame out, so either the bottom frame or the underside of the gyro mount are similar in work if you have to get to the servo connectors. Guess that is just the downside of a small heli. I suppose once it is fitted then that will be it till you seriously bend it.
Old Aug 05, 2012, 04:11 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
I've read some posts on the 450 some people that tried to mount it on it's side got some issues with it. IIRC they got some real bad vibes or somewhere along that line. We're all here
http://www.rcgroups.com/forums/showthread.php?t=1512179
Old Aug 05, 2012, 10:11 PM
thloh85 is offline
Find More Posts by thloh85
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
Hi all,
A question about ZYX. I set the ZYX up, and use the F3C default parameters, but the heli wobbles on the aileron sometimes, especially when taking off. Am I setting my roll gyro gain too high? Or is there any advanced parameter I can set the fix this? I tried setting the Roll P gain to a lot higher (30), but still it wobbles sometimes...
thloh85 is offline Find More Posts by thloh85
Old Aug 06, 2012, 01:58 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
What are you cyclic gains currently set to? Aileron wobble does sound like the gain is too high. It can also be a sign of too much vibration.
Another trick is to lower the Roll P gain (usually 80) by 10, to 70. This still maintains the stability the I gain gives, which would also be reduced by lowering the overall gains.
I'm confused by this. Roll P gain is usually 80.
beenflying is offline Find More Posts by beenflying
Old Aug 06, 2012, 02:11 AM
thloh85 is offline
Joined Apr 2010
I'll try lowering the Roll P gain.
Oopz, I meant Roll D gain. I saw in some thread that Roll D gain will reduce the oscillation, thus I tried that.
Old Aug 06, 2012, 03:00 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by thloh85 View Post
...Oopz, I meant Roll D gain. I saw in some thread that Roll D gain will reduce the oscillation, thus I tried that.
I thought that might be the case. One other thing would be to try upgrading to v3.5, but make sure you lower you cyclic D gains to 10, to start with.
Old Aug 07, 2012, 10:19 AM
umejopa is offline
Find More Posts by umejopa
Sweden, Västerbotten County, Umeå
Joined May 2011
Building kit parts
I have bay the HK250GT kit and now and most other part I need.
But will I get ball link 3,5x5,3mm for the servos
Will take some week from Hongkong to get it so it good to now before.
Edit :
Seem other have get tha ball link to servos I will see if a get some
umejopa is offline Find More Posts by umejopa
Old Aug 08, 2012, 12:50 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
I got my other canopy in the mail today. I just love these canopies. I plan to slowly replace all my helis with this canopy
Old Aug 08, 2012, 01:10 PM
mugen 1 is offline
Find More Posts by mugen 1
Joined May 2011
They look real nice, where did you get them from?
mugen 1 is offline Find More Posts by mugen 1
Old Aug 08, 2012, 08:23 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
Flying-hobby.com
Old Aug 08, 2012, 10:07 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I'm thinking about selling one of my 250's What do you guys think? I just don't know which one to sell. I could sell my old reliable after all it has never been crashed. Or I just got all the parts to make number 2 just as reliable.
Align parts
motor, speed control, tail, head, OK never mind let me change this around What is not align....Frame lol! 502 gyro, eflite servos, hyperon tail servo.
I'm only selling it because I don't need two and I rarely use one anymore. Always flying the 500's and crashing the 450
mhills51 is offline Find More Posts by mhills51
Old Aug 09, 2012, 12:07 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
Align parts
Put them on the classifieds, they would sell quick!! and keep bumping it!
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 02:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 11:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 06:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 02:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 09:54 PM
