Old May 02, 2012, 01:24 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by Kauaiguy View Post
The comments on the Hobbyking site say the data logging isn't working right yet,some where calling it false advertising ,I liked the idea though so maybe they can work out the bugs!
Steve
I missed that. Also interesting to know. They currently don't have any of the programmers in stock anyway, and some things on HK's site seem to be taking a long time to come back into stock again. I think the other stores are draining a lot of the international stores stock.
beenflying is offline Find More Posts by beenflying
Old May 02, 2012, 02:18 AM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Hi guys I'm new to 250 and have bought the HK250 kit with tarot fbl head,PZ-15178B 9g cyclic servo, HK922 tail servo, Turnigy 4200kv motor, Walkera V2618D FBL receiver and 30A turnigy esc the question is I'm using 2s turnigy battery will it be sufficient for soft 3d?
OnceAFly is offline Find More Posts by OnceAFly
Old May 02, 2012, 05:15 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Nope - you'll need a 3S with that motor
MikeHRC is offline Find More Posts by MikeHRC
Old May 02, 2012, 05:23 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
http://www.amainhobbies.com/product_...s-Motor-5600kV
Specifications:
Model: VSH2556
Heli Class: 250
kV: 5600
Stator Arms: 9
Magnet Poles: 6
No-Load Current: 3.8A
Max Continuous Current (Amps): 18/22
Max Continuous Power (Watts): 180
Weight: 30g
Outer Diameter: 28mm
Shaft Diameter: 2.5mm
Body Length: 22mm
Max LiPo Cell Count:2S
pitchp is offline Find More Posts by pitchp
Old May 02, 2012, 03:53 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Okay, I got a new question...what do you guys do about the tight main blade links? I took off the hk links as one was fine, but the other was a bit tight and I now know that's causing hell in controlling the cyclics. The align links are nice, but tight as heck. I have been moving them up and down to losen them up but still not there. I used sciccors to take down a bit on one of the hk links and that left it too lose, so any suggestions to get these working correctly without messing them up. I crashed earlier due to the one not working correctly and hit a wall after I fixed it with the main blades but managed to save it. I know it's the links because once I got those lose, but not too much it would work great, now I feel like I got no control and I think this gyro is really messing me up too. But I want to get the links working correctly before I even mess with the gyro as I can at least get a hover, well not much as I can't turn where I want it to go.
efx is offline Find More Posts by efx
Old May 02, 2012, 05:04 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
After fighting these things with wiggles, hex driver through them, I'm sticking to the sciccors method. Just put the sciccors in them and turn with the edge angle not a gainst it to remove a little bit at a time. It's easier to do with the align since they're a bit harder. You may ruin the hk since they are thinner, doable, but just go slower. My receiver just came in and the one exi links which look similar to the align but I won't bother trying them now.
Old May 02, 2012, 05:07 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Jombo would say. Take a spare ball and a dremel to cut a slot in it to use as a reamer to open up the link.
mhills51 is offline Find More Posts by mhills51
Old May 02, 2012, 05:36 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Haha...well either that or I just figured you can probably use a small round file to take off a safe amount too. In any case I'm trying to bind my new receivers to my v2 and I can't get these to bind. Any ideas. I got the bind plug on the top BAT plug as that's where that points, and esc to channel 3. I tried turning the heli on with the esc on it, the light blinks. I then tried turning on the tx with the button pressed and nothing. I turned it off and back on, then tried to press the bind buton and still nothing with two so far. I'm wordering if it will do it with just a battery directly, but of course my battery is slow, so I'm charging it now and will try that in a bit.
Oh, this is the receiver. I hope this is the one that's should also work with the 9x too.
http://www.xheli.com/79p-r6b-receiver.html
Old May 02, 2012, 05:41 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Trex 250 Ball Link Sizing (1 min 50 sec)
Old May 02, 2012, 05:45 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Thanks pitchp...I don't know where my balls are right now, so I used the sciccors...now I'm just trying to get the new esc to bind, but not having any luck for whatever reason. Okay good news, I got one bound to the tx. You need to put the black/brown negative wires towards the edge of the transmitter, not the inside of it, now it binds fine, then just turn on the transmitter with the bind buton pressed and you're good. Then just unplug the battery, take out the bind plug and then the transmitter, it's all back to normal after that. Whew! Nice to know I can use the smaller receiver.
Old May 02, 2012, 07:29 PM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Thanks guys for the reply guess i will need to get some 3s battery and use the 2s for just flying around..
Old May 02, 2012, 07:31 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Slowly but surely, they're finally coming to life. Charging batteries so I can set up the gyros. I took out the gy48 and put on the 250 I have and then I'll see if I can set up the tarot gyro too. I decided to mount everything with velcro, just added the velcro strap and they hold on just fine. Trying to move stuff with the double sided tape is a pain even though I like the hold too. I put the receivers facing down as I want to be able to plug and unplug things since I'm still crashing every now and then. The xheli 250 uses the same type of skids as the hk so that was cool. I still prefer the one piece skids, one less thing to adjust but they also break easier.
Old May 02, 2012, 07:36 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
wow. they look really nice efx. very nice indeed.
Old May 02, 2012, 08:34 PM
Micro Buzzer is offline
Find More Posts by Micro Buzzer
Micro Buzzer's Avatar
Joined Oct 2009
Since we are talking about resizing links, does anyone know of a trick to decide what is the proper tension of a link on the 250. I heard people say that the link should start to fall under its own weight but when I resized the link until it started to fall under its own weight, the link had slop in it.
Micro Buzzer is offline Find More Posts by Micro Buzzer
Old May 02, 2012, 09:39 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Okay, here are a few more pictures of the final setups before I crash them again. This is what I have ended up with after setting both of them up and the gyros. I just need to test them and trim them assuming no nasty things come up.
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
