Old Apr 24, 2012, 07:14 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
It's down stairs with epoxy drying...... don't ask! lol!!
mhills51 is offline Find More Posts by mhills51
Old Apr 24, 2012, 07:16 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
I hope you get it going mhills. I really want to see and hear that baby fly!!
pitchp is offline Find More Posts by pitchp
Old Apr 24, 2012, 07:21 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Right now my attitude on it matches my avatar.
Old Apr 24, 2012, 07:23 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
alright guys I changed my list again, because mhills mentioned an important note about tail boom strikes with fbl heads, so i thought ok harder filler dampers! Trueblood!
So here's my list now!
Cheapie Ultimate 250 (my future ongoing research project)
The 250 kit
http://www.hobbyking.com/hobbyking/s...idproduct=9974
Align T-Rex 250 250FL Linkage rod(A) set H25109
http://www.ebay.com.au/itm/Align-T-R...item3a5faa911b
The Cyclics
http://www.hobbyking.com/hobbyking/s...dproduct=16260
The Tail Belt Gear
http://www.hobbyking.com/hobbyking/s...2pcs_set_.html
The Tail Belt
http://www.ebay.com.au/itm/Super-tai...item3365572fdc
Align T-Rex 250 Tail Rotor Control Arm Set H25062-1
http://www.ebay.com.au/itm/Align-T-R...-/250735084214
The Tail Servo
http://www.hobbyking.com/hobbyking/s...06sec_21g.html
The Tail Push Rod
http://www.completeheli.com/Flying-S...Pushrod-FS1209
The ESC
http://www.ebay.com.au/itm/Align-15A...item4162f3f952
The Motor
http://www.hobbyking.com/hobbyking/s...idProduct=8501
The Pinion
http://www.hobbyking.com/hobbyking/s...idProduct=9253
The Swash Plate
http://www.ebay.com.au/itm/Align-H25...item589192e5d0
The Lipo
http://www.hobbyking.com/hobbyking/s...dproduct=18203
The RX
http://www.hobbyking.com/hobbyking/s...dproduct=20684
The TX
http://www.hobbyking.com/hobbyking/s...idproduct=9895
The Main Blades
http://www.hobbyking.com/hobbyking/s...dproduct=10821
Trueblood Dampers
http://helidirect.com/trueblood-head...50-p-19811.hdx
The FBL Unit
http://www.oomodel.com/tarot-zyx-3-a...2-p-61906.html
http://www.oomodel.com/tarot-zyx04-m...n-p-61880.html
Or
http://www.infinity-hobby.com/main/p...oducts_id=7611
http://www.infinity-hobby.com/main/p...oducts_id=7853
http://www.hobbyking.com/hobbyking/s..._Adapter_.html
Old Apr 24, 2012, 07:24 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
what if you change your avatar picture to something like mine, would it change your attitude?
Just try it!
Old Apr 24, 2012, 08:00 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
NO, I just got back up stairs. I found what let go that broke everything. It was the align tail holder. It seemed tight, but even after changing the screws it will not tighten down. Also the boom is bent as well as the tail shaft. Good thing the kit came with two. I will get a align boom and see if that works and shave the blocks down a bit. Funny but if it was belt it would of just slipped instead the shaft drive wanted to tare everything apart.
Old Apr 24, 2012, 08:02 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
What makes things more frustrating is trying to work on this pile after working on the sweet and perfect no fuss Align 500pro.
Old Apr 24, 2012, 09:15 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Spoofman and I have been trying to work out some good combos for this 250 since time began! The 250 is a mans heli.
I'm thinking of using the trueblood dampers on this hk250gt some stiff professional dampers, to fix the vibes @ 4800 HS.
Old Apr 25, 2012, 12:15 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
anyone use this? CF tail blades?
http://www.ebay.com/itm/Real-carbon-...item2311dd8838
Old Apr 25, 2012, 05:14 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Nothing wrong with those linkages as a replacement or spare part, but there are flybarless linkages included with the Tarot ZYX and 250 head combo. You'll just have to screw on the plastic ends.
(The USB programmer link is optional though.)
PHMX is offline Find More Posts by PHMX
Old Apr 25, 2012, 06:05 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
very nice phmx, very nice! is that your next project? Will it also be a 250 FBL TT?
Old Apr 25, 2012, 06:26 AM
PHMX is offline
Joined Feb 2011
Yeah, it's actually already installed on my repaired CopterX 250. I'm pretty satisfied with the Tarot ZYX, but it still needs some fine-tuning flights.
No, it's not a 250 FBL TT. I'm not a huge fan of torque tubes as I'm usually landing in taller grass, something that perhaps becomes more of an issue with a smaller helicopter.
Old Apr 26, 2012, 07:56 AM
rseegers is offline
Find More Posts by rseegers
Cambodia
Joined May 2009
Originally Posted by Kauaiguy View Post
You might have to use the Walkera esc with that rx.I think the Walkera esc uses a + signal.To make a non Walkera esc work you need a positive signal from the battery source,to the connection called (battery test).Unlike most receivers that have a common postive and negative bus rails ,the Walkera rx's seperate the signal to the esc and rx side(I think they did it that way so the Walkera esc would shut down before battery damage).To make my rx2435 (4channel) work I made a positive wire soldered to esc board and connected to battery test connector.Im using a yellow eBay $6 esc.
Steve
Thanks for that. I don't want to try this on my current esc, but instead order http://www.hobbyking.com/hobbyking/s...ontroller.html.
This "battery test connector" is on all escs and an easy enough to solder a wire to; or would I better off with a different esc for this?
rseegers is offline Find More Posts by rseegers
Old Apr 26, 2012, 10:20 AM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
That esc should be pretty good for your project!
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Apr 26, 2012, 10:52 AM
cgriffith is offline
Find More Posts by cgriffith
cgriffith's Avatar
United States, FL, Oviedo
Joined Apr 2011
@pitchp
I really enjoy seeing your shopping list, but not will all the pictures every time. Don't like to scroll so much. Can you just post the links next time.
cgriffith is offline Find More Posts by cgriffith
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
