Old Mar 07, 2012, 01:44 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Originally Posted by HolgiB View Post
I am using the HKSCM9-6 on my 450 V2 and really satisfied with them.
But some words about the spare gears. HobbyKing doesn't have spare gears for them. You can use the HXT900 gears to fix a broken servo. But two of the gears (the two top ones) need to be replaced and the number of teeth is different. So the ratio/speed of the servo changes. When you have 3 broken servos with stripped gears, you can build an identical set with these gears. Could be used for cyclic again, but perform different of course!
The ESC only got a 5V BEC. You are wasting potential of your servos. I would rather go for a BEC which can do 6V. But there is nothing in the HK store. The only small ESC I know with 6V BEC (you can even adjust from 5 - 6 in .25V steps,) is the original Align one. It also comes with a governor and is quite light.
I know what you mean, it would be nice for a cheapie clone of this Align 15A ESC
RCE-BL15X
http://beta.ivc.no/rc_airplane/align...esc_manual.pdf
It would also be nice for HK to have some decent ESC clones of th Mini Jazz 15A/20A ESC.
pitchp is offline Find More Posts by pitchp
Old Mar 07, 2012, 04:29 AM
HolgiB is offline
Find More Posts by HolgiB
Australia, NSW, Sydney
Joined Mar 2011
YES I can't agree more. There is acutally no "real" heli ESC in the HobbyKing store. Switchable BEC is for higher amp ESCs also a rare feature. Well we can add a separate BEC (like I did for my 250) but with the wiring and one additional electronic component on the heli not nice.
Especially with FBL, where you already have to cramp quite something into our tiny birds.
HolgiB is offline Find More Posts by HolgiB
Old Mar 07, 2012, 05:44 AM
HolgiB is offline
Joined Mar 2011
Hobbyking is now stocking the programming adapter as well for the ZYX FBL:
http://www.hobbyking.com/hobbyking/s..._Adapter_.html
But still no cheap 450 FBL heads in stock and nothing for the 250.
Old Mar 07, 2012, 06:53 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
What would you consider to be a real heli ESC? There are loads of ESC with decent soft start features and governor modes. Not all of them come with SBECs, but some in fact do. This number also seems to be increasing.
Then there's the obvious thing of many helicopter setups not requiring more than the 5V many ESCs do provide effortlessly.
Its somewhat of a myth that you actually need those 6V with smaller helicopters though, unless you're talking about an outdated inefficient old generation linear BECs that can't provide a reliable continuous 2A/3A output current for your electronics.
Many of the modern SBECs boast an efficiency of ~93% which is well enough to meet the demand of digital servos of higher torque and additional electronics you'd normally use on the smaller helicopters.
The Turnigy AE-30A Brushless ESC will really work fine on a 250, without using a UBEC.
The main reason why people choose to use an UBEC is to maintain control over servos and receiver (doh) in case of an ESC failure.
PHMX is offline Find More Posts by PHMX
Old Mar 07, 2012, 07:31 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Tarot has a 250 speed control that looks just like the Align. There is no specs on it, but it is cheap http://www.rcinthebox.com/tarot-250-...-_p148356.html
mhills51 is offline Find More Posts by mhills51
Old Mar 07, 2012, 08:00 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
that's a pentium esc. I got that one. the one we are looking for has to have
6v to support the servos. Turnigy AE will be fine, but it wont bring the servos to it's optimum efficiency. The turnigy ae will work with those servos, it will be good enough for now. But I am considering that align ESC just to see what those servos can really do. But if you find an align esc clone or even better one, please let us know.
But just to sum it up Holgib is just trying to make sure there is minimal power congestion (for a lack of a better word) as such in my power train. If the esc doesn't deliver the power that the servos trully need, then the result is something what this guy is experiencing.
slow servos (0 min 26 sec)
A good Power Train is the key!
Old Mar 07, 2012, 08:01 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Intermission....
Trex 250SE 16T pinion (3 min 35 sec)
Old Mar 07, 2012, 08:17 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Good news! one of my 250 torque tubes have shipped!
Old Mar 07, 2012, 08:22 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
photos please!
Old Mar 07, 2012, 10:38 AM
PHMX is offline
Joined Feb 2011
http://www.youtube.com/watch?v=m9jsU...1&feature=plcp
That doesn't look like a power issue to me though. Under such zero load conditions like this servos will easily be able to run at their full speed.
It's also entirely unknown which FBL settings he's using there, but I'd suspect he's got something setup wrong in there instead or is simply using terribly slow servos like the title suggests.
Old Mar 07, 2012, 02:13 PM
im2tall is offline
Find More Posts by im2tall
Joined Feb 2012
I installed the Power HD D65 servo on the tail and was wondering if this was a bad idea!I bought it for its size , weight ,and speed!!The torque is somewhat low compared to the mini servos alot of people are using,but I really don't think that should be a issue with these 250's what do you guys think?
[IMG][/IMG]
http://www.hobbyking.com/hobbyking/s...5kg_07sec.html
im2tall is offline Find More Posts by im2tall
Old Mar 07, 2012, 03:04 PM
PHMX is offline
Joined Feb 2011
I'm using this one;
http://www.hobbyking.com/hobbyking/s...dProduct=10976
and it's actually very capable of withstanding hardcore 3D (on both 250s and 450s alike).
So, I really think you should be just fine with 1,3kg/cm @ 4,8v and 1,5kg/cm @ 6v for the most part.
The difference isn't actually that huge.
Old Mar 07, 2012, 03:17 PM
im2tall is offline
Joined Feb 2012
Thanks!
Old Mar 07, 2012, 05:55 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Those servos are slightly slower indeed, and he admits to that but he also admits that the esc wasn't doing the power train any justice.
But it would be nice for the turnigy ae to be upgraded to support 6v servos.
He's using the copterx on an HK450 modded kit.
Copterx FBL unit in HK450 (4 min 26 sec)
But I'm still considering the ALIGN 15A ESC just to see how those orange servos perform on 6v POWER!!
Old Mar 07, 2012, 06:00 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
The MOST EXPENSIVE 250!!
This has to be the most expensive 250 heli, I have ever seen!! $2300.00 ouch!
http://www.ebay.com.au/itm/ALIGN-RTF...item53ea42ecbf
why is it so expensive????
It looks similar to the Trex 250 V2 FBL combo that is about to be released!
I'm wondering will HK make an HK250GTarot FBL Combo soon??
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
