Old Oct 02, 2009, 10:03 PM
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
So I have the heli ordered, but I need to get some gear coming for it. Any suggestions on servos and a motor? I'll probably run a turnagy ESC since I have the programmer and like it, and as far as the gyro goes, I'll probably get something more high end since they can always be moved to bigger helis and the gyro has everything to do with how it flys.
schu
akschu is offline Find More Posts by akschu
Old Oct 02, 2009, 11:07 PM
Excellence is Expected
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Originally Posted by lovespicyfood
Just to clarify, is this the HK250GT or the standard HK250? I'm seriously considering one of these for a small field inverted hover trainer, but I'm weighing a real T-Rex250...
Thanks!
That would be = to the GT
MakMov is offline Find More Posts by MakMov
Old Oct 02, 2009, 11:19 PM
d3x
Joined Jan 2009
Hi, i have two questions for those who are more aware what will fit in and work and what will not. Is this setup ok for normal flying (no 3d or invert) and what servo would you recommend for a tail (preferably from HobbyKing)
HK-T250 CCPM Electric Helicopter Kit $29.99 499g
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo $23.85 75g
Turnigy 2627 Brushless Outrunner 3800kv $12.01 82g
TURNIGY Basic 25A v3.1 Speed Controller $15.49 45g
Spektrum AR6100 (have a spere one)
GY401 + ??? Servo (same here, have spare one)
Z8003S20C - ZIPPY Flightmax 800mAh 3S1P 20C
dexter
d3x is offline Find More Posts by d3x
Old Oct 03, 2009, 12:05 AM
flying with dx7...
futabafreak's Avatar
USA, MD, Westminster
Joined Aug 2006
I have yet to get my hk250 and Im already looking for parts lots and used trex 250s on ebay and I came across this anyone know anything about using a flybarless head on a 250?
futabafreak is offline Find More Posts by futabafreak
Old Oct 03, 2009, 06:37 AM
Sir J David's Avatar
Sweden
Joined Dec 2007
dexter
Go for the mks ds-480 for the tail. I use it at a 450 and will start use them at my 250's as well. It's abut $25 at hobbycity
Sir J David is offline Find More Posts by Sir J David
Old Oct 03, 2009, 11:26 AM
I Can Fly An FP Inverted!
Hal_The_Hacker's Avatar
Teddington, Middlesex, UK
Joined Jun 2008
I run a flybarless set up on one of my 180 class helis, and it flies OK, though ideally you want a 3 axis gyro, which adds a lot of weight.
its not really worth it on a heli as small as this, any weight/drag you save in the head, you will add with the 3 axis system.
I have not tried my flybarless 180 in forward flight, thats how little I trust it, i would never attempt to 3d it
Hal_The_Hacker is offline Find More Posts by Hal_The_Hacker
Old Oct 03, 2009, 11:57 AM
Joined May 2006
Helidirect sells a flybarless head for the T-rex 250
http://www.helidirect.com/microheli-...50-p-14149.hdx
skizziks is online now Find More Posts by skizziks
Old Oct 03, 2009, 01:34 PM
Nitro Freak
Dark-Angel's Avatar
Canada, Quebec, Saguenay
Joined Jul 2008
Originally Posted by Hal_The_Hacker
60g is on the light side of things, 75g is average i reckon, but 95g is definately on the heavy side
a 4s 250 sounds pretty cool, now you got me wanting one
or maybe a 6s 250.......
hmmmm
yep, wont go 3s finaly.. ive choosen to go the 4s route(dual 2s pack) 600-610 mah will weight around 70g - ~35g each pack
so ill be able to use the 2s packs in my other helis.
my 900mah packs are abit heavy for the ff200 anyways.. have to fly w/o canopy.. the 600 should be just fine.
i like when my helis can share their batteries.
6s seem abit overkill though
Dark-Angel is offline Find More Posts by Dark-Angel
Old Oct 03, 2009, 03:04 PM
Heli Hooligan
London
Joined Dec 2006
You will need an ESC capable of 4s. Many claim 4s but if they have a linear BEC then you will need to disable it and run an external BEC. If it has a switching BEC and the ESC claims 4s then the BEC should be good for 4s too.
mahbouni is offline Find More Posts by mahbouni
Old Oct 03, 2009, 03:29 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
I think that you will struggle to fit the batteries in and get the canopy on with a senssible CoG using 4S
MikeHRC is offline Find More Posts by MikeHRC
Old Oct 03, 2009, 05:12 PM
Joined Oct 2007
Originally Posted by tornadorc
what HS do you need? are you going to be using the 15T pinion?
I want to use 15T pinion and a good HS for sport fly. The only ones I found are the originals Align 250, Align 250S and Scorpion 2206-3900.
pastoreli is offline Find More Posts by pastoreli
Old Oct 03, 2009, 09:41 PM
Lake City, PA USA
Joined Sep 1999
For anybody building the base kit:
Anybody notice the main gear is a bit out of round so that it is pretty stiff in spots with the tail drive, or is it just mine.
Also, The bottom end of the main shaft was too big for the bearing in the main gear. I chucked the main shaft into my drill press and cleaned up the end of the shaft with some 220 wet or dry and got everything to fit.
FWIW, my motor mount was put in upside down at the factory. No biggie, but if you dont know...
Finally, I got the recommended 3500 kv motor but it is lots bigger than the Align on my "real" t-rex. It still fits, but is heavier. I may look for a smaller motor since this will be an indoor flyer and I am hoping for lighter...
I am using htx900 servos which are working out fine so far. All three installed in frame and head & linkage mounted.
Gene
GeneR is offline Find More Posts by GeneR
Old Oct 04, 2009, 12:07 AM
Joined Jun 2005
also reserved
dinner is offline Find More Posts by dinner
Old Oct 04, 2009, 02:08 AM
new pilot - micro addict
UH -1H's Avatar
Singapore
Joined Jul 2007
yummy...
Subscribled
UH -1H is offline Find More Posts by UH -1H
Old Oct 04, 2009, 08:52 AM
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
That thing scares the living daylights out of me. I see how my Microheli T250 tail pitch arm is wearing a groove into the Microheli slider...if they are using the same grade aluminum that thing might be a big headache.
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10571 Jun 10, 2013 02:41 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 37 Oct 24, 2009 07:43 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
