Old Oct 17, 2009, 09:09 PM
distractor is offline
Find More Posts by distractor
East Coast, Australia
Joined Jul 2009
Originally Posted by Evan D
I have not been able to find a 2.3mm .4 mod 13 or 14 tooth pinion. If anyone knows where to find one plaese give me a link.
13 Tooth
14 Tooth
distractor is offline Find More Posts by distractor
Old Oct 17, 2009, 09:12 PM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
You can also risk your rx rebooting even if you use a BEC on a 2.4 ghz system.....Your battery may say 20c or more but because you are using a jst connector you will only be getting between 10c and 15c....
skizziks is offline Find More Posts by skizziks
Kepler is offline
Find More Posts by Kepler
I'll have one of each thanks
Kepler's Avatar
Melbourne Australia
Joined Feb 2006
Originally Posted by Hal_The_Hacker
well you must be flying very gently then.
I have melted pairs before in my gaui 200, and that only runs on 2S
2S would be harder on the plugs then 3S flying this size model.
Not trying to be argumentitive here, the Deans are a better choice without doubt. However, most packs come with JST plugs standard. The JST plugs are adequate unless you are a really hard flier.
I run a 3800kv motor 13 tooth and have +/- 12 degrees pitch. I am yet to hurt a plug.
However, I certainly appreciate your information and if start having problems, I will look at the deans for sure.
Kepler is offline Find More Posts by Kepler
Old Oct 17, 2009, 09:18 PM
skizziks is offline
Joined May 2006
The reason that they put JST connectors on packs in Asia is because deans are hard to get in Asia and that is where the packs are made....You never will find JST connectors on 220mah 20c packs because they will melt...Anything above 1300mah 15c will have a deans connector....I work at a Hobby store I should know this.....3dxhobbies.com
Old Oct 17, 2009, 11:56 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Originally Posted by mahbouni
Yes I'm sure they work for you like they work for most people, but you are pushing it beyond limits and therefore there will be voltage drop acros the connection, which results in poorer performance. Whether you notice that or not is one thing but you are on the borderline of overloading the connector. All it takes is a little bit of dirt or oxidization on the connector pins and then you risk an ESC shutdown.
Thanks mahbouni....yep....mine are going to mini deans shortly and if I were setting up a new heli like many in this thread I would choose to not use jst.
On another note here is another source of pinions:
http://www.helidirect.com/motor-pini...c-1_78_512.hdx
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Oct 18, 2009, 02:54 AM
erna is offline
Find More Posts by erna
Joined Aug 2009
http://www.hobbycity.com/hobbycity/s...idProduct=9254
erna is offline Find More Posts by erna
Old Oct 18, 2009, 05:09 AM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Connectors
2mm gold connectors are the way to go in my opinion.
ghost2212 is offline Find More Posts by ghost2212
Old Oct 18, 2009, 06:14 AM
mahbouni is offline
Find More Posts by mahbouni
Heli Hooligan
London
Joined Dec 2006
Yes they would be good too. I use them for motor connections. Medusa used to sell some really light weight ones (0.5g per mated pair and good for 30A cont) but unfortunately they are not in the RC business anymore. I haven't yet found any others as light as that.
mahbouni is offline Find More Posts by mahbouni
Old Oct 18, 2009, 06:28 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Amp
Be careful - a lot of those are 0.5m (trex 450 size) - you need 0.4M for the T250 and clones
MikeHRC is offline Find More Posts by MikeHRC
Old Oct 18, 2009, 08:13 AM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Thanks guys. Looks like another order to HK....
If anyone does find the right 13t in stock let me know.
Evan D is offline Find More Posts by Evan D
Old Oct 18, 2009, 01:24 PM
holsen is offline
Find More Posts by holsen
Joined Mar 2009
Tail belt too loose/long?
After first test flight today with my new HK250GT, my tail belt became way too loose. Ok, back to the table and have a look. I notice that if the tail case is pushed all the way in over the tail boom, then the tail boom cannot be pulled enough rearward to tighten the belt before the tail boom exits the first of the two grips to hold it in place. So to keep the boom in both grips, I had to move the tail case rearwards on the boom, so much that you can see the boom end through the slot you can look through in the tail case.
holsen is offline Find More Posts by holsen
Old Oct 18, 2009, 01:34 PM
holsen is offline
Joined Mar 2009
Another set of observations:
The G401B gyro sits very close to the tail boom supports when mounted upside down under the gyro mount (only position that I could see as it's rather big). But it just clears both (at least without vibrations on the ground/table) if positioned precisely.
I have a MKS480 on the tail, ball in closest servo arm hole, servo rod parallel to boom, no binding, gyro in digital mode, 0 delay, around 80 for limit. But the tail was not solid. Could only gain via gear channel up to around +35 before it shaked a little. On piro stop I get a bounce. Not a "clean" and quick stop. Is the servo too weak? I have a GWS HPX-F from HK as well to try (more torque as I remember but not digital).
Do I need a more highend gyro and/or servo for a more solid feel?
Also annoyed by the canopy being too tight or out of intended shape I guess on the left side, so the servo hits it. Tried to dremel a rather large hole in it to make room. Not optimal. The noise level is also increased quite a lot with it on, so I test flew without, but visibility is hurt, and a 250 sure gets very small to look at very quickly
Old Oct 18, 2009, 01:51 PM
Hal_The_Hacker is offline
Find More Posts by Hal_The_Hacker
I Can Fly An FP Inverted!
Hal_The_Hacker's Avatar
Teddington, Middlesex, UK
Joined Jun 2008
I assume you mean for the battery.
not such a great idea, I know a guy who's nephew managed to 'daisy chain' 8 6s2500 packs, soon as he connected the last connector, that garage never looked the same again
not to mention the possibility of plugging them into each other by accident, or having them touching
the hazards are neverending
Hal_The_Hacker is offline Find More Posts by Hal_The_Hacker
Old Oct 18, 2009, 01:52 PM
Joined Jun 2008
belt on mine was fine, check to see if any of the fibers in your belt have snapped, and caused the belt to expand
Old Oct 18, 2009, 01:54 PM
Joined Jun 2008
Originally Posted by 9sec240
As voltage goes up, amperage goes down. A 2S would be harder on the connector than a 3S at the same watts.
yeah I know this, i forgot to mention the fact that i use a 10A esc on 2s, when everyone here uses 18A escs on 3s, thats a lot more amps.....
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
