Old Oct 02, 2009, 04:12 PM
Hal_The_Hacker is offline
Find More Posts by Hal_The_Hacker
I Can Fly An FP Inverted!
Hal_The_Hacker's Avatar
Teddington, Middlesex, UK
Joined Jun 2008
Yeah I love my gaui, but i need an inverted hover trainer, and the 250 is just that
Hal_The_Hacker is offline Find More Posts by Hal_The_Hacker
Old Oct 02, 2009, 04:22 PM
HeliStyle is offline
Find More Posts by HeliStyle
hmmm...
Joined Sep 2008
I do believe the MG-14 servo's will not fit in this heli, without some serious grinding of the frame
HeliStyle is offline Find More Posts by HeliStyle
Old Oct 02, 2009, 04:31 PM
Dark-Angel is offline
Find More Posts by Dark-Angel
Nitro Freak
Dark-Angel's Avatar
Canada, Quebec, Saguenay
Joined Jul 2008
these things are selling like hot cakes.. heh
any good 2s setup out there? or i would be better to run it off 3s lipos?
i would like a 2s setup since ive a rotofly and 2 ff200 that run on 2s, so ive couple of lipos for them already.
or mb 4s(2s2p with my current packs)? that would be too big/heavy i guess?
Dark-Angel is offline Find More Posts by Dark-Angel
Old Oct 02, 2009, 04:32 PM
hmmm...
Joined Sep 2008
if you did a 4s lipo, would be to heavy and your headspeed would be crazy with the stock 15t pinion lol
Old Oct 02, 2009, 04:43 PM
Nitro Freak
Dark-Angel's Avatar
Joined Jul 2008
yea, i mean 2 2s pack in series, i could use a lower Kv motor and different pinion.
whats the average weight of the 3s pack you guys run in these 250?
just weighted 2 2s 900mah which give a total of 95g.
Old Oct 02, 2009, 04:58 PM
Joined Jun 2008
I will be using a few 3s 800 desire packs which weigh in at 60g each.
Old Oct 02, 2009, 05:18 PM
Nitro Freak
Dark-Angel's Avatar
Joined Jul 2008
i see, 95g would be too heavy then.
would need pack of 500-600 mah to get a decent weight on 4s.
ill probaly go for 3s.
Old Oct 02, 2009, 05:20 PM
Joined Jun 2008
60g is on the light side of things, 75g is average i reckon, but 95g is definately on the heavy side
a 4s 250 sounds pretty cool, now you got me wanting one
or maybe a 6s 250.......
hmmmm
Old Oct 02, 2009, 05:27 PM
Hellysmack is offline
Find More Posts by Hellysmack
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
I really shouldn’t
Subscribed
Hellysmack is offline Find More Posts by Hellysmack
Old Oct 02, 2009, 06:03 PM
mahbouni is offline
Find More Posts by mahbouni
Heli Hooligan
London
Joined Dec 2006
My 250 packs are between 61-75g. The lightest 61g Outrage 3s 800mAh pack is a bit old and doesn'lt produce a great headspeed but I can still do gentle tictocs, etc. My 75g ProPower 850mAh pack is quite new and potent. Tictocs are quite aggressive and it's very quick. I tried an 83g 3s 1000mAh pack but it didn't perform so good. Keep it light if you want to do 3D. Mine is 295g with the 61g pack.
mahbouni is offline Find More Posts by mahbouni
Old Oct 02, 2009, 07:05 PM
pastoreli is offline
Find More Posts by pastoreli
Joined Oct 2007
I would like suggestions for HK250GT motors for use with 3S800 20C (16A max and sport fly).
pastoreli is offline Find More Posts by pastoreli
Old Oct 02, 2009, 07:26 PM
tornadorc is offline
Find More Posts by tornadorc
Frequent Flyer
tornadorc's Avatar
Australia, Melbourne
Joined Jun 2009
what HS do you need? are you going to be using the 15T pinion?
tornadorc is offline Find More Posts by tornadorc
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
Originally Posted by MakMov
I can that it's the exact same heli as the Bullet I already have. Same canopy, same everything down to the three tools. They can call it whatever they want but it's the exact same heli.
How is it? It's not a bad little heli.
I can say that when I first got it flying it was every bit as good as my Trex.
However, it is not as strong or durable as my Trex. It has 1/2 the flying time as my Trex and has gone through a lot more parts. Partly because I have crashed a few times more than my Trex but now even things like bearings are starting to wear out. the head which has been rebuilt with half and half stock and Align parts is much more loose than my Trex head.
I even had the swash ball fall out for no apparent reason.
Now on the other hand, the stuff I have replaced with Align parts has been fine. I will, however, soon have to replace the rest of the head, which will make it about 80% Trex and 20% original.
I could have bought a new Super Combo Trex and had money left over for what I have in the clone.
Replace the head, tail and gear and will have a heli as good or better than the Trex.
There are some good things about the clone that the Trex doesn't have.
Much better hardware.
More metal. The boom tail fin support bracket is metal. The boom mount metal, the tail drive blocks are metal. Metal tail servo brackets.
Much better tail pushrod fins or guides
When I first saw the paddles I was WHAT THE But I kind of like them now. They are like my big heli with a set screw that locks them in place.
Just to clarify, is this the HK250GT or the standard HK250? I'm seriously considering one of these for a small field inverted hover trainer, but I'm weighing a real T-Rex250...
Thanks!
lovespicyfood is offline Find More Posts by lovespicyfood
Old Oct 02, 2009, 07:34 PM
Frequent Flyer
tornadorc's Avatar
Joined Jun 2009
try them all. see which one works for you
Old Oct 02, 2009, 07:46 PM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
250's rock! (dont have anything else to say, but I'm curious how that base model will go together)
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
