Old Mar 15, 2011, 02:55 AM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
+10/-10 is nice, i have +11/-12
as for your other question I use to screws. I use the spare screws that came with the kit, the small ones that is used for the main frame. I dremelled a bit off just enough so that it protrude inside the tail boom but not too much or the tail will rub on it, just enough to see it protruding instide. I also round off the edges of the screw, then i dip the edge in some Epoxy. i allow to cure and hardened then i place that in the hole with some CA. I use 2 screws because i oil my tail everytime prior to use. i hope this helps.
pitchp is offline Find More Posts by pitchp
Old Mar 15, 2011, 03:06 AM
ministeve2003 is offline
Find More Posts by ministeve2003
ministeve2003's Avatar
Joined Sep 2007
Originally Posted by HolgiB View Post
Just one more question about the HK-250 setup. How much Pitch, Aileron and Elevator are you using in your transmitter at the swashplate setup?
Thats what I have set up:
Pitch 45%
Aileron 55%
Elevator 55%
I just check with throttle off...
Move pitch up and down, move all servos... if it doesn't bind and your servo arm doesn't hit the main gear... you should be ok...lol
SK
ministeve2003 is offline Find More Posts by ministeve2003
Old Mar 15, 2011, 04:48 AM
HolgiB is offline
Find More Posts by HolgiB
Australia, NSW, Sydney
Joined Mar 2011
@pitchp
Thank you. Good idea with the epoxy. I should use epoxy as well, it would remain forever in its place then.
@ministeve2003
Ok, then I keep my settings like that. Had also in mind to have it easy controllable. I am a bit afraid of this little devil and my limited pilot skills.
Seems my bird is grounded for tonite. Yesterday at the first test flight, my tail box was twisted to the right. I lost one tail blade in the following ground contact and the store around the corner has no spare.
But lesson learned. Why not ordering some cheap spare from HobbyKing, right then when buying the helicopter...
HolgiB is offline Find More Posts by HolgiB
Old Mar 15, 2011, 05:49 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
@pitchp
@ministeve2003
lol read what i posted again. it wont be there forever, i allowed the screw to dry hence the epoxy will hardened (once the epoxy is dried on the screw) then i screw it in i add a bit of CA to lock it into place. And when it comes time to change the belt i apply the soldering iron rod on to the head of the screw and she comes out like butter. Do you get it dude? lol what ever you do, dont epoxy the screw into place. It will be there forever! lol
To sum it up, I am replacing the rubber dongle with a metal dongle but coated with epoxy, and i'm using CA to lock it into place. i hope you get what i'm trying to say. I know the guys here know what i'm talking about, and i understand you are new to this 250, and as the guys here we'll tell ya, it's trully a fun heli to have.
Old Mar 15, 2011, 05:53 AM
Hellysmack is offline
Find More Posts by Hellysmack
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Originally Posted by pitchp View Post
Very cool did not know they had one, fancy, Haven’t tried that one, I actually just use an old white towel/rag.
Originally Posted by jombo View Post
well guys i have given up with this weather . i have started another project ging to post it up in the scale forum but want to give you guys a sneek peek
and i threw in the hk250 GT so i am on topic
That is gonging to be sharp, please post both when done.
Pitch 45%
Aileron 55%
Elevator 55%
@pitchp
@ministeve2003
I may be all wet but I will throw in my 2 cents’,
I love helicopters but for as long as I have been at it I suck. But hey I am having fun.
My 450 is more intimidating as far as getting in the blades, the 250 will seem to move faster because of its small size. So I set mine real mild and will increase AIL and Ele as I feel more comfortable. The pitch on the other hand I adjust it so I get full range in the head without binding. I then adjust the pitch curve so that I am getting +10 & -10. As I am flying I can adjust these up or down to how it flies, I increase pitch until it starts to bog then I back off.
Pitch 67%
Aileron 45%
Elevator 45%
I feel your pain I Have been waiting on parts for ever so it seems but they showed up last night so just need to balance blades and put on training gear for test flight.
Hellysmack is offline Find More Posts by Hellysmack
Old Mar 15, 2011, 12:13 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
will do Hellysmack, i put it right here. http://www.rcgroups.com/forums/showthread.php?t=1406692
pitchp, i just looked at what your talking about the black angel , i have to say that has to be the u..... . the black i like , but what is up with the gold tub swash .
the reason i like the blue is it is more visible when its flying than the black , but i would prefer the black over the blue if they gave me a choice.
see how bad the weather is here , yesterday the sun was out and it was snowing , today its cold and looks like its going to rain.
jombo is offline Find More Posts by jombo
Old Mar 15, 2011, 12:40 PM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Yeh i have two of these. Havent really used them much yet but seem alright.
ghost2212 is offline Find More Posts by ghost2212
Old Mar 15, 2011, 03:03 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
yeah the gold is horrible. just the black is good. If you want something real easy on the eye some say the fluro tail, fluro skids and flashy stickers on the blades help. i think i got too many blue helis as it is. copterx has stuck with the blue look since day one. i've got blue helis to build as spare, but i got too many already as it is.
Old Mar 15, 2011, 04:42 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
you know what would be good jombo, deanodizing i'm thinking of doing that later on to some of my blue helis.
Tutorial: De-anodizing Aluminum on your RC Car (7 min 38 sec)
Old Mar 15, 2011, 06:53 PM
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Ok I have a question
Where do you get the spacers that go between the blade grip bearing and the rubber damper?
They donít come with the feathering shafts and do not come separate; I have checked the CopterX and Hobby king and looks like you can only get them with the blade grips.
found a washer to get by.
Well my 250 just past test flight
Old Mar 15, 2011, 07:21 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
aslong as the dimensions are the same
http://cgi.ebay.com.au/Feathering-Sh...item45f93280d5
Old Mar 15, 2011, 07:27 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
copterx has stuck with the blue look since day one. i've got blue helis to build as spare, but i got too many already as it is.]
See i have the opposite , mine are all black or grey , the blue makes it stand out from the crowd .
Old Mar 15, 2011, 07:37 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
to deanodize the parts ,people have used easy off oven cleaner. i never tryed it but i hear it works. same as the video, put it in something and spray it on , let it sit for a while and it should come off .
Old Mar 15, 2011, 07:45 PM
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Feathering shafts, the screws with washers but again without the spacer.
Align
25H023 spacer 25X4.5X0.2MM
Old Mar 15, 2011, 08:07 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
Align
ahh you want the spacer. i thought you meant the washer. my bad.
http://www.completeheli.com/index.ph...rv85ij9svh55v5
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 02:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 11:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 06:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 02:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 09:54 PM
