Old Oct 12, 2009, 06:31 PM
tornadorc is offline
Find More Posts by tornadorc
Frequent Flyer
tornadorc's Avatar
Australia, Melbourne
Joined Jun 2009
superkool Hal, good job. Specs sheet?
Cyclic Servos:
Tail Servo:
Gyro:
ESC:
Motor:
Pinion:
RX:
Battery:
Mods:?
Thank you
Paul
tornadorc is offline Find More Posts by tornadorc
Old Oct 12, 2009, 06:33 PM
Hal_The_Hacker is offline
Find More Posts by Hal_The_Hacker
I Can Fly An FP Inverted!
Hal_The_Hacker's Avatar
Teddington, Middlesex, UK
Joined Jun 2008
Cyclic Servos:
Tail Servo:
Gyro:
ESC:
Motor:
Pinion:
RX:
Battery:
Mods:?
Thank you
Paul
I listed the mods in my build review, here are the rest of the specs you requested:
HXT500s
hyperion DS09GMD
logictech 2100t
skyartec 18A esc (was lying around)
HDX300 motor - 3500kv
15t pinion
AR6110
Desire Power 3s800 22C
Hal_The_Hacker is offline Find More Posts by Hal_The_Hacker
Old Oct 12, 2009, 06:35 PM
GeneR is offline
Find More Posts by GeneR
Lake City, PA USA
Joined Sep 1999
Well,
The wind died down to 5 this evening so I took my plastic kit out for the maiden flight. A quick check of the controls and she jumped of the ground and settled into a rock-steady 3 foot hover. Three clicks on the tail and I shot around for a dozen circuits to check out the trim. I will need to tweak the linkages later but it flies wonderfully. Very nice, smooth flyer. Note I never wanted a 3d machine but just something to fly around the backyard and it is clear this will fill the bill nicely. I could not be more pleased.
Setup:
HK250 base plastic kit, all stock
3 HTX900 on cyclic
1 Spektrum programmable 6g digital servo on the tail (in tail mode)
E-Flite 11g gyro
Turnigy 25amp ESC
Turnigy 2623 3000kv motor
Spektrum AR6100E rx
Turnigy 800mah 3 cell batt
Gene
GeneR is offline Find More Posts by GeneR
Old Oct 12, 2009, 07:34 PM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Hal, on the GT, what did you do about the main blade grip bearings? Did you do anything with the tail pitch arm? What was wrong with the washout base? Too much play where the pins are?
Evan D is online now Find More Posts by Evan D
Old Oct 12, 2009, 11:55 PM
mekaone is offline
Find More Posts by mekaone
Joined May 2009
Has anyone mounted a G401B to the HK250GT yet?
I am asking because I didn't know if it would be to big to fit on the 250GT and I am about ready to purchase one. Thanks all :-)
Eric
mekaone is offline Find More Posts by mekaone
Old Oct 13, 2009, 06:10 AM
deanc338 is offline
Find More Posts by deanc338
Shut up and talk to me!!
Manila
Joined Aug 2006
+1 on the G401B....
deanc338 is offline Find More Posts by deanc338
Old Oct 13, 2009, 07:20 AM
Frequent Flyer
tornadorc's Avatar
Joined Jun 2009
the 401b is still good to use. it's a bit big, but if it really bothers you, strip it, is the other alternative
Old Oct 13, 2009, 07:59 AM
beer-man is offline
Find More Posts by beer-man
USA, NY, Syracuse
Joined May 2005
Hey, what size bearing are in the grips? I'm thinking of getting an order ready for VXB bearing. thanks.
beer-man is offline Find More Posts by beer-man
Old Oct 13, 2009, 08:38 AM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
The grip ones are 2.5mm inner diameter, 6mm outer diameter, 2.6mm thick.
You'll also want the seesaw bearings as two of them are bushings, 1.5x4x1.2.
Old Oct 13, 2009, 12:33 PM
Joined Jun 2008
I replaced the blade grip bearings with ones from my plastic kit.
tail pitch arm seems fine, the plastic kit's one has a lot less slop so I may swap it out at some point.
the hole in the center of the washout base was too large for the mainshaft, so it wobbled around a bit, and it gave me pitch fluctiations, made circuits really hard.
Old Oct 13, 2009, 01:00 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
It was nice to have the plastic kit for spares then...
My washput base is not wobbly at all. I have bearings, blades, and a tail pitch arm on it's way....
Old Oct 13, 2009, 01:02 PM
Joined Jun 2008
yeah it is nice to have the plastic kit for spares, I will replace the bushings in the seesaw with the bearings from the plastic kit later on today as well
Old Oct 13, 2009, 02:38 PM
Joined Jun 2008
Just posted my 250GT flight log/review in post six:
http://www.rcgroups.com/forums/showp...68&postcount=6
Old Oct 13, 2009, 03:07 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
So did you fly it with the wrong bearings in the grips? Or did you fix that before the first flight?
I have to think it'll be tough since it has low mass and high stregnth components.
Old Oct 13, 2009, 03:22 PM
Joined Jun 2008
no i fixed that before my first flight as detailed in my build log
and actually this does seem surprisingly tough, i was half expecting everything to be totally bent because of cheap materials
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
