Old Feb 02, 2011, 03:57 PM
heniochus is offline
Find More Posts by heniochus
NW, US
Joined Mar 2007
Originally Posted by bwoollia View Post
The 401B mod is here.
Thanks, bwoollia. Just in time. I've got a couple "damaged" 401b laying around. One was when I installed it on the 250, its case was actually touching the heli frame, and after a test run the "rev" no longer works (it doesn't reverse direction any more. I was switching servos, some swing in opposite direction). So I filed down frame around that area a little bit and glued in some foam as cushion, and put in a new gyro. When I told a guy in the field he felt strange. He said a gyro doesn't usually get damaged that way. Now I think it must be a wire inside got loose. I will check it out tonight.
heniochus is offline Find More Posts by heniochus
Old Feb 03, 2011, 08:09 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Got some more winter flying in - this time it was much milder than the first attempt at winter flying, so I had a bit more success. I think I need to dial my gyro back in, I've tightened everything up so I should probably be able to kick up the gain a click or two, might help to straighten my loops out.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Feb 03, 2011, 10:59 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
i could hear the wind in the back ground, what was the windspeed?
pitchp is offline Find More Posts by pitchp
Old Feb 04, 2011, 10:09 AM
ghost2212 is online now
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Nearly There
Nearly Done. The ESC i bought is supposed to have a 15 second startup but as it came with no instructions and i cant find any on the internet i wont be able to use that :/
The turnigy 3800kv motor pinions are not the right pitch for the main gear so i am using the one from the kit which is meant for a 2.5mm shaft on the 2.3mm shaft with red loctite. Will have to see how it holds
ghost2212 is online now Find More Posts by ghost2212
Old Feb 04, 2011, 10:57 AM
Firefox675 is offline
Find More Posts by Firefox675
Firefox
Firefox675's Avatar
USA, KS
Joined Oct 2005
Are these the motors to use on the 250 ?
http://www.hobbyking.com/hobbyking/s...idProduct=9223
FF200 Brushless Outrunner 5000kv
http://www.hobbyking.com/hobbyking/s...idProduct=8501
Dimension: 24mm x 26mm, 37mm(with shaft)
Weight: 29g (kv4500) (not including connectors)
Diameter of shaft:�F2.4mm
Length of front shaft:�F12.8mm
Lamination thickness: .2mm
Magnet type: 45SH
Max performance;
Voltage: 2S
Max current: 10A/20S
For 200g size helicopter.
Firefox675 is offline Find More Posts by Firefox675
Old Feb 04, 2011, 12:03 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
I would go for something slightly larger than either of those. The Turnigy 2627 series work well, both the 3800kv and the 4200kv versions are suitable - select a pinion for your desired headspeed.
It appears the 4200kv is out of stock but the 3800kv one is in. The pinion that comes with the kit is the wrong size (too large? can't remember) so you'll have to order one. The ones that fit don't have a grub screw, you can secure them with red loctite. Also, the shaft will have to be cut short, it's too long out of the box.
http://www.hobbyking.com/hobbyking/s...idProduct=8144
http://www.hobbyking.com/hobbyking/s...idProduct=8143
Here's a good pinion that should provide about 4200rpm-ish on 3S with the 3800kv motor:
http://www.hobbyking.com/hobbyking/s...idProduct=9254
Site Sponsor
Old Feb 04, 2011, 12:08 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
About 10mph.
Site Sponsor
Old Feb 04, 2011, 02:50 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
nice
Old Feb 04, 2011, 03:07 PM
Skint since 2000
ghost2212's Avatar
Joined Oct 2008
2.3mm shaft pinion
Anyone know where to get a 2.3mm pinion for the turnigy 3800kv motor apart from hobbyking? . It tried to use the 2.5mm pinion but as it was off centre it just destroyed the main gear and now i cant maiden my heli. Iw really dont want to have to wait for ages to be able to fly it.
Brett
Old Feb 04, 2011, 03:28 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
I use these
Note this is a 15T. make sure you select the appropriate size for the desired HS.
http://hobbyking.com/hobbyking/store...idProduct=9255
i also use the green threadlock for these. I haven't had one come off. I've tested it on almost 6K HS.
Old Feb 04, 2011, 03:40 PM
Skint since 2000
ghost2212's Avatar
Joined Oct 2008
I use these
Is there anywhere to get one apart from hobbyking. Seeing as its Chinese New Year it will probably take 2 weeks to ship
Old Feb 04, 2011, 04:04 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Couple of my usual stores.
Rotorquest: https://www.rotorquest.com/advanced_...+2.3mm&x=0&y=0
Readyheli: http://www.readyheli.com/search.asp?...d=pinion+2.3mm
Site Sponsor
Old Feb 04, 2011, 04:34 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
i use the mod .4 that works for me. i don't know if mod .5 would work?
Old Feb 04, 2011, 06:48 PM
NW, US
Joined Mar 2007
Brett
Aside from HC my frequent store would be helidirect.com. I got both the 3800kv and the 4200kv from HC, using 13T and 12T respectively. I am not yet advanced enough of a pilot to tell the differences.
You may also try ebay. It's amazing, some folks from overseas would make a sale for only a few bucks (i.e. free shipping). I got a bunch of esky king main drives for 99 cents apiece (shipped). I have no idea how they make any money out of it.
Old Feb 05, 2011, 12:46 AM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Okay, last video of me flying over the snow. It's supposed to drop back down to -15 and colder next week again. Stupid prairies.
Site Sponsor
Discussion Official HeliMax AXE CP Thread with pics post em here!!?.. darklyte24 Micro Helis 10606 Nov 19, 2015 01:32 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Discussion Build log or review for BulleT? raycsr Electric Sailplanes 3 Jan 30, 2009 01:03 PM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
