Old Nov 30, 2011, 01:37 PM
old p47 is offline
Find More Posts by old p47
Joined Nov 2002
Andy I had an early 11x DSM2 and had a repair over the summer they upgraded it to DSMX. I have bought several DSMX receivers and still have several planes on the radio that are DSM2 receivers. When I bind to a new DSMX receiver or to a old DSM2 receiver it does not show the difference. And is the DSMX upgraded have the 11ms speed?
old p47 is offline Find More Posts by old p47
Old Nov 30, 2011, 05:14 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
I stand to be corrected; but I thought the speed and resolution also required an Rx with the correct specs.
DavidN is offline Find More Posts by DavidN
Old Nov 30, 2011, 05:21 PM
old p47 is offline
Joined Nov 2002
I know they have faster rx for the DX7 but I thought the DSMX would go to the 11ms and was backward compatible with the slower DSM2 receivers
Old Dec 01, 2011, 06:34 AM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
JR aren't offering a DSMX upgrade for Europe yet. It's not clear if they ever will. I'm not really bothered though. I bought mine to use with indoor DSM2 planes. I mostly use 35MHz for outdoor planes. If Horizon Hobbies / Parkzone / E-Flite start selling DSMX equipped ultra micro planes, it would be more useful to me, but DSMX is supposed to be backwards compatible with DSM2 anyway. You can't really get enough people flying in a sports hall to cause problems with DSM2.
Andy2No is offline Find More Posts by Andy2No
Old Dec 01, 2011, 06:43 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I backed up my SD card to my PC and I see it says this at the start of every model memory file:
¥JR PROPO¥11X ZERO
- So the DSX11 thinks it's an 11x Zero. I can see the difference between the Zero and the non modular versions, but I don't know what the difference is between the DSX11 and the 11x.
Old Dec 01, 2011, 07:14 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
And now I do! I decided to email MacGregor (the UK distributor) and I've had a reply already:
Dear Sir,
The JR 11X (Not CE Legal) is the US equivalent of the DSX11 and the
11X-Zero is a modular version of the DSX11.
http://www.macgregor.co.uk/jrpropo/dsx11.htm
Regards
Modeller Support
So, what I have is an 11x, just an EU legal version (we have to have a lower power output than in the US).
Old Dec 01, 2011, 03:50 PM
theaton56 is offline
Find More Posts by theaton56
United Kingdom, Slough
Joined Aug 2003
To be totally honest, there is little difference to the modular and non-modular systems. On the so called "non-modular" system, if you strip it down and remove the RF interface pcb, you will find the exact same RF pcb that is found in the modular system.
theaton56 is offline Find More Posts by theaton56
Old Dec 01, 2011, 07:57 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Thanks, theaton56. That's good to know. Is the RF board soldered on, or in a socket?
I've fitted a FrSky 2.4GHz module to the back of one of my 35MHz Futaba FF6's, which isn't modular, and it was pretty simple to do, so I figured I'd probably be able to something similar with the DSX11 if I ever needed to in the future. The 11x Zero was about £100 dearer ($160 or so) and I specifically wanted DSM2, so I didn't feel like paying the extra.
Old Dec 02, 2011, 04:32 AM
johncoulouris is offline
Find More Posts by johncoulouris
Ελλάδα, Δυτική Ελλάδα, Πάτρα
Joined Jun 2009
how many flight conditions does the jr 11x has? Is the throttle trim digital in the US version?
thanks ,
john
johncoulouris is offline Find More Posts by johncoulouris
Old Dec 02, 2011, 07:25 AM
Nettraptor is offline
Find More Posts by Nettraptor
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
John IMHO dont go with the us version because of the dsmx , and dms2
Go straight to JR 11X ZERO because of the interchangeable module.. and superior DSMJ frequensy hoping system.
also beware that it will be released soon this module for 9X, 10X and 11Xzero sets
https://rcjapan.net/index.php?main_p...ducts_id=11927
i use the FRSKY for FPV though , and DSMJ for my MK
Nettraptor is offline Find More Posts by Nettraptor
Old Dec 02, 2011, 07:31 AM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
There are six flight modes for helicopters, five for gliders and three for planes.
I can't answer about the throttle trim, sorry.
Old Dec 02, 2011, 12:54 PM
AWorrest is offline
Find More Posts by AWorrest
Lincoln, NE
Joined May 2005
thanks ,
john
The JR 11X2.4 sold in the US has analog throttle trim. But of greater concern should be is the US version legal where you are located and also can you get it serviced if needed? The US version does differ from the versions sold elsewhere in its programming. Most notably the GLID mode. Personnally I think the US GLID is better.
Allan
AWorrest is offline Find More Posts by AWorrest
Old Dec 02, 2011, 01:03 PM
HaventFlownSince2014 is online now
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Allan, I have a few 11x questions but they do not relate to sailplanes. I do not know anyone with more knowledge of this radio than you; could you tell me how you would set up your radio for a giant scale gasser?
Specifically, my goals are to program a 4 servo wing (2 ail, 2 flaps) and I was hoping to plug each servo into a separate channel on my rx, but I also want to be able to match the two flap servos together [even though they operate separately on the full scale].
I am also running one servo for each elevator half and would also like to put them on separate channels and also ensure they are matched in synchronization with each other.
How would I go about this?
HaventFlownSince2014 is online now Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Dec 02, 2011, 01:36 PM
AWorrest is offline
Lincoln, NE
Joined May 2005
The ACRO programming for what you want is straight forward. It will require a receiver with seven or more channels. Start with a cleared memory slot. Select ACRO type. When asked for wing type, select NORMAL. Next when asked about DUAL-AILE, select GEAR. Make your choice about having a V-tail or not. Then go to the WING TYPE menu on the System List and under FLAP select AUX2. If you have a receiver with more than seven channels then the mated channels to aileron and flap can be other than what I listed.
Allan
Old Dec 02, 2011, 01:40 PM
USA, GA, Atlanta
Joined Nov 2008
Thanks Allan! I will get on it when I get off work; it sounds pretty easy
I will be using a total of 10 servos (2 ail, 2 flap, 2 ele, rudder, tail wheel, throttle, choke) and likely using a 9ch rx so I may have to use a Y somewhere in there...
New JR receiver sent in for repair 12+ BD turnaround. sa-10 Fuel Plane Talk 6 Sep 29, 2002 03:38 PM
New Jr Batt, New Jr Servos, Hitec Rx W/xtl, Electronic Mixer saint152 Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2002 01:26 PM
New JR X-378 Radio wayne Electric Heli Talk 0 Nov 05, 2001 12:10 PM
Brand New JR ERGO 60 Sport Jim McPherson Aircraft - Electric - Airplanes (FS/W) 1 Oct 14, 2001 09:00 AM
Brand New JR ERGO 60 Sport Jim McPherson Aircraft - Electric - Helis (FS/W) 0 Oct 13, 2001 05:52 PM
