Old Oct 17, 2011, 09:20 AM
Tadango is offline
Find More Posts by Tadango
Joined Nov 2004
See my answer above It was the answer i received from a UK reseller. Maybe in the USA the DSMX upgrade will be availabe and in the UK and EU a DMSS upgrade. I would really like a DSMX upgrade to, i have some DSXM receivers......
Tadango is offline Find More Posts by Tadango
Old Oct 17, 2011, 09:50 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Sorry, I am a little behind on the technology so thank your for clarifying it may be a EU/UK issue.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Oct 17, 2011, 12:51 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by ditchit View Post
Can the DSM2 version of the 11X be upgraded to DSMX?
Yes!
http://www.horizonhobby.com/Products...odID=JRP11XUPG
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 17, 2011, 01:21 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
You could try contacting Horizon Hobby. If it doesn't violate an agreement with Spectrum, they might accommodate you.
DavidN is offline Find More Posts by DavidN
Old Oct 17, 2011, 05:50 PM
theaton56 is offline
Find More Posts by theaton56
United Kingdom, Slough
Joined Aug 2003
Ok.... here in the Uk we are stuck with DSM2.
Horizon owns Spektrum and in the USA, Horizon are also the JR dealers (for the time being). This means that they can use their own technology (DSMX) to upgrade their JR supplied DSM2 systems.
Anywhere else where Horizon IS NOT the JR distributor, there is a problem. As JR does not have rights to use the DSMX, they cannot provide an upgrade path for the DSM2 systems that they used to sell.
In the UK we have a JR distributor AND a Horizon Hobbies distributor, BUT... Horizon are not allowed to touch JR radios (as they are NOT the distributor in the UK) and the official JR distributor cannot get the upgrade as they are not a Spektrum dealership.
As you may (or may not know) JR have released their own system (now that they are allowed to) and have in their stables... the XG6, XG7, XG8 and the XG11. (the 6 and 11 have just been shown to the public for the 1st time over in Japan).
Hopefully they will release an upgrade path for the DSX11 / 11X and then the 9X/9XII in due course. (Wishful thinking on my part )
Time will tell.
theaton56 is offline Find More Posts by theaton56
Old Oct 18, 2011, 06:21 AM
JazzMan2001 is offline
Find More Posts by JazzMan2001
JazzMan2001's Avatar
Hampshire, United Kingdom
Joined May 2009
As I understand it the JR upgrade is not backwards compatible but the Spektrum DSMX is?
JazzMan2001 is offline Find More Posts by JazzMan2001
Old Oct 18, 2011, 07:55 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
DMSS is not compatible with DSM2.
DSMX is compatible forwards and backwards with DSM2.
Andy
Site Sponsor
Old Oct 18, 2011, 10:09 AM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Mine also was DSM2 upgraded to DSMX and it works just fine with both DSMX and DSM2 recievers.
SZD16 is offline Find More Posts by SZD16
Old Oct 18, 2011, 12:02 PM
Joined May 2009
Being a UK resident DMSS is my only choice for my DSX11. Seeing as I have several micros running Spektrum 6400's, an MSR and an assortment of RX's I'll be sticking to DSM2. I don't think that's a major issue reading up on the tech as I'm never going to be at a location with more than 4 or 5 TX's in use at one time possibly a max of 8.
Old Oct 18, 2011, 12:10 PM
USA, GA, Atlanta
Joined Nov 2008
Time will tell.
Thank you for the thorough answer and information.
Old Oct 18, 2011, 01:18 PM
Joined Aug 2003
No problem.....
Old Nov 29, 2011, 05:12 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
There doesn't seem to be an actual JR DSX11 thread, but I gather there's only a few differences between the DSX11 and the 11X, so I thought I'd ask a few questions here.
I've just bought a DSX11 (UK version, mode 2) and it has firmware version 0001-0002. Is there a newer firmware I should put on it? I can't find anything relevant on the MacGregor site (UK distributor), JRRadios.com doesn't even mention the existence of the DSX11 and www.jrpropo.co.jp/english/ doesn't help much either, as far as I can see.
I gather there's a certain folder structure I need to make on an SD card to use it with the DSX11. I found out about making a folder called JR and one inside that called VERUP to put firmware updates in. What about the saved model memories? Is the folder for those created when I first save one, or do I have to make it myself?
Andy2No is offline Find More Posts by Andy2No
Old Nov 29, 2011, 05:20 PM
Joined Aug 2003
Andy,
Whatever you do ... do not attempt to load a new version of firmware unless it states that it is for your particular NET code (as shown on front panel).
Failure to load the correct version will result in the DSX11 becoming a big shiny paperweight.
Old Nov 29, 2011, 05:33 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Thanks. I'd guessed that I just thought there may be some DSX11 users lurking in this thread.
I'm sure the SD card folders structure would be the same for all similar models (second question).
Old Nov 29, 2011, 05:35 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Model memories folder
Okay. Found it:
Originally Posted by HankSchorz View Post
Slight correction since I made a slight mistake (this has nothing to do with the upgrade). The folder structure for the model files is \JR\MODEL instead of \JR\MODELS.
So it should contain the following:
\JR\MODEL - This contains any model files you saved to the SD Card
\JR\VERUP - This contains any firmwar upgrade files you download
Is it okay to keep other things on the SD card, provided they're not in the JR folder? E.g. text files with notes, and PDF manuals would be useful to carry with me (Yes, I realise the transmitter can't display them I have other gadgets that can though, and a couple of cheap pocket USB card readers).
New JR receiver sent in for repair 12+ BD turnaround. sa-10 Fuel Plane Talk 6 Sep 29, 2002 02:38 PM
New Jr Batt, New Jr Servos, Hitec Rx W/xtl, Electronic Mixer saint152 Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2002 12:26 PM
New JR X-378 Radio wayne Electric Heli Talk 0 Nov 05, 2001 11:10 AM
Brand New JR ERGO 60 Sport Jim McPherson Aircraft - Electric - Airplanes (FS/W) 1 Oct 14, 2001 08:00 AM
Brand New JR ERGO 60 Sport Jim McPherson Aircraft - Electric - Helis (FS/W) 0 Oct 13, 2001 04:52 PM
