Old Oct 06, 2009, 10:37 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Who says you can only have one SD card?
Leave the data for your models on multiple SD cards and when you want to fly one, put in the card that has the data.
Fly2High is offline Find More Posts by Fly2High
Old Oct 06, 2009, 01:52 PM
DannyZRC is offline
Find More Posts by DannyZRC
USA, CA, Merced
Joined Dec 2007
well, in my argument I said plenty of models, and I thought 50 was plenty.
but there's nothing saying that it couldn't be 100, or 1,000, or 10,000.
there's a crossover, below which it's cheaper to put the memory into the transmitter than it is to put an SD card reader into the transmitter. I imagine it's probably well over 500 models worth of memory (250megs~)
updating firmware over usb is just as feasible as through a card slot.
I mean, more model memories and firmware upgradeability is fine, and if they achieve it through an SD card, so be it. I just disagree that it's the best way.
DannyZRC is offline Find More Posts by DannyZRC
Old Oct 07, 2009, 06:41 AM
Roryw is offline
Find More Posts by Roryw
Rory
Roryw's Avatar
Australia, Belrose
Joined Aug 2005
Check this out
I was able to get this
Roryw is offline Find More Posts by Roryw
Old Oct 07, 2009, 06:47 AM
Roryw is offline
Rory
Roryw's Avatar
Australia, Belrose
Joined Aug 2005
More
More pics
Old Oct 07, 2009, 06:54 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Uh Oh! The Cylons are getting angry
p.s. Thanks for the cool pics
kgfly is offline Find More Posts by kgfly
Old Oct 07, 2009, 06:55 AM
Roryw is offline
Rory
Roryw's Avatar
Australia, Belrose
Joined Aug 2005
● Saboribasu
● trim sub
● Program MIX: 6 lines /
Curved lines in selectable MIX3 (EXP with)
● Model Name: up to 10 characters
● failsafe
● System Trainer: Type 2 can be selected
● Select the device (with Tatchiserekuto)
● SD card slot
● Sutikkupojishonsuitchi
Right rudder adjustment ●
● Adobansudejitarutorimu: F.M. every
● Step Trim / Trim Type
● DSC / Trainer Jack
● Furaitomodonemu: Up to 6 characters
● Various alarm timer: 3 channels
● Switch Type: 3 selectable types
● 4 grayscale LCD with backlight
My list features ●
● Monitor mixing
● D / R &: EXP: 2 Division: F.M. every
● Speed Servo: 2 split
Stick with tension adjustment ●
● Switch Model: copy: 30 minutes Machine
● Detairezu
● Servo Monitor: With the test function
● Copy data (TX in)
(TX ← → TX) (TX ← → SD)
● adjust limit
● Simple configuration features
● Hold Servo All
※ ※ FM every new feature red letters ... each flight mode
Helicopter Functions
● Flight mode: Up to 6 lines
● curved tail: 5 strains
Multipoint (EXP with)
● MIX throttle
● Setting the governor: F.M. every
● Throttle curve: up to 5 lines
● Hold the throttle: with auto-cut
● Suwasshutaipu: 6 types (140 compatible)
● Furaitomododirei
● Pitch curve: up to 6 lines
● Gyro sensitivity setting: sensitivity up to 6 lines /
GAIN tail lock system up to 6
With Jairogeindirei
(G7000T only)
Feature plane
● Flight mode: Up to 3 lines
● AILE → RUDD MIX
● AILE → FLAP MIX
● wing type setting: with differential
● Throttle curve: two strains
● Hold the throttle (when the twin-engine configuration)
● ELEV → FLAP MIX
● flap system (direct input)
● Aidoruajasutomento
● curve pitch: 2 strains
● Gyro sensitivity setting: Up to 3 lines / with delay
● RUDD → AILE / ELEV MIX
● Sunappuroru: four independent lines
Glider features
● Flight mode: up to 5 lines
● RUDD → SPOI MIX: F.M. every
● AILE → RUDD MIX
● Furaitomododirei
● Brake System
● ELEV → CAMB MIX: F.M. every
● Purapperon MIX: F.M. per /
With Furappurebaofusetto
● Motahorudo (with delay)
● AILE → RUDD MIX:
F.M. each (with breaks)
● Rate flap: F.M. every
● Type Wing
set & price
12ch Receiver RD1231 No.03420
RD1231 price alone
34,650 yen (including tax 33,000)
● Ekusutoraantena: EA131 3
● Antenna cable:
230/300/450mm (each book)
● Baindopuragu
9ch receiver RD931 No.03419
RD1231 price alone
29,400 yen (including tax 28,000)
● Ekusutoraantena: EA131 2
● Antenna cable:
230/300mm (each bottle)
● Baindopuragu
RD1231_12chset for air DSMJ method: Set the receiver for airplanes 12ch
No.00917/P11ADTR 88,200 yen (including tax 84,000)
Method for heli DSMJ: receiver set for helicopter 12ch
No.00918/P11HDTR 88,200 yen (including tax 84,000)
RD1231_12chset for air DSMJ method: Set the receiver for airplanes 9ch
No.00915/P11ADTRL 84,000 yen (80,000 yen including tax)
Method for heli DSMJ: receiver set for helicopter 9ch
No.00916/P11ADTRL 84,000 yen (80,000 yen including tax)
Common content set [all] ● TX power accessories: 8H1500 ● Charger: NEC-501C
Old Oct 07, 2009, 06:57 AM
Roryw is offline
Rory
Roryw's Avatar
Australia, Belrose
Joined Aug 2005
Cost is about $990 US including receiver which is about $1,100 AUD
Old Oct 07, 2009, 07:17 AM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
I am not sure if I like the sliders on the back. I got so use to them being on the sides on the XP9303
Is the 12X and 10X this way?
Old Oct 07, 2009, 08:16 AM
gquiring is offline
Find More Posts by gquiring
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
I love my JR 9303 but this 11x is UGLY. It reminds me of a future Sci-FI Pontiac grill! Glad to see JR is going to use SD cards, it's about time.
gquiring is offline Find More Posts by gquiring
Old Oct 07, 2009, 09:38 AM
g_mkoch is offline
Find More Posts by g_mkoch
Joined Aug 2009
After looking at the prices makes me think this system is set out to compete with the Futaba 12FG at about $900
g_mkoch is offline Find More Posts by g_mkoch
Old Oct 07, 2009, 09:57 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Hmm... wonder where they got the styling cues...
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Oct 07, 2009, 10:07 AM
DougV is online now
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
They already have the 12X competing with the 12FG.
Doug.
DougV is online now Find More Posts by DougV
Old Oct 07, 2009, 04:49 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
A few points of note:
1. those sliders on the back -- just waiting to be knocked when putting the radio down.
2. why oh why do they still have a plug-in module for the 2.4GHz circuitry? Surely we're getting close to the point where people want/demand dedicated 2.4Ghz radios with no legacy compromises?
3. it looks as if (based on the LCD voltage readout) it still uses a 8-cell NiMH pack. Once again -- why are they "so last century" in their thinking? With a 2.4GHz module this almost certainly means most of the battery power will be wasted as heat. Why not a 2S lithium pack? Oh, that's right, sticking with the old FM legacy (boo!).
4. Styling is "love it or hate it". I'm torn. I do like the much cleaner lines without all the little crevises, nooks and crannies that are just a PITA to clean but it does look like a design that will date *very* quickly. Contemporary today, so "last year" tomorrow.
5. No indication of resolution (or did I miss that). Is it 1024 or 2048?
For the price?
I'll stick with my JR9X/II for now.
XJet is offline Find More Posts by XJet
Old Oct 07, 2009, 05:14 PM
g_mkoch is offline
Joined Aug 2009
Doug.
At $1500 the 12X is more competition to the 12Z than the 12FG
Old Oct 07, 2009, 05:22 PM
DougV is online now
DougV's Avatar
Joined Dec 2007
Maybe in price, but not in programming. The 12Z has the 14MZ programming, I will compare the 12X to the 12FG, even then is a close call.
I own the 12FG and I have setup some airplanes with the 12X.
JMO,
Doug.
New JR receiver sent in for repair 12+ BD turnaround. sa-10 Fuel Plane Talk 6 Sep 29, 2002 02:38 PM
New Jr Batt, New Jr Servos, Hitec Rx W/xtl, Electronic Mixer saint152 Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2002 12:26 PM
New JR X-378 Radio wayne Electric Heli Talk 0 Nov 05, 2001 11:10 AM
Brand New JR ERGO 60 Sport Jim McPherson Aircraft - Electric - Airplanes (FS/W) 1 Oct 14, 2001 08:00 AM
Brand New JR ERGO 60 Sport Jim McPherson Aircraft - Electric - Helis (FS/W) 0 Oct 13, 2001 04:52 PM
