Old Oct 02, 2009, 11:03 AM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
United States, FL, Ponce De Leon
Joined Nov 2005
Parkzone Micro Mustang TX Setups, Tweaks, Mods Tips, and Upgrades (work in progress)
Here we go again, be patient as I gather the info as these planes start to make it out into the world.
I will eventually edit this into a cohesive posting, but for now I am collecting the data.
Please feel free to add to this, I will just edit it back into this post.
Manuals
RTF Manual
http://www.horizonhobby.com/ProdInfo...600-Manual.pdf
BNF Manual
http://www.horizonhobby.com/ProdInfo...680-Manual.pdf
Parts Listing
From the Parkzone Website
http://www.parkzone.com/Products/Rel...g&SubCategory=
Radio Settings
DX7
DX6i
LP5DSM/HP6DSM
Radio Mods
Bob K's Stick Extensions for the RTF package TX
http://www.rcgroups.com/forums/showp...56&postcount=1
Battery
Boidster's List Of Battery Options
http://www.rcgroups.com/forums/showp...&postcount=962
turboparker's Test Results
http://www.rcgroups.com/forums/showp...postcount=1491
Daedalus66's Description and Tip on LVG (Low Voltage Cutoff)
http://www.rcgroups.com/forums/showp...postcount=3752
Batery ratings explained by 9sec240
http://www.rcgroups.com/forums/showp...&postcount=931
HobbyCity/HobbyKing Flight Max Battery
http://www.hobbycity.com/hobbycity/s...idProduct=8864
RCBABBEL'S Velcro For The Batteries Suggestion.
http://www.rcgroups.com/forums/showp...&postcount=957
Doug Sipprell's Cold weather flying tip, how to warm the batteries.
http://www.rcgroups.com/forums/showp...postcount=2053
ronht's Battery mod for oversized lipos.
http://www.rcgroups.com/forums/showp...postcount=4471
RCBABBEL's battery mods
Part 1
http://www.rcgroups.com/forums/showt...r#post13012360
Part 2
http://www.rcgroups.com/forums/showp...postcount=1127
ODUsurfer's double battery mod
http://www.rcgroups.com/forums/showp...&postcount=170
Battery connection
http://www.rcgroups.com/forums/showp...postcount=1952
http://www.rcgroups.com/forums/showp...&postcount=728
Custom batteries for sale!
http://www.rcgroups.com/forums/showp...&postcount=643
Charger
Charger Mods
A whole thread, started by modfly
http://www.rcgroups.com/forums/showthread.php?t=1108545
TheSteve's AA Mod
http://www.rcgroups.com/forums/showp...postcount=1317
melcrose's AA Non-mod Mod
http://www.rcgroups.com/forums/showp...postcount=1435
Proppellers
bluefisherking's Prop Comparison
http://www.rcgroups.com/forums/showp...&postcount=591
modfly's Test Of The GWS 4530 prop
http://www.rcgroups.com/forums/showp...&postcount=956
motor
*Dave Eichstedt's Comments On The Pulsing Motor Problems.
http://www.rcgroups.com/forums/showp...&postcount=129
Chompers motor problems (or the cat-whisker-brush-lottery problem)
http://www.rcgroups.com/forums/showthread.php?t=1120553
modfly's Motor Timing To Gearbox Mod/Repair
http://www.rcgroups.com/forums/showp...19&postcount=5
Gearbox
modfly's Gearbox Analysis
http://www.rcgroups.com/forums/showp...2&postcount=13
Modfly's Binding Gearbox Video
http://www.rcgroups.com/forums/showp...&postcount=815
Wrathchild's Non Binding Gearbox Video
http://www.rcgroups.com/forums/showp...&postcount=834
Going Brushless
EmmDee's brushless set up
http://www.rcgroups.com/forums/showp...&postcount=202
mitsudriver274's brushless motor/esc
http://www.rcgroups.com/forums/showp...&postcount=207
Wings
Bobber Bob's Split Flap Mod Description
http://www.rcgroups.com/forums/showp...&postcount=149
And Construction Details...
http://www.rcgroups.com/forums/showp...&postcount=158
Dennis A's Posting Of Images Of A Split Flap Mod
http://www.rcgroups.com/forums/showp...&postcount=993
Ailerons
Rudder
Elevator
Servos
Bodies Mods, Scale Details
Mattfly's Custom Body Mod Converted to a P51B
http://www.rcgroups.com/forums/showp...&postcount=510
Pilotrob56's gear door mod
http://www.rcgroups.com/forums/showp...2&postcount=93
Flying Outdoors
Lights
Tiny Brite Lights for Parkzone P51-D
http://www.rcgroups.com/forums/showp...&postcount=985
Specs, Stats, Calculations, and Formulas
http://www.parkzone.com/Products/Def...ProdID=PKZ3680
Specifications
Wingspan: 15.8 in (401mm)
Overall Length: 14.3 in (363mm)
Flying Weight: 1.22 oz (34.6 g)
Motor Size: 8.5mm brushed motor (installed)
Radio: Spektrum AR6400 receiver (installed); transmitter required
Servos: Spektrum 1.5-gram (SPMAS2000)
CG (center of gravity): 35mm from leading edge of wing at the fuselage
Prop Size: 130mm x 70mm
Recommended Battery: 3.7V 120mAh Li-Po (included)
Aileron: Fully proportional
Elevator: Fully proportional
Rudder: Fully proportional
Throttle: Fully proportional
Control Throw (Ailerons): High- 7mm up/down, Low- 5mm up/down
Control Throw (Elevator): High- 7mm up/down, Low- 5mm up/down
Control Throw (Rudder): High- 10mm left/right, Low- 6mm left/right
Charger: DC single-cell Li-Po (included)
Miscelanious
After Market Add On's
Repairs
Reviews/Comparisons
Problems
Tork's Parkzone P51 Issues Poll
http://www.rcgroups.com/forums/showthread.php?t=1121558
P51-C's Stuck Controls Post
http://www.rcgroups.com/forums/showp...&postcount=132
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old Oct 02, 2009, 11:27 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Sub'd..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Oct 02, 2009, 11:51 AM
kenstogie is online now
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Originally Posted by Tram
Sub'd..
Ditto. I love this micro stuff.
kenstogie is online now Find More Posts by kenstogie
Old Oct 02, 2009, 12:08 PM
Joined Nov 2005
Parkzone (and Eflite...) has really gone all out for you snow bound guys this winter.
From the older Parkzone Centurions, through the Vapor and Ember, and now this?
As I mentioned before, I can really see these mustangs bringing pylon racing into the gym. They should be fast enough, yet maneuverable enough, to make it fun.
Plus as Matt showed, they are easily customized.
Looking at the way the top hatch comes off, you can make several different versions, and just switch them out. The A and B ridgeback versions, the bubble top, and the lowered canopy reno racers to name a few.
You guys write about it, I'll link it here.
I can't wait to see what this next flying season produces!
Old Oct 02, 2009, 12:48 PM
ODUsurfer is offline
Find More Posts by ODUsurfer
Fly it like you stole it!
ODUsurfer's Avatar
United States, VA, Purcellville
Joined Aug 2009
Subscribed.
Will post any mods I make once I get it.
ODUsurfer is offline Find More Posts by ODUsurfer
Old Oct 02, 2009, 01:57 PM
Admiral14 is offline
Find More Posts by Admiral14
Full throttle and supersonic!
Admiral14's Avatar
USA, VA, Richmond
Joined Aug 2009
I look forward to seeing mods to the p-51. Maybe someone will paint theirs with the Gunfighter scheme and have a side by side picture of the mini and the biggy.
I love the performance of the Gunfighter too, not to mention this little bird
Admiral14 is offline Find More Posts by Admiral14
Old Oct 04, 2009, 12:42 PM
anti-gravity is offline
Find More Posts by anti-gravity
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
I soo want one
anti-gravity is offline Find More Posts by anti-gravity
Old Oct 05, 2009, 10:49 AM
jakesterama is offline
Find More Posts by jakesterama
Never enough RC time.
jakesterama's Avatar
Joined Aug 2007
OMG just called the local shop (HobbyZone) and they say they have them! Will report back after lunch
jakesterama is offline Find More Posts by jakesterama
Old Oct 05, 2009, 11:10 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
As with the Sukhoi, I am putting on a 240 Mah Hobby King Battery. I just tape it but I am sure a little velcro could be used. It does lose a little aerobatic ability but makes up for it in run time of about 10 mins. Inverted flight is a little bit trickier and loops are too. Here's some video.....
ParkZone P 51d mustang Ultra Micro (2 min 3 sec)
Old Oct 05, 2009, 01:44 PM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I don't know if my elevator pushrod was 'normal' or not. But moving it in on the horn was not going to work as it was already pressing up against the top of the slot in the fus. side.
Before mod:
And after:
Bill Glover is online now Find More Posts by Bill Glover
Old Oct 05, 2009, 02:02 PM
bluefisherking is offline
Find More Posts by bluefisherking
bluefisherking's Avatar
Bray, UK
Joined Aug 2009
Yes, that seems to be normal design/manufacturing flaw - I have the same. Nice work correcting it.
bluefisherking is offline Find More Posts by bluefisherking
Old Oct 05, 2009, 03:37 PM
Joined Aug 2007
I was so excited after picking mine up at lunch I took off an hour early! Got home, bound it to the 6i and set up DR, went outside and it was/is raining
Old Oct 05, 2009, 04:46 PM
Joined Nov 2000
Interesting - thanks.
It's a simple fix. If you carefully grip the main part of the pushrod with thin pliers you can twist the wire end piece out relatively easily, leaving the heatshrink (?) in place on the rod.
Snip off at the right angle bend in wire, bend a new right angle, de-burr the end of the wire, then you can re-insert into the heat shrink. A tiny drop of thin cyano completes the job.
On mine, moving the pushrod in two holes as shown doesn't quite give the specified maximum throw.
Old Oct 05, 2009, 05:32 PM
Wrathchild is offline
Find More Posts by Wrathchild
Just above a newb
Wrathchild's Avatar
Fort Mill, SC
Joined Sep 2007
Here are my settings with a DX6i, works great for me:
D/R & Expo
(low rates)
Aileron 0 65% +20%
Elevator 0 65% +20%
Rudder 0 65% INH
(high rates)
Aileron 1 100% +30%
Elevator 1 100% +30%
Rudder 1 100% INH
Travel adjustments
Throttle 125%
All others 100%
Sub-trim set to get all control surfaces as close to neutral as I can by eye, then I trim it in flight.
Wrathchild is offline Find More Posts by Wrathchild
Old Oct 05, 2009, 05:37 PM
Jay-viator is offline
Find More Posts by Jay-viator
Yea..When mowers fly!
Jay-viator's Avatar
The White House?
Joined Apr 2008
Originally Posted by Bill'y Glover
It's a simple fix. If you carefully grip the main part of the pushrod with thin pliers you can twist the wire end piece out relatively easily, leaving the heatshrink (?) in place on the rod. Snip off at the right angle bend in wire, bend a new right angle, de-burr the end of the wire, then you can re-insert into the heat shrink. A tiny drop of thin cyano completes the job.
Try one of these collars...
They work great for connecting\adjusting servo rods.
No cyano\heatshrink required.
Jay-viator is offline Find More Posts by Jay-viator
Discussion mSR TX Setups, Tweaks, Mods Tips, and Upgrades (a work in progress) Flying-Monkey Micro Helis 1143 Feb 26, 2014 03:40 AM
Discussion Bill Lowe's 9 inch Micro Mustang For Parkzone. edoc Scratchbuilt Indoor and Micro Models 330 Jun 28, 2009 10:19 AM
Discussion official parkzone micro citabria mods page. raptorddd Scratchbuilt Indoor and Micro Models 0 Feb 20, 2009 02:10 AM
Discussion tandem,micro,trico z mods, tips, hacks, and reviews dill Micro Ready-to-Fly 78 Feb 01, 2009 01:46 PM
Found Tx for ParkZone Micro Cessna 210 Big Fran Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 11, 2008 09:23 PM
