Old Oct 02, 2009, 10:04 AM
darthdrk is offline
Find More Posts by darthdrk
My hobby is why Im broke
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
Resurrection Jet Ranger body
Resurrection Jet Ranger body. I got a request if I had anything to fit a 500 size heli and i wasnt really sure if I did or didnt. I was given a few specs and I begin to dig thru my stash. I came up with an old Corona fuselage I make and from the specs given, should fit the 500 size heli. I do have plans on also fitting one of my 450 size helis inside of this fuselage which shouldnt be a problem at all. May even be able to get a front cockpit inside. (Good thing I didnt toss the moulds) For the 450, I am going to have to make a platform for the mechanics to sit on . The tailboom was made a little long so I am going to have to cut some off the end for my 450 heli which is not a problem. Heres some pics of the 450 size with the Corona 206 and a few pics of others Corona jet Rangers Hard to believe the Corona Jet ranger fuse is about 6-7 years old. time has flown by.
darthdrk is offline Find More Posts by darthdrk
Old Oct 03, 2009, 08:56 AM
rabidcanary is offline
Find More Posts by rabidcanary
rabidcanary's Avatar
Joined Aug 2007
If you have a 500 size Jet Ranger fuse, i'll take one.
rabidcanary is offline Find More Posts by rabidcanary
Old Oct 03, 2009, 09:20 AM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
I really need some solid specs of a typical 500 size chassis. . frame height, width mainshaft to Tail shaft distance
I was given the specs of a blackhawk 500 (I think thats the one) wich is pretty much a stretched 450 and it looks like it will fit this fuselage but an actual T-rex or clone there of would probably let me know a little more whether or not this will fit. If it does, I will probably add more detailing to the fuselage .
Old Oct 07, 2009, 10:55 PM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
Question
Darthdrk: How long is the fuselage of your Bell long ranger?
prop bender is offline Find More Posts by prop bender
Old Oct 08, 2009, 09:40 AM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
I dont have a Long Ranger
Some specs on this Jet Ranger
Tip of the nose to the end of the tailboom: 30 1/2 inches
center of mainshaft opening to end of tail boom: 21 1/2 inches
Height of fuselage ,Top of upper cowling to bottom belly 6"
Width 4 5/8 inches
Tailboom end can be trimmed to suit
Old Oct 08, 2009, 10:00 AM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
More info to add, Im doing this for someone who was looking for a body for his heli which is a BlackHawk 500. According to the specs given me he says its slightly bigger than the 450 but slightly smaller than the T-rex 500. With the specs given me of the heli this should be a good fit.
I dont know if this would be a good fit to a 500 size heli such as the T-rex 500 or Clone there of. Dont want this to be misleading for those who may think this might work on the T-rex 500 size and clone like helis but it does look like it will be a good match to the BlackHawk 500 according to the specs given to me.
Old Oct 09, 2009, 09:01 AM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
Stabilizer and vertical fin added
Old Oct 17, 2009, 12:15 AM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
Simple paint schemed applied before shipping off
Old Oct 17, 2009, 11:54 PM
jzanutto is online now
Find More Posts by jzanutto
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
the yellow one is nice looking
jzanutto is online now Find More Posts by jzanutto
Help! How I can paint mine Jet Ranger body???? massimo Micro Helis 1 Mar 28, 2004 10:06 AM
Jet Ranger body b16knl Electric Heli Talk 3 Feb 26, 2003 12:31 AM
FS ECO 8 Jet Ranger Body george wheeler Aircraft - Electric - Airplanes (FS/W) 3 Apr 26, 2002 06:36 PM
For Sale Jet Ranger Body for eco8 rccrashed Aircraft - Electric - Airplanes (FS/W) 3 Apr 21, 2002 05:30 PM
Jet Ranger Body for ECO, Tips?? JIMJAM Electric Heli Talk 0 Apr 30, 2001 05:08 PM
