Old Apr 22, 2003, 07:33 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
How do I know if I have a Bad Motor?
My Hitec Sky Scooter is getting real doggy in it's performance. I use to be able to do all kinds of aerobatics but now it's just kinda Lazy. I am thinking that I either have a Bad Motor or Bad battery packs, Both the Motor & Packs are old. How can I tell if the motor is bad? I am charging up the Packs right now & will put my Multimeter on them to see what voltage they have. Does the Sky Scooter Pro have a Speed 400 or a 380 Motor?
-Thanks-
mrebman is offline Find More Posts by mrebman
Old Apr 22, 2003, 08:43 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Well the only <=400 motors I've truely worn out are the speed 400s in my Zagi. Went through 4 or 5 in about 4 years. In all the ones I replaed they would make "weird" clicking noises when turned by hand. Flight times and performance were down, and the motor was warmer than normal. Also there was a fair amount of arching seen when peaking in the slots by the brushes.
Interestingly enough I tore apart one of them ,and it looked fine, but it was definatly the motor in my case, because as soon as I replaced the motor all was well.
The speed 400s included with my Twin Star that has a LOT of flights ( first flown Aug 1998) and the motors are just fine, but I rarely go above 1/2 throttle with this plane.
OK I wore out 2 Atomic Forces and one Fusion in my Corona, but I'm only counting the <=Speed400 stuff.
rcav8r2 is offline Find More Posts by rcav8r2
Old Apr 22, 2003, 09:25 PM
GooberVA is offline
Find More Posts by GooberVA
Alexandria, VA
Joined Feb 2002
The Sky Scooter Pro has a Speed 400 6V
How long have you had your Sky Scooter, any idea of how many flights?
You might also check your gearbox and make sure it hasn't got itself buggered up.
GooberVA is offline Find More Posts by GooberVA
Old Apr 23, 2003, 08:02 PM
mrebman is offline
Joined Nov 2000
I am still using the STOCK Hitec Motor & this was a Sky Scooter Pro I that I converted to Geared. This motor probably has 40 flights on it maybe, the gearbox looks OK & my batteries tested fine for voltage. If I remember correctly, this is a either a Speed 400 or 380 Motor & I know it's 7.2V, would It be better to go with a 6V Motor?
-Mike-
Old Apr 23, 2003, 09:22 PM
GooberVA is offline
Alexandria, VA
Joined Feb 2002
It sounds like your setup is the similiar to mine: SS Pro I geared. When I needed to, I replaced the motor with the 400 6V. I am running an APC 9x6 Slow Flyer prop geared 3:1 and I really like the way it flies. Lately I have been using 8 cell HECell packs and they work great.
Old Apr 23, 2003, 10:15 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
Mike,
You really need to measure your battery under load to determine if it is going bad. An unloaded bad battery will read about the same voltage as a good one. It isn't until a significant load is applied that the voltage sag really shows up. Best thing to do would be to find a friend with a good battery charger that can do discharges as well and has a digital display, then cycle the pack a few times and see how much capacity the charger measures. This seems to be the best way to determine if it is the pack.
10Thumbs is offline Find More Posts by 10Thumbs
Help! How do I know if my tail motor's burned out? trashmanf Micro Helis 16 Jan 26, 2006 06:38 PM
How do I know if I have glitches? guillaume83 Electric Heli Talk 1 May 13, 2004 09:39 AM
How do I know if my Hummingboard is bad? kansasjayhawk Micro Helis 9 Nov 16, 2003 02:41 PM
How do I tell if my brushless motor is up to par? ferradas Electric Plane Talk 4 May 12, 2002 03:38 AM
How do i know if im getting the NEW twinjet? Adam in Toronto Foamies (Kits) 7 May 05, 2001 07:41 PM
