Old Apr 22, 2003, 06:58 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Bullseye Update....
The Bullseye has been a popular airplane around here with all kind of mutations flying successfully..... here's the latest incarnation ...the Albatross 3D body and the Bullseye wing..... lots of side area and prevents the broken in the middle stick syndrome....besides looks cool .... Plans are still avialable for free at www.FoamFly.com
What do we call it ??? the Bullbatross???? ...or as FB Rich says the Albetoilet ....isn't that what friends are really for???
gpw is offline Find More Posts by gpw
Old Apr 22, 2003, 06:59 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
another...
Old Apr 24, 2003, 09:04 AM
SkyBurner is offline
Find More Posts by SkyBurner
LaPorte, IN
Joined Jul 2002
Just putting the finishing touchs on mine, adding the full fuse does add more character.
SkyBurner
SkyBurner is offline Find More Posts by SkyBurner
Old Apr 24, 2003, 05:56 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
WoW!!! Nice Paint!!!
Should be a "Hot " flier .....You're right!!! The fuselage really looks better than a stick ....
Really gool looking , please let us know how your's flies......
Old Apr 25, 2003, 08:03 AM
LaPorte, IN
Joined Jul 2002
Thanks Glen,
I used a Sanford HI Impact Broad tip permanent colored marker for the flame job, waiting for the weather here in N.W. Indiana to coperate, winds been 10 to 20 mph. on a daily average, Closer to 20mph.
I,ll post how the maiden goes.
Old Apr 25, 2003, 08:21 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Windy here now also ....looks like a good weekend ...hopefully for all...
Old Apr 27, 2003, 06:43 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
UPdate...... Tried the E-Gull/ GWS D motor 11x8 prop... on the Bullbatross (or whatever) and experienced SEVERE torque rolling problems...would flip over left and execute roll at any altitude ....NO FUN!!! checked for warps ....found none .low throttle , no problem......maybe just TOO much power ( I can't believe I'm saying that) so I put an A motor back on it ( epu-6).....maybe not enough turning force with Rudder and elevator ...maybe elevons would solve the problem.....will test further ...don't go away....
Old Apr 29, 2003, 06:22 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
have tested the ( your name here ) and found that I stupidly had a bit of left thrust in the motor mount (senility!!!)...Problem solved.....flies great now .....DUH!!!!
Old Apr 30, 2003, 01:03 PM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
E-GULL/GWS D MOTOR SETUP
gpw ,,,, I know you have talked about this motor and gear box setup before and have had good results on different models.. but could you tell me what it is and where do you get the motor and gearbox, ( Aeromicro, bpproducts.. ?????)
STRINGFLY is offline Find More Posts by STRINGFLY
Old Apr 30, 2003, 06:13 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
The E-gull motor is the replacement motor for the E-GULL RTF (?) www.ReadyToFlyFun.com toytronics..... $5.00 ...GWS E-300C gearbox (or D)
Old Apr 30, 2003, 06:16 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
In search for even more stability (trainerbull)....
Have bent some dihedral into the wing 8" out from the fuselage.....we'll see if it helps .....maybe tomorrow if the weather permits....
Old Apr 30, 2003, 06:23 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
pics
1
Old Apr 30, 2003, 06:25 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
pics
2
Old May 04, 2003, 08:17 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
Well let just say I was a sceptic that a round flat wing with ONLY rudder and elevator would have any control to keep any plane level and even turn the thing with any reason of control. Yes I know that there was a WW1 plane that was controlled this way but I still thought it would be a pain to fly.
Well let me tell you after a little bit of a rocky road to find the balance and basic trim, 1 motor stick, I must say I'm really impressed, amazed, and in awe with this little plane. Glen, I am sorry for doubting you and your plane.
I worked around the house and on the cars all day. The weather was perfect for flying. Finished up around 5pm and got the idea to try out this design. So off to the shed for a hunk of blue and by 7pm it was ready. After 2 failed trips to the park to fly #3 was the charm as the sun went down and darkness set in. So after a trim flight move location to the school parking lot and put in another 45 minutes. What a blast. I think this is a plane my 8yr old can fly, with a little help.
Thatovalguy is offline Find More Posts by Thatovalguy
Old May 04, 2003, 08:23 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Way cool Dude , but then , you are one of the only few that had any success with the Borg Cube.... Glad you enjoy the Bullseye ....it was my attempt to come UP with a plane that fly great and be really easy to build....sorta' like the Bic lighter of foamies .....
