| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
3D Hobby Shop 46" Vyper Review
Over the past couple years; 3D Hobby Shop (3DHS) has released a lot of very popular, high quality electric aircraft models. One of their more unique aircraft, the hybrid 46” Vyper, has become one of my favorite go-to electric airframes. The Vyper, developed by Scott Stoops, is considered a hybrid because of its ability to perform both 3D and precision maneuvers. The airframe itself is shaped similarly to that of a pattern aircraft (swept wing, long fuselage), but the large control surfaces, light wing loading and superb design allow it to perform 3D maneuvers as if it were any other 3D aircraft. The Vyper looks to be a top performer in both the 3D and sport aerobatics classes.
Box ContentsMy Vyper came with all of the contents neatly laid out and secured in a triple-boxed package for the ultimate damage protection. I first noticed carbon fiber renforcements in the fuselage and the high quality Ultracote covering used. After a couple hours after letting it adjust to the high altitude and dry Colorado heat, I took a few minutes and a heat gun to the few wrinkles that existed.
The 3D Hobby Shop 46” Vyper kit contains:
The 3D Hobby Shop 46” Vyper kit requires:
AssemblyFollowing the highly detailed instruction manual, the Vyper can be assembled and flying in as little as 6 hours. The build process was very easy, and everything fit together quite well. The included hardware is very high quality and was veasy to work with. Let’s go through some of the build process and get a 46” Vyper ready to go.
Fuselage, Tail and Wings
Fuselage assembly is where I spent most of my time during the build. After cutting out all the necessary holes, I assembled the landing gear and wheel pants. Although not mentioned in the manual, I used a little bit of shoo-goo between the wheel pants and landing gear to help keep the wheel pants straight. I also used a little bit of medium CA to glue the foam wheels to the rim. I have found that both of these things help to keep the wheels from locking up and damaging the plane during a rough landing.
The tail assembly went very smoothly. I took my time to align the elevator stab and made sure everything was square before gluing. All of the stabs and control surfaces fit and aligned perfectly without any modifications. When installing the stabs, I made sure not to cut the covering. It has been recommended that you wick extra thin CA where the elevator joiner contacts each elevator half to help strengthen the bond between the joiner and the elevator to prevent an in-flight failure.
Assembling the wings is probably the easiest thing to do in the build. The ailerons (like all of the control surfaces) use CA hinges that are already pre-installed which makes installing them very easy. I just slid the ailerons in place, aligned and glued. I installed the servos and control horns, and I was done!
Power System and Electronics
My Thoughts...
Motor – After wicking the motor box joints with thin CA, I installed the Omega 103g motor from 3DHS. For cowl spacing, the motor requires the use of the four included spacers. The firewall has pre-drilled holes and pre-installed blind nuts for most of the popular motors, so installing the motor was as simple as tightening 4 bolts.
SetupI followed the manual’s recommendation for aircraft setup (quoted below). The manual provides an excellent explanation on the setup.
FlyingMaiden and Trimming
The maiden flight of the Green Vyper was a new experience for me. I had never flown an airplane like this before, and didn’t know what to expect. With the CG and throws set to manual specifications, I was very impressed that the model only required a couple clicks of rudder trim for straight and level flight. After a few rolls and half-Cubans to get used to the flight characteristics of this new airframe, I had no problem bringing the plane down for some KE passes, upright, inverted and rolling harriers, hovers and torque rolls. After a short 4 minute maiden flight, I landed so I could start trimming it out to see what the Vyper could really do. After a few flights of trimming, I had it flying exactly how I like it. For trims, my Vyper required 1-2% Rudder-to-Elevator and 3% Rudder-to-Aileron mixing for knife edge flight, and one small washer of additional up-thrust for vertical lines. Sport FlyingAlthough I spend most of my time practicing 3D maneuvers, the Vyper can be set up to fly very well for the average sport pilot. I found no bad habits at all while flying this plane around and performing the very basic pattern sequences. It tracks very straight, rolls very axially and on low-rates is not twitchy at all. The Vyper is easy to land, and it doesn’t take a lot of effort to achieve a beautiful 3-point landing. It’s almost as easy as lining up with the runway and reducing the throttle. Aerobatics
Flying the Vyper is almost like flying the perfect plane. Smooth, straight tracking and wild 3D aerobatics are not a very common mixture among a lot of the planes in this size, but the Vyper really does have an ability to switch back and forth from precision to 3D flight with ease. Most of my flights start off with some easy flying, maybe a few point rolls and IMAC maneuvers, and then I flip it to high rates and bring it down for some 3D fun.
Rolling – The Vyper performs rolling maneuvers very well. Slow rolls, point rolls and rolling harriers were all very precise, controllable and axial. It doesn’t require much rudder or elevator adjustments to draw a straight line while rolling.
Flight Photo Gallery/Video
DurabilityThe Vyper is an extremely durable plane. I have put mine through a ton of abuse, and it keeps on going. It has had the wing tips scraped down the runway in KE, fallen out of hovers due to LiPo-cutoff, skidded across the runway after catching the rudder in inverted harrier and even cart wheeled once after the elevator caught some tall grass. Most of the damage could be repaired with a little bit of CA, and for the rest of it, well, 3D Hobby Shop stocks a lot of spare parts. The worst damage was during the cartwheel where some of the balsa on the side of the fuselage broke, but the carbon fiber re-enforcements saved the fuselage from breaking in half. The motor box also survived which I was surprised to see, I thought I was going to have to replace it for sure.
Is it for beginners?No. While the Vyper is a very solid plane to fly, it does require some skill. It is a purpose-built aerobatic airframe that can be flown aggressively. This is a great airframe for someone who has a good understanding of aerobatics and is looking to advance his skills.
ConclusionFor lack of a better word, the Vyper is awesome. I love having an airframe that combines a mixture of precision and 3D flight characteristics. The plane tracks very well for long, smooth pattern maneuvers and at the same time can slow down and harrier with the best of ‘em. Since the first time I flew the Vyper, it has stayed in the truck just in case I happen to drive past an open field with some time to get in a few flights. After hundreds of flights, I broke down and bought another one to have as a backup. This plane truly brings new meaning to “Fly the Best”.
Pluses:
Minuses:
Thread Tools |
#2 |
AMA 247498-3DHS is what I fly!
Very nice review and video.
You did forget 2 Minuses: Once you fly this you will want a bigger version Once you fly a 3DHS plane you will spend more $$$ on their airframes. Umm, maybe thoses are pluses and not minuses now that I think about it. ![]() Carlo PS, tjhawker maybe you could give a bit of comparison how this flys compared to the SHP or new 330SC in similar sized airframes. The SHP has been used by many to practice both 3D and precision also. |
#3 | ||
* Igotitigotitiaintgotit
Nicely done Tyler, and great flying. Certainly the fastest rollers in an RCGroups review, ever.
Unsure why it didn't make the review, but here's my favorite video of Tyler flying this green Vyper. The shot of the yawing landing at the end is awesome...
#4 |
BadPilot
Tyler,
Super review! Very detailed explain on all crucial points of the build and several different possible setups. Clean, clear pics and a full take-off and landing on the video. Was that you flying in the vid? I kept hearing a gas engine in the vid, I am sure it was another plane at the air field but it was loudest when you plane was close. LOL Really nice flying in the vid great hovering skills. Thanks for the review. John |
#5 |
Thanks for the compliments guys. Yes that was me flying in both videos (thanks for posting the second video Arron). The review video was filmed by Jeff Mitchell of Plane-Fun R/C at the LAMA R/C Club field (thanks again Jeff!).
As for plane comparisons...IMO.... The Vyper tracks better, and performs general pattern-type maneuvers better than the SHP and 330. The SHP will lock into hovers and harriers easier, and is more "floaty," but the Vyper isn't a slouch in the 3D department. The SHP would probably be the better choice for someone who is new to 3D, but the Vyper is great for a second or third airplane when you're looking to improve or broaden your piloting skills. --Tyler |
#6 |
rc addict
Is that Joe Satriani ?
#7 |
It's been a while since I watched the video, but I think so. I'd re-watch it and confirm, but I'm in Phoenix right now on my way back from TAS, and no way to watch the video.
#8 | |
Scott |
#9 |
Thanks Scott, glad you like it.
#10 |
Nice plane and flying!
#11 | ||
H. Diddy
Very well done Tyler! Here's my favorite Vyper video and one of the big reasons I got one. Maybe I just like that song...
#12 |
Thx guys! I wish the camera wasn't so shaky in that yellow video
#13 |
Even with the "shaky" video work, still one of the best Vyper Vids...
#14 |
2.4 GIDDIDY GHz! All Right!
Great job Tyler! The review is very well written.
Jeff |
#15 |
Thanks Jeff
Thanks for the help filming and getting the stuff to get these guys setup and flying.
| Thread Tools | |
| Discussion 3D Hobby Shop 46" Aspera | sun.flyer | Sport Planes | 2839 | Jan 08, 2010 01:35 AM |
| Sold 3D Hobby Shop 46" Vyper 3D/Precision | jadamian75 | Aircraft - Electric - Airplanes (FS/W) | 3 | Sep 04, 2009 02:13 AM |
| Video 3D Hobby Shop 46" Vyper | sukhoi26mx | Airplanes - Electric Videos | 3 | Jun 27, 2009 11:49 PM |
| Video 3D Hobby Shop 46" Aspera video: | sun.flyer | Airplanes - Electric Videos | 0 | Mar 19, 2007 01:23 PM |
