Old Oct 01, 2009, 09:27 PM
lazer155 is offline
Find More Posts by lazer155
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
I need help setting up my dx7 as a master trainer of my dx6i
Im moving this from the heli electric section....
I want ot use my dx6i as a slave with my dx7. The dx7 will be the master. I tried setting the dx7 to normal trainer mode and hooking it to a dx6i but it wont work. The dx7 works fine but the dx6i cant control anything. How do I set the dx7 up as a master remote with full control capabilities to the dx6i as a slave also with full control privileges?
lazer155 is offline Find More Posts by lazer155
Old Oct 01, 2009, 10:17 PM
lazer155 is offline
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
anybody?
Old Oct 02, 2009, 04:07 PM
lucasavaitor is offline
Find More Posts by lucasavaitor
Joined Aug 2008
Turn the dx7 on, use a trainer cable to connect the 2 tx's, but ensure that the dx6i is OFF. It will turn on by itself. Now, program the exact same for both radios. When you pull the trainer switch, the dx6i will have control.
Hope that helps, and sorry nobody answered your question for a while.
Lucas
lucasavaitor is offline Find More Posts by lucasavaitor
Old Oct 02, 2009, 09:26 PM
lazer155 is offline
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Thats exactly what I did but it looks like the dx6i I just sent back to horizon under recall which they supposedly replaced with a brand new dx6i now has a broken trainer function. I have to end it back to horizon again for repairs again.
Old Oct 02, 2009, 09:53 PM
Joined Aug 2008
That sucks. Keep us posted!
Lucas
Old Oct 02, 2009, 11:56 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Oct 03, 2009, 01:18 PM
Joined Aug 2008
I have buddy boxed a dx7 and dx6i, using my procedure it worked fine.
Spektrum screwed this whole buddy box thing up imo. I mean, why not just make it compatible with all jr? Sure, it would make the dx6i $5 more to manufacturer, but this is such a common problem, and it needs a fix.
Lucas
Old Oct 03, 2009, 06:05 PM
lazer155 is offline
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Originally Posted by fhhuber506771
DX6i has problems buddy boxig with anything except :
Another DX6i
A DX5e
I've not been able to personally test the DX6i with a DX7... I know the DX6i will not buddy box with several other radios that will buddy box with the DX7.
For best chance of success:
1) Turn on the TX to be used ans master
2) Turn on the aircraft RX.
3) Verify all controls function.
4) Plug in the trainer cord to the slave box
5) THEN plug in the trainer cord to the master.
6) Retest the control with the master
7) Test control with the slaved box.
Then do a range check. (which might require turning everything off and restarting at step 1 after the range check... don't repeat the range check if this is needed.)
Note that if it fails at any point in that sequence you have no chance of success.
There may be nothing wrong with the DX6i...
I took my dx6i to my lhs and they could not get it to buddy box with my dx7 at all. They grabbed one of their new dx6i out of the display case and it buddy boxed perfectly with my dx7. So I am positive the dx6i can buddy box with a dx7. Horizon just messed up with my replacement. Now I have tto call them on monday when they open again and see what I should do. I assume they will just replace it again, but this time hopefully with an actual fully functioning dx6i. We'll see...
Old Oct 13, 2009, 07:08 PM
lazer155 is offline
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Great news! Horizon has decided to make up for me having to send the dx6i back again by sending me a DX7se! Thanks Horizon!
Old Oct 13, 2009, 07:28 PM
Joined Aug 2008
WOAH!
You have to be kidding! I have never in all my life heard of a company compensating a product in this way!!! Way to go! good for you! (wish it happened to me though). One problem. The dx7se doesn't have a trainer port...
Lucas
Old Oct 13, 2009, 07:40 PM
lazer155 is offline
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Originally Posted by lucasavaitor
WOAH!
Lucas
Nope not kidding! I dont care that the DX7se doesnt have a trainer port now though. Its a free replacement thats better than my DX7 and way better than a DX6i. I only needed the dx6i to use to train my friend how to fly anyways. I can always sell the DX7se and have enough money to buy a dx6i and something else.
Old Oct 13, 2009, 07:52 PM
Joined Aug 2008
Wow, still speechless.
I'm amazed.
Lucas
Old Oct 14, 2009, 09:43 AM
lazer155 is offline
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Horizon is the best! I couldnt believe it either.
Old Oct 14, 2009, 10:30 AM
jimbob00 is offline
Find More Posts by jimbob00
Joined Aug 2009
that's weird, you send a TX because the buddy boxing doesnt work, and they replace it with a TX that *doesnt buddybox*
Other than that i'm just jealous
jimbob00 is offline Find More Posts by jimbob00
Old Oct 14, 2009, 11:53 AM
lazer155 is offline
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
The first tx i sent in didnt buddy box and the rudder and throttle were jumping around by themselves. Like i would have the throttle at 50% and the monitor would show the throttle and rudder jumping randomly around. It was a recall problem. Horizon sent me a new dx6i and the rudder and throttle worked on that one but the buddy box on that one still didnt work. I sent the nonbuddy boxing dx6i back to and they called be saying they were going to make up for me having to send it in a second time by giving me a DX7se. They asked what mode and type I wanted. I told them the heli version. So they shipped it yesterday and I should be getting it by tomorrow or friday. Hurray!
Help! I need help setting up ailevators in my Futaba 9C, please. WarrrEagle! Radios 7 Dec 13, 2015 05:58 AM
Discussion I need help setting up my Blade 400 - Central Ohio Blue Jacket Mini Helis 7 Aug 10, 2008 05:19 PM
Discussion I Need Help Setting Up My Cppro W/jr6102 helidiction Micro Helis 1 Jan 20, 2007 08:17 AM
Discussion Need help setting up 401 w/DX7 please... warpspeed Mini Helis 0 Jan 16, 2007 09:16 PM
Need help setting up a CP picccolo as FP microflite Micro Helis 8 Nov 18, 2003 07:03 PM
