Old Oct 01, 2009, 06:25 PM
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
R617FS RSSI problem whit remzibi OSD
Hi
I have made the RSSI hack on the R617FS reciever and i use a 4.7kohm resistor to connect to the Remzibi OSD.
But i have some strange values when iam going to polling the adc values.
When i turn on the tx the values it jump very much, the values between 11-43 and then a big jump to 360-380 adc value and then back to the lower values then upp again.....,
If i turn of the tx i get some lower values and they donīt jump around that quick, geting the values between 11-25.
But i tried to calibrate the RSSI as good i could, then i went out to my flying field and fired up and voila the RSSI was working and showing 160% +/- very stable, and i fly away and the RSSI went weaker and showed around 125% at 1km/0.6mile.
So it worked,
The inside test showed 0% and then jumped to 100% when tx on and then back to zero and than back to 100%........
when tx off the rssi showed around 0% +-- and no jumping upp. wierd
One tought i have about this strange values could be the wireless networks.
I have one 200mw router on my roof and one weaker in my apartment, plus the neigbors nets.
So maybe the FASST must work realy hard to filter out the noise and the diversity between the antennas could be one problem between the jumping values?
Hmm i forget to mention that i have measure the rssi whit my voltmeter and it showed a stable high/low value when tx on/off. but maybe the remzibi osd can measure more precise? or something i have made wrong.
So if you guys have some tips and tricks it would be great.
Regards Alex
Tuven is offline Find More Posts by Tuven
Old Oct 01, 2009, 06:34 PM
mmormota's Avatar
Budapest
Joined Jul 2003
I use a different approach, because strong disturbing signals may fool rssi.
I use a "packet loss indicator". There is a red led on the receiver, it is on if a packet lost. The more it light the worse the reception.
I connected a RC low pass filter (150kOhm, 10 uF) on the led's pin, and connected the average voltage to the A/D. It diplayed as 0% to 100%.
Works pretty well.
Time to worry above 30%, but you can't feel it, the servos are smooth at that level. Above 70% the servos are jumpy.
My test video (check the % vs the movement of the servo):
Untitled (1 min 37 sec)
mmormota is offline Find More Posts by mmormota
Old Oct 01, 2009, 06:58 PM
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
Okey i see, thatīs realy smart and fool prof, the RSSI is not that precise then.
Must test it out tomorrow and see how the red led behave and record whit my webcam.
But shouldent the lowpass be on the OSD? because the voltage dropp ??
Old Oct 01, 2009, 07:09 PM
mmormota's Avatar
Budapest
Joined Jul 2003
Of course I soldered the R and C part to the OSD's pcb.
I attached an oscillogram, the rssi output of the 617 is a series of pulses. If you like to use rssi, you need an opamp voltage follower (to avoid low impedance on the output) and a RC lowpass.
Old Oct 01, 2009, 07:18 PM
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
Thankīs alot. very good info.
I will go for the packet loss indicator mod.
But the rssi could be good also. but for me i think the packet loss indicator will do fine. it is simple then opamp.
Have you tested in air yet?
PS. do you have some direct link to the specified cap and resistor?
Old Oct 01, 2009, 07:46 PM
mmormota's Avatar
Budapest
Joined Jul 2003
More then a hundred flights in 2 planes. Works very well.
Before this mod I didn't know that there are losses in relative small distances, if my body is between the plane and the radio.
No, sorry, I have resistor and capacitor sortiments, as my job and second hobby is electronics.
You can use any resistor and capacitor with the above values, including electrolyt type (take care of polarity).
I built it with a ceramic one.
Old Oct 02, 2009, 01:19 AM
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
Okey good.
No problem i will find the right parts.
And thankīs for the quick answers.
Old Oct 03, 2009, 10:58 AM
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
BTW whatīs the formfaktor on the resistor/cap are you using, i have seen three diffrent sizes/package
0603
0805
1206
Old Oct 04, 2009, 02:03 AM
The one and only
dadde's Avatar
Hjo, Sweden
Joined Apr 2004
Cool find mmormota! One question thou; Is there no need for a D/A converter from the led output to the RSSI input on the OSD? Or does the RC filter make one obsolete?
dadde is offline Find More Posts by dadde
Old Oct 04, 2009, 07:26 AM
mmormota's Avatar
Budapest
Joined Jul 2003
0603
0805
1206
0805 for most positions, just the 10 uF is bigger.
Old Oct 04, 2009, 07:28 AM
mmormota's Avatar
Budapest
Joined Jul 2003
No need for additional hardware, just the RC low pass: 150k in series, 10 uF parallel to the input.
Old Oct 04, 2009, 07:30 AM
The one and only
dadde's Avatar
Hjo, Sweden
Joined Apr 2004
Thanks man Awesome
Old Oct 04, 2009, 10:59 AM
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
Have ordered the stuff
Old Oct 13, 2009, 06:01 AM
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
I have it working now. Thankīs mmormota
Peace of cake, my first smd soldering hehe. not that easy.
Old Oct 19, 2009, 11:24 PM
The one and only
dadde's Avatar
Hjo, Sweden
Joined Apr 2004
Tuven: Did the mod work good for you?
My OSD's RSSI input is made for 0-2.5V and the signal i get from the receiver is 2.8V, would it be possible to add a pull down before the low-pass filter to get the voltage down a tiny bit?
Video Fasst dropout test with Remzibi OSD mmormota Electric Plane Talk 0 May 29, 2009 11:48 AM
Discussion Interesting problem with ET OSD nathanj988 Video Piloting (FPV/RPV) 11 Dec 29, 2008 03:51 PM
Discussion Problem whit 6exa Futaba XE3HWA Radios 0 Aug 31, 2007 07:59 PM
Help! problem whit digital link knoke Aerial Photography 2 Dec 09, 2006 10:29 AM
Discussion Problem whit new lipo's, then don't charge anymore, why???? Jet builder Batteries and Chargers 13 Sep 11, 2006 02:25 PM
