Old Oct 01, 2009, 10:17 AM
laser110 is offline
Find More Posts by laser110
Just Limin'
laser110's Avatar
United States, NJ, East Brunswick
Joined Nov 2008
Winter Battery Storage
As the days get shorter here and the wind kicks up some, sailing my boat will not be possible again after a few weeks. I was wondering what others do for winter battery storage?
Normally now, I use my boat and run the batteries down some. When I get home I take them out of boat and when I am sailing again, top them off which only takes a few hours. Should I continue to do this every few weeks, even if I am not using the boat? Or should I drain them completely? Last thing I want to have to do is buy new ones in the spring.
What about your transmitter battery?
Scott
laser110 is offline Find More Posts by laser110
Old Oct 01, 2009, 12:03 PM
Tachikaze is offline
Find More Posts by Tachikaze
太刀風
Tachikaze's Avatar
United States, OR, Eugene
Joined Jan 2003
Most of my batteries are SLAs, with a few ni-cads and ni-myd.
The SLAs get charged up and then set aside. I have found that the thing that will kill a SLA in no time is placing them on concrete. I lost three in one year from setting them on the floor in the garage. Now, they are all stored on a shelf.
My Nickle batteries are all charged up and then also set aside. I have lost very few of them.
But for the most part, my batteries are used all year round. If not sailing a boat, I am building a boat and will have to use the batteries when putting in the electronics.
Where the winter use of the SLAs really comes in handy is when the snow falls and the power goes out. I can use my power converter and my large SLAs to run the microwave and stereo. Brings the neighbors over looking for heat and water.
Tachikaze is offline Find More Posts by Tachikaze
Old Oct 01, 2009, 12:48 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
I think just the opposite is true. Nicad and Nimh are stored discharged to about 1 volt per cell. Nicads suffer from memory, in that if they are not charged up fully and discharged fully they loose some capacity to hold a charge. This is why cycling a nicad pack before use is important. Nimh have much less memory effect, but neither are good at long term storage as they both self discharge. Over long periods of time both will loose a charge.
SLA's should be stored charged and topped off once in a while. A float type charger is ideal, but occasional trickle charging is OK. And as long as SLA's have used molded plastic cases (20 years?) the drain to earth has been eliminated. The older battery cases made from bakelite or rubber have a slight conductivity and will drain through a wet concrete floor. Polypropolene is an excellent insulator.
I would think that if you have an SLA battery that self discharges significantly it has one or more plates damaged. A common problem if too many amps are pulled from a small SLA battery.
See this for some more info.
Any battery should be unplugged and all cells removed for long term storage. Corrosion in the wires (black wire disease) is common if you don't.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Oct 01, 2009, 12:54 PM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Originally Posted by Tachikaze
............I have found that the thing that will kill a SLA in no time is placing them on concrete. I lost three in one year from setting them on the floor in the garage. Now, they are all stored on a shelf............
Do you know what it is about the concrete that kills them?
Tom
Trisquire is offline Find More Posts by Trisquire
Old Oct 01, 2009, 01:17 PM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Have a read through this. It should clear a few things up for all different cell types.
http://www.powerstream.com/Storage.htm
The only thing I would add is to to recharge at 1/10 C when bringing them out of storage. That's for NiMh & NiCd. It's a good idea to check the voltages once every couple of months too, just to see if one is losing voltage too fast.
Luckily, here in sunny Brisbane we don't have a real winter, so it's boating all year round for us.
All the best.
Paul.
785boats is online now Find More Posts by 785boats
Old Oct 01, 2009, 01:37 PM
420TEE is offline
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
You can also check buchmann.ca/
Very handy site.
420TEE is offline Find More Posts by 420TEE
Old Oct 01, 2009, 03:47 PM
Big Boats Rule!
Wisconsin
Joined Jun 2007
Most of the references say that in the 'old' days, a battery was built in a container which had a very mild conductivity. When placed on a concrete slab, especially when damp, the battery would discharge through the case to ground. Placing the battery on wood, a very good isolator, minimized the discharge. Perhaps it is the calcium, or the salt, that makes enough of a circuit to drain the battery down over time.
Today, batteries are made from injection molded plastic housings with excellent insulation properties. The discharge through the case is minimal.
However, if you are storing them in a garage with no heat and live where the winters get cold, freezing is a problem. Storing a battery with the terminals touching a concrete slab is probably a bad idea for the same reason.
Dave
Old Oct 02, 2009, 05:49 AM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Thanks Dave.
Old Oct 02, 2009, 03:49 PM
laser110 is offline
Just Limin'
laser110's Avatar
Joined Nov 2008
Maybe I should have explained more. My batteries are stored in a climate controlled room ( my office/computer room) and are actually sitting on a wooden shelf. I am not worried about them discharging from concrete storage.
I have 2 Werker 6v/10Ah AGM Sealed Non Spillable batteries. The battery in the remote is hard wired in. NICD 9.6 V
If I understand right, I don't need to do anything with them till the Spring again, when I'll charge them up fully for the first run of the year?
Scott
Old Oct 02, 2009, 05:04 PM
Big Boats Rule!
Wisconsin
Joined Jun 2007
For long term storage...
The AGM should be charged up, and topped off after a few months.
The nicad pack in your tx should be discharged to about 1 volt per cell, so around 8 to 9 volts and then unplugged from the circuit board. Even built in packs have plugs on the wires.
Come spring, cycle the nicad pack a few times to make sure it will deliver the capacity you expect. Top off you AGM's and you are ready to go.
The discussion about concrete was really responding to the other posts. Sorry for the hijack.
Dave
Old Oct 02, 2009, 11:50 PM
laser110 is offline
Just Limin'
laser110's Avatar
Joined Nov 2008
Dave thanks for the advice. I had sort of figured thats' what I would do with the AGM's and what I was planning to do.
I can't unplug the battery from the circuit board in my tx. I have an older tx made by Futaba for Robbe. When I went to the local hobby shop to get the replacement battery, the connectors used back then are not available now. The guy there said "no problem" snipped my connectors on the tx and the connectors on the battery and soldered them together with some heat shrink tubing to protect the joint. I can turn on the tx and let it run down, but disconnecting is not an option.
Scott
Old Oct 03, 2009, 08:51 AM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Tom
This myth does have some historical basis. Many years ago, wooden battery cases encased a glass jar with the battery in it. Any moisture on the floor could cause the wood to swell and possibly fracture the glass, causing it to leak. Later came the introduction of the "hard rubber" cases, which were somewhat porous. A current could be conducted through this container, which had a high carbon content, if the moist concrete floor permitted the current to find an electrical ground. The wise advise of the old days to "not store batteries on concrete" has apparently been passed down to us today, but it no longer applies.
more coffee is offline Find More Posts by more coffee
Old Oct 04, 2009, 06:08 AM
time4420 is offline
Find More Posts by time4420
time4420's Avatar
S.E. Mass.
Joined Oct 2007
The most important point is to always keep the batts with a full charge.
The AGM's don't care about running down and then left in a discharged state. When charged, they will pop right back.
time4420 is offline Find More Posts by time4420
Discussion Winter battery storage? Maz North Coast Electric Flyers 9 Jan 05, 2007 07:14 PM
Winter Battery Storage alaskagoldman Batteries and Chargers 10 Aug 16, 2005 10:41 AM
Question Winter battery storage Bernie Wolfard Batteries and Chargers 5 Nov 21, 2002 05:49 PM
battery storage cenman Electric Plane Talk 3 Feb 20, 2002 04:41 PM
Flight Battery Storage - charged or flat? Steve_Bennington Beginner Training Area (Aircraft-Electric) 11 Sep 16, 2001 05:00 AM
