Old Mar 31, 2010, 03:20 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Originally Posted by muto View Post
Thanks, Berrie.
Its flying. And turning. And wont land.
Is this a good thing or a bad thing?
Gerald
G_T is offline Find More Posts by G_T
Old Mar 31, 2010, 04:01 PM
muto is offline
Find More Posts by muto
Dimitre
Baltimore
Joined Mar 2006
For now looks good. I just come back from a test fly. I was flying in the same baseball field place between the trees.
muto is offline Find More Posts by muto
Old Mar 31, 2010, 04:15 PM
G_T is offline
G_T
G_T
Joined Apr 2009
How does the performance and handling seem to you?
Gerald
Old Mar 31, 2010, 07:36 PM
Pook is offline
Find More Posts by Pook
Pook's Avatar
Bolton,England
Joined May 2003
Hmm...I feel compelled to say something, even though it may back fire and make me look like a pedantic know-it-all...So apologies in advance
Muto, you probably know this....but if you press the print screen key you can then paste a screen shot of anything you have on your screen into a program like Paint and then save it as an image file...jpg or similar.
Pook is offline Find More Posts by Pook
Old Apr 01, 2010, 08:48 AM
muto is offline
Dimitre
Baltimore
Joined Mar 2006
Gerald
Looks like the model love speed. Nice control with ailerons only. Yesterday was so windy and turbulence in that small field an the model has no problem moving into the wind. I set my flaps 2mm offset for launch 0 and 2mm dawn. Ailerons 12 mm up and down no differential. Elevator little up for launch only. Finally model weight its 160 grams.
Pook
I know, but was something wrong with my PC and I take a picture
Old Apr 01, 2010, 09:24 AM
Berrie is offline
Find More Posts by Berrie
Festina lente
Berrie's Avatar
Schoonhoven, the Netherlands
Joined May 2006
Muto, I think you can add more downflap for thermalling. My Mini Zone (which is a bit smaller as yours) has 3.5-4mm downflap for thermalling. The plane slows down drastically. And if you swith to cruise or speed, the plane is fast indeed. You can see it accelarate. In speed mode the sinkrate is, as a backdraw, noticable higher.
G_T has posted his flapsettings fot the fullsize Zone.
http://www.rcgroups.com/forums/showp...59&postcount=6.
I copied them for the Mini Zone.
I flew the 1mtr Mini Zone last weekend with a gusty wind, 3-4 beaufort. I was standing behind a threeline, getting even more turbulence. The Mini Zone doesn't like this kind of turbulence. Even if you ballast the glider to 165 gram.
Berrie is offline Find More Posts by Berrie
Old Apr 01, 2010, 09:59 AM
G_T is offline
G_T
G_T
Joined Apr 2009
Yep, you will probably find that having a base camber of 3 to 4mm and then elevator to flap compensation that puts you closer to 6mm in a thermal turn is what you want. It should slow down quite nicely and turn decently tight. But for those not used to Zones, keeping the bank angle no higher than 45 degrees helps keep the turn efficient. And don't try to float the turn too much. Let it carve a little bit.
For launch, having perhaps 1mm of down camber mixed into the launch preset is a good thing. Then on the climb, be at 0 camber which is the native camber of the wing.
Gerald
Old Apr 01, 2010, 03:49 PM
muto is offline
Dimitre
Baltimore
Joined Mar 2006
Look that 6mm flap works fine. Even more
Old Apr 02, 2010, 07:49 AM
muto is offline
Dimitre
Baltimore
Joined Mar 2006
DLG Zone 1m (1 min 15 sec)
Old Apr 18, 2010, 05:49 AM
Berrie is offline
Festina lente
Berrie's Avatar
Joined May 2006
Yesterday I could spec out my Mini Zone. Thermals were everywere.
I could roll, loop and when flying gets really boring, upsite down thermalling.
Hehehe, cool plane.
I'm really surprised there are so little people who build the mini Zone so far.
Meanwhile, the fusemold is ready. Due to familyresponsibilitys it will take some time before the first fuselage is ready.
Things I want to try with the mold:
Canopy:
http://www.rcgroups.com/forums/showp...&postcount=973
Bladder:
http://www.rcgroups.com/forums/showthread.php?t=1056468
Old Apr 19, 2010, 12:07 PM
G_T is offline
G_T
G_T
Joined Apr 2009
Berrie,
I think the light weight in the specification scares many away.
I'm glad you are having fun with your new plane!
Gerald
Old May 11, 2010, 02:26 PM
Berrie is offline
Festina lente
Berrie's Avatar
Joined May 2006
Dennis was placed second with the Mini Zone at one of the six Dutch championship competitions!! It was the first time ever that he flew a Mini Zone at a competition. The reason he is placed 'only' second: he hit someone during the last landing and got a penalty....
We expect a better score the next time, cause he flew with a warped wing, not the sweet dihidral and with fat balsafuselage.
Last weeks I've build 3 more wings, and they are almost completed. These wings are layed up with extra reinforcement around the servo's. It addes extra grams as a concequence.
This evening the first composite fuselage left the molds. It's lay up was simple. Four layers of balanced glas at 45. One 24K roving at the wingsaddle and one at the longitudinal joint. Weight about 11 grams. I was hoping for 10 or 9 gram. Next layup with kevlar.
A picture:
Old May 11, 2010, 02:44 PM
ROOSWH is offline
Find More Posts by ROOSWH
Walter Roos
ROOSWH's Avatar
Canton, Ga.
Joined Aug 2004
Berrie,
I think it's because " little people " can't handle a 60" DLG without a tip strike, but they want to fly DLG too.
walt
Sorry
ROOSWH is offline Find More Posts by ROOSWH
Old May 11, 2010, 03:39 PM
Frans Bal is offline
Find More Posts by Frans Bal
Frans Bal's Avatar
Vlaardingen, The Netherlands
Joined Feb 2004
Hi Berrie,
It was a shame that Dennis had to hit somebody and that he lost because of that.
We where really close the whole day (In points that is, Walt ). But Dennis had a better last round. Sadly he also lost the 100 points in this round.
Looking forward to the coming rounds where I hope that I can keep up with the Zone and Dennis.
The new fuse looks great.
Frans
Frans Bal is offline Find More Posts by Frans Bal
Old May 11, 2010, 07:27 PM
G_T is offline
G_T
G_T
Joined Apr 2009
Berrie,
That is shaping up to a nice looking little plane!
Dennis,
Good flying! Until the end of course
Gerald
Discussion Zone wing airfoils G_T Hand Launch 176 Sep 15, 2009 06:48 PM
For Sale New ArtHobby Ghost 1.1m Flying Wing droydx Aircraft - Sailplanes (FS/W) 4 Jun 24, 2005 03:48 PM
