Old Nov 06, 2009, 09:32 PM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
Thanks for to guidance Gerald!
We get a 14 minute window in which to fly a 6 minute flight, spot land and return the Tx to the impound. The point about min sink performance being be more important than max L/D is probably true but it can be hard to see the little ones when they top out at or over a 1000'.
My last effort was AG3 foil at 1.2 M based roughly on the Mimi wing. Inside panel was HL60 and outer Formular what ever is sold in the big box stores, carbon rods top and bottom but with a film covering. AUW was 185gm with spent motor, pod and pylon [40-45 gm no matter the size plane hence the desire to compensate with a bigger wing]
I don't have any skills with XFLR5 and must do things empirically so I shall build a 1.1, a 1.3 [Z46-Z36 as you suggest] and a 1.5 [2P] and see if I can try them all on the same day. The idea being that reportedly the 1.5s can stay up much longer than the 1 M in dead air. The test will be to see if the smaller wings extra altitude compensates for the duration of the larger wings. I can then with confidence go chase thermals.
Thanks again.
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old Nov 06, 2009, 09:57 PM
muto is offline
Find More Posts by muto
Dimitre
Baltimore
Joined Mar 2006
Thanks for advice Gerald. I'll try for 1.2 m wing for my new RGDLG .
Dimitre
muto is offline Find More Posts by muto
Old Nov 06, 2009, 10:19 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
You guys will have to let me know how this all works out. I know I have received requests for wings around 1.2M before but I never really knew why. Now I know!
Gerald
G_T is offline Find More Posts by G_T
Old Nov 07, 2009, 10:32 AM
Berrie is offline
Find More Posts by Berrie
Festina lente
Berrie's Avatar
Schoonhoven, the Netherlands
Joined May 2006
I have the wing (foamblocks) templates and profile templates as a .DXF ready. Dennis wil cut the profile templates with a lasercutter. The wingtemplates will be cutted oxygen/acethyleen in 1" carbonsteel. I will use them as a weight during cutting the wing out of the foamblocks.
(live is easy with al those CNC cutting stuff at our jobs...)
I'm willing to attach the .DXF here in this thread. Sadly this forum doesn't like . DXF. Can anyone help? Is there interest?
Berrie is offline Find More Posts by Berrie
Old Nov 12, 2009, 05:49 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Berrie,
Wont the extra thick templates (1" steel) really cool the wire?
Gary
GaryO is offline Find More Posts by GaryO
Old Nov 12, 2009, 05:52 PM
GaryO is offline
Joined Sep 2001
Gerald,
Earlier you said:
"If people are interested in a lower aspect ratio version of the Zone 2P wing I can create one. I'm certainly set up to do it."
It's obvious that you are doing lots of other things. Do you have any idea when you might do this, or are things just too hectic?
Gary
Old Nov 12, 2009, 06:11 PM
G_T is offline
G_T
G_T
Joined Apr 2009
Gary,
The wing is basically done. If I last long enough tonight I'll see what I can do.
Gerald
Old Nov 13, 2009, 12:51 AM
Berrie is offline
Festina lente
Berrie's Avatar
Joined May 2006
Originally Posted by GaryO View Post
Berrie,
Gary
I think I wasn't very clear a few posts ago. We will make two kind of templates:
1) Weights to hold the foam on the workdesk
2) Templates for cutting the wing (foil)
These 1"templates are ment to put ON the foamblocks to keep them flath on the workdesk. There will be at least 15mm foam between the cutting wire and the weights.
The cuttingtemplates, at the sides of the foamblocks, shall be made of 0.4mm thick stainlesssteel or whatever there is for free.
"sadly" both the laser and acetyleen/oxygen cutters have a lot "real" work to do. So we have to wait. (Economical revival started one week to early...)
Old Nov 13, 2009, 01:50 PM
Pook is offline
Find More Posts by Pook
Pook's Avatar
Bolton,England
Joined May 2003
Damn you economy...why must you mock us! :P
Pook is offline Find More Posts by Pook
Old Nov 15, 2009, 06:22 AM
Berrie is offline
Festina lente
Berrie's Avatar
Joined May 2006
So, here we have the first steps! I draw the Mini Zone and printed the view to see how the wing is gonna look.
The weights are cut:
I wasn't sure if it was necessary to cut 3 foamblocks for each wing, but I tought it could give a nice new challenge to cut a acurate wing tip. Therefore the 40mm span of the wingtip foamblock will give some extra attention to cut that.
The foil templates need a little fine sanding before we can cut, but the profile looks very accurate to me:
I try to follow up some advises that Phil and Gerald gave to attain better wingaccuracy in one of the Zone (profile) threads. One of their suggestions is using a thinner cutting wire. I use to cut with 0.5mm. With some 0.3mm wire in store I made me a new, smaller, cutting bow to cut with the 0.3mm wire. Will see if that works for me.
The first Mini Zone wing will be a cheap version cause we don't have experience with glassed mini wings. Using the green foam (which I can get for free mostly cause it is waste from building houses), 54gram/m@2 glas and carbon sparcaps. During the build I will write down al the weights from the used parts.
Test flying this wing will be done on a wooden Mimi fuselage.
After that we will make lighter/better wings and a fiberfuselage. About the final tailfeathers we still don't have made a decision.
back to building:
I made a 0.4mm thick carbonplate from rovings. With double sticky tape a piece of mylar was taped on a piece of wood. With tape I made 0.5mm thick wall on the mylar. A piece of balsasheet, that fits between the tapewalls, was covered with cheap packing tape. (I like that tape a lot. Epoxy doesn't stick on that stuff.)
The rovings were wetted carefully, bottom first, carefully hardroled in one directrion, heated with a haredryer and vaccuumbagged.
This turned out very good in my opinion.
I cut out 4 strips for this wing. 6mm at the root, 3mm at the tip, 0.4mm overall thicknes. The first 6 grams...
Old Nov 15, 2009, 10:25 AM
GaryO is offline
Joined Sep 2001
Gerald,
You said :"
Gary,
Gerald "
Is that the one that is now posted on the 2P thread?
Gary
Old Nov 15, 2009, 10:27 AM
Joined May 2002
Hi Berrie
Can you give me an idea of the density of that foam? The entire wing is the same foam and the carbon plate is to be the spar material, correct? BTW you can post the .dxf if they are in a .zip format.
Interested in your build.
Richard
Old Nov 15, 2009, 02:01 PM
G_T is offline
G_T
G_T
Joined Apr 2009
Gary, yes.
Gerald
Old Nov 16, 2009, 12:34 AM
Pook is offline
Pook's Avatar
Bolton,England
Joined May 2003
I'm sorting out parts at the moment to try to make my first steps towards cutting my own wings, so it's really great seeing how you are doing it....thanks for all the pictures!
Just a quick question about the carbon plate, Is it laid up with the tow overlapping like bricks in a wall or side by side?
I guess if its side by side then the strength comes from the rolling?
A little drawing of a cross section to try to illustrate my question
Piers
Old Nov 17, 2009, 05:59 AM
Berrie is offline
Festina lente
Berrie's Avatar
Joined May 2006
@The Tellurian,
The entaire wing will be made out of the green foam. The weight is about 33Kg for eacht m^3.
The carbon strips, for the spar, are cut from the "plate" I made with the rovings.
@Pook, the rovings are laid up side by side. In the end it doesn't matter how they have been laid up. Fibers are all in one direction, there is no side strenght. You have to be carefull when you remove the just cured plate from the mylar.
@The Tellurian
Posting the .DXF as a zip-file is a good idea. How simple things can be.....
I will post the file when I like the templates. The first cuts failed. As said before I use to work with a 0.5mm cutting wire. My templates have never been thinner than .5mm to. Now the wire is 0.3 and the templates are 0.4mm. That didn't match yesterday evening. The problem was cutting the upper surface of the wing. The 0.3mm did not made the first few millimeters of the cut. The cuttingwire sticked ad the templates.
I will do some tests:
1) measure the cutted foil to check accuracy in profile thicknes
2) cut with the same templates and a 0.5mm wire. Then check thickness
3) depends on what point 1 and 2 will teach me, draw better templates and lasercut new ones from slightly thicker plate.
Discussion Zone wing airfoils G_T Hand Launch 176 Sep 15, 2009 06:48 PM
For Sale New ArtHobby Ghost 1.1m Flying Wing droydx Aircraft - Sailplanes (FS/W) 4 Jun 24, 2005 03:48 PM
