Old Sep 30, 2009, 12:58 PM
hidavi is offline
Find More Posts by hidavi
Joined Sep 2009
Building RC Helicopter from Scratch
Just from reading online, it looks like unless we're ready to do some heavy machining, we're going to have to go with a fixed-pitch rotor control system.
One of the guys in my group says that we can do a full-range one, but we don't have proper access to machining for the swashplate.
What do you guys think?
hidavi is offline Find More Posts by hidavi
Old Sep 30, 2009, 04:26 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Well, you buy in bearings, right? The swash is just a complicated and hard-to-machine bearing. I think a heli still counts as built from scratch if you buy a swash or swash core.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Sep 30, 2009, 04:35 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
If you make it flybarless the head will be much simpler.
RC Man is offline Find More Posts by RC Man
Old Oct 01, 2009, 01:34 PM
mareklew is offline
Find More Posts by mareklew
How does it work? How did it?
mareklew's Avatar
Germany, BY, ERH
Joined Mar 2009
Originally Posted by hidavi
J
If you have a lathe that can turn about 50mm (2") diameter alu, you can do a swashplate. Keep it standard size though, so if you fai you can anyway uy one.
Of course, you have to buy the large diameter bearing, but I don't think you aspire to machine your own bearings anyway.
Marek
mareklew is offline Find More Posts by mareklew
Old Oct 01, 2009, 03:51 PM
grant31781 is offline
Find More Posts by grant31781
United States, GA, Americus
Joined Jun 2003
How about using the Himaxx CR 2805 counter rotating motor and making a simple coaxial?
grant31781 is offline Find More Posts by grant31781
Old Feb 19, 2010, 08:54 PM
hidavi is offline
Joined Sep 2009
UPDATE!
We decided to just buy a rotor assembly:
The battery we ordered was defective so we can't run any serious tests, but I did get to test the servo-rotor function before it ran out of juice and seems to be working fine.
I requested an RMA for the battery a different another one at the same time.
Anyway, that one is made out of carbon fiber, pvc, and pcb.
We decided to go with a standard 120 degree ccpm system, but 4 blade. We're going to use a KDS Flymentor to compensate for the absent flybar. Also, we're using a seperate gyro for a tail motor. We decided against the belt system to save time and make it simpler.
We actually got the advice about the tail motor from a connection we have at Sikorsky; the people who make the real life Black Hawk. We described to them our plan to go flybarless and they think its totally feasible.
Old Feb 19, 2010, 09:48 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Well yeah - considering it's been done like, a bazillion times, I think my dog would agree it's "totally feasible" - but does it address your specific need?
jasmine2501 is offline Find More Posts by jasmine2501
Old Feb 19, 2010, 11:26 PM
hidavi is offline
Joined Sep 2009
It just needs to fly really.
Old Feb 19, 2010, 11:38 PM
Rocket Programmer
Joined Jul 2007
Would make a good frame for a scale project I think. Flybarless heads are almost required if you want that scale look.
Old Feb 20, 2010, 04:20 PM
fr4nk1yn is offline
Find More Posts by fr4nk1yn
fr4nk1yn's Avatar
Norfolk, Va
Joined May 2006
I haven't searched through all your posts. What are you trying to accomplish?
Some type of project or experiment since "it just has to fly"?
I'd be worried about the way the main shaft is mounted to the "frame" for any type of durability. Maybe gusset it to the frame and use those as servo mounts(?).
fr4nk1yn is offline Find More Posts by fr4nk1yn
Old Feb 21, 2010, 09:08 AM
hidavi is offline
Joined Sep 2009
I was actually thinking about that. Carbon fiber braces at 60 degree angles from the back center line of the tube. Kinda busy, so I'm not touching it again till like Tuesday...
Old Feb 21, 2010, 10:37 AM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
if you think of the flymentor better get the real thing ; the capton helicommand (of wich the flymentor is a copy)
I have 3 and am verry happy with the suport capton has provided.
cmulder is offline Find More Posts by cmulder
Old Feb 21, 2010, 06:07 PM
hidavi is offline
Joined Sep 2009
I didn't realize the Flymentor wasn't the real deal. I've had it for like 2 weeks now but haven't gotten a chance to try it.
Old Feb 21, 2010, 11:14 PM
wetwolf is offline
Find More Posts by wetwolf
Quit asking ???s, get a Quark!
wetwolf's Avatar
On a 20ft ladder with a 20ft stick beating an airplane out of a tree. In Spokane, WA.
Joined Oct 2006
Good luck with that.
Hope it doesn't have to land..................
wetwolf is offline Find More Posts by wetwolf
Old Feb 22, 2010, 08:25 AM
hidavi is offline
Joined Sep 2009
Well it does have to land as well
Does the landing gear really need those end curves that I usually see?
Question How Do You Go About Building An RC Plane From Scratch? Gabbro Electric Plane Talk 34 Dec 23, 2015 12:55 PM
Question building a hearse from scratch deadsled Large Scale Cars 5 Oct 14, 2005 01:42 PM
Building an RC Boat from scratch gamer_dave Dock Talk 9 Mar 01, 2005 11:10 PM
Building a plane from scratch karpar The Builders Workshop 8 Dec 26, 2004 08:55 AM
