| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 | ||||
There's no place like foam...
EPP Edge 540 T; videos, plans
Edge 540 T
This Edge 540 T is a spin off from the EPPYak55 . Similar size and construction and flying qualities, but with a new distinctive look. I really like the lines of the Edge 540 T. My personal challenge was to see if I could make a similar plane that looks like an Edge 540 T but that will fly as well as the Yak55 and maybe better! It shares a lot of the dimensions of the Yak (wing span, tail span,wing to tail spacing, etc) yet I tried to retain the lines and look of the Edge. Here is the maiden video:
Trimmed an showing off 3D video:
#3 |
Parts (some links don't work yet, fixed soon)
Parts list for 32" Edge 540 T
1 sheet 18 x 36 1.3# 9mm epp foam. 1/16" carbon rod for control rods. Carbon flats 1/32 music wire for control rod ends. Sumo or equivalent glue Welders glue Paint Here a list of hardware that can be used and the respective costs. Make sure the components you chose are compatible with each other; especially motor and esc. For instance the Mag8 esc listed here will not work with the Hacker motor. 1) Cheapest, 24 gram motor, $8.95 sometimes less on sale, Blue Wonder 1500 kV 1.5) BW substitute Turnigy 2730-1500 Motor mount for 24 gram motor if required, 5 pack plastic stick mount 2) Mid $, 2204-14, http://www.justgofly.com/Order%20Form.htm Scroll down the page until you get to the motor and esc. 3) More $, Hacker A10-9L Prop, $1.20, GWS 8x4 available widely Prop adapter if required, $1.99, prop adapter 1) ESC for 24 gram motor, 2730-1500 motor, or 2404 motor, $11.95, 8 amp HobbyKingSS or Mystery 12 amp 2) ESC for hacker,Turnigy Plush 10 amp 1) Rudder and elevator servos also use for dual aileron set up, $3.49 ea , HXT 500 and for single aileron set up HXT 900 Reciever, $14, Corona 4 ch EZ connectors 5 pack, 1.5mm EZ connectors Control horns plywood type Prop saver bands from West Michigan Parkflyers. Last edited by leadfeather; Jan 14, 2010 at 07:01 AM. |
#4 |
Alternate size plans
Under construction
#5 |
Build guide and build photos
Under construction
The design of this plane started with the Zivko factory 3 view drawings of the Edge 540 T. Then several adjustments were made to allow good low speed flight characteristics and to make it work as a profile foamie. Last edited by leadfeather; Sep 30, 2009 at 06:41 AM. |
#6 |
You didn't say where you got the epp... I have been pricing tonight and looks like RCskyflyer.com has the best prices... You do alot of epp so just curious... RcFoam has alot of choices, but look abit higher... Don't know if they have a difference in their processing. Seems like I have read that hot wire epp is better due to its "skin"...
thanks and btw, looks like another good one |
#7 | |
I Love My Ember!
I will say that RCSkyflyer has some cool deals and good discounts on carbon/foam orders. |
#8 | ||
I Love My Ember!
Hey Dan,
Is the tail moment on the your Edge shorter than the one on your Yak? I watched the video, and it does some good loops. Will it Lomcevak? I'd love to see someone do that one indoor.
#9 | |
#10 | |
The Lomcevak looks just like what I do just before a maneuver I call a Smakitin. But seriously, I think the EPP Yak or Edge may be too light to do a Lomcevak...but ya never know?
#11 |
Aviation-Frenzy
Dan,
You must dream about this stuff. Looking forward to working up the plans. Ken
#12 | |
SEFF 2010 yet?
Smakitin is my second least favorite maneuver. My least favorite is stuckintree.
#13 |
Foam Frenzy
With the tail moment being longer it should, if my calculations are correct have slightly better hover characteristics than the Yak??
Lead your the best!!! |
#14 |
Lead - I noticed the elecs are mounted way forward. Is this because of the added weight of the carbon? In the parts count you didn't mention battery size. I assume 2S for indoor and 3S for outdoor?
#15 | |
I'll be adjusting parts positions this evening.2s works for me for indoors and outdoors. If you use larger batteries than you may need 3s for the extra weight of the battery. Last edited by leadfeather; Sep 30, 2009 at 11:11 PM. |
