As to the LE, skin as far as the LE then add hardwood LE. Prime, paint and know one will know (unless they read this etc etc). S |
I built mine just by pressing 1/64th ply over the blue foam, and then painting the ply. Overall, mine is probably TOO light, as it'll fly in very, very light lift.
They actually thermal great, with a touch of a tip-stall at the low-speed/pulling up and turning limit. They carve and loop like there's no tomorrow. On landing, I fly about 200' below the lip, fly a 360, and come up for my approach. The 360 seems to scrub off enough energy to make the landings easier. Try to avoid the "too-fast" landing, as the plane will spin 180 degrees and blow over backwards, and either break the boom or break your tail joiners. I finally went to 1/8" music wire for the tail joiners, and added some carbon at the 6:00 and 12:00 on the boom to make it stronger. On my next one, I want to reduce the dihedral, go to some stronger servos, and put a ballast tube in it...somewhere. You'll love how this plane flies. |
Latest blog entry: F-20 update
I *really* need to get building on my Shredder as well...got a few in the que ahead of it still unfortunately. I DO have the 1/64" ply already though--not easy to come by around here.
I'll be watching with interest...if you run into any snags be sure to PM Doubletap. He's one of the Mark Grand/Shredder gurus around here and a top-notch builder to boot. He's got some great Shredder pics in his blog. |
Are you sure the cores haven't been cut such that the core ends before the end of the blank? Some people do this to give a nicer TE. Also the TE of RG12 would need that little bit of a concave region.
Or put another way check with the designer before commiting sanding block to foam! S |
Shed is correct, the bed cores are oversized to support the sheeting at the TE.
Carefuly trim the TE of the cores to the correct sze with a sharp razor blade and a long steel straight edge. The cores will be shorter than the wing width shown on the plans by about 1/4 to 1/8 inch. Trim your sheeting to the correct width indicated on the plans. When I do sheeted wings, I stack from bottom bed up: sheet of wax paper, (so that any epoxy doesnt glue the sheeting to the beds) sheeting, core, sheeting, wax paper, top core bed. Take care to line up the LE so that it is flush with the front of the core beds. Use a top piece of shelving or other flat wood and then put a lot of weigth on top! Andy Quote:
| Thread Tools | |
| Discussion CR Savaron--Anyone know anything about this twisty-wing? | cynjon | Slope | 27 | Apr 06, 2011 02:36 PM |
| Poll What are your TWF (Twisty Wing Fetish) predilections? | Sled Driver | Slope | 28 | Nov 11, 2006 06:01 PM |
| Help! Request for twisty wing plane span and aspect ratio (or wing area) data | Sled Driver | Slope | 17 | Oct 28, 2006 11:44 AM |
| Question Twisty wing aspect ratio | Sleedo | Slope | 27 | Oct 26, 2006 01:20 AM |
| Hmmm. Another twisty wing thing? | Brian Courtice | Slope | 0 | Jun 09, 2005 02:28 AM |
