Old Sep 28, 2009, 02:57 PM
Joined Jun 2008
New Freewing 70 mm F-16 w/Thrust Vectoring
Has anyone seen the new F-16 70 mm single axis vector thrust EDF that BP Hobbies is selling?
http://www.bphobbies.com/view.asp?id=V815101
Check out the video, looks pretty fast
FreeWing F-16 2D 2D Vector thrust nozzle (3 min 43 sec)
chrisper27p is offline Find More Posts by chrisper27p
Old Sep 29, 2009, 04:45 PM
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
I bought one at the NEAT fair! It looks even better in person then in that video! Mine is in the Syracuse ANG scheme and has a cobra on the vertical stab. I was going to gut my Exceed F-18 for the Shulman fury fan but its been flying so well lately that I had to kill that idea. I guess my Phase-3 Falcon is going up on the shelf for a bit. That means I'll likely be using a 2w-20 setup. Anyone else have one of these yet? I can't start my build until after halloween as I am involved in a neighborhood project that's sure to scar a few children
Mark-
MYC is offline Find More Posts by MYC
Old Sep 29, 2009, 04:53 PM
Joined Jun 2008
freewing F-16 VTOL
I have one that I ordered from BP Hobbies, not sure what I am going to power it with, either sapac MB1 and sapac fan w/ 80amp speedo for 6s or E-flite fan w/ ultrafly 6s motor setup on 6s lipo with 60 amp pentium speedo, not sure allot of options., I want to start the build tonight.....
Old Oct 07, 2009, 04:23 PM
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
U sure bout the 6s setups chrisper? The foam itself sure seems light enough. I was thinking 4s so it can make better use of the TV. How small of a 6s pack can the MB1 get away with? I have 2 6s 3700's from Rhino but these things are almost a pound each if not a bit more even.
Old Oct 10, 2009, 10:16 AM
Joined Jun 2008
Setup
MYC I went with MB 1 motor sapac edf unit and 4S Hyperion and 4s outrage nrg packs, the battery bay in stock configuration will only hold 3s and 4s packs in the 2200 - 2500 mah size
Old Oct 10, 2009, 10:21 AM
Joined Jun 2008
Setup
MYC I have F15 from Freewing that I am going to put a 70 mm fan and 6s 2500 25c mega which is the same size and weight as a 4s 3700 mah outrage pack
Old Oct 10, 2009, 08:17 PM
guitarflyer
Joined Feb 2009
i just ordered the airframe only what would be a hot motor for this.HK has a combo but im curious what the FW fan is like hopefully i jut need a motor please help thanx ant
guitaramp68 is offline Find More Posts by guitaramp68
Old Oct 12, 2009, 10:32 AM
Joined Jun 2008
Fw F16 Vtol
The fan that comes with this kit is a Freewing 64 mm fan like the one that comes with the f-15, F-35, anf Freewing L-39 and Talon. THis unit will not work in the F-16, I am not sure why they even put it in the kit.
Old Oct 12, 2009, 10:35 AM
Joined Jun 2008
VTOL Radio Settings
I have a Futaba 10CHP radio, does anyone know how to center the VTOL in the radio either when vectoring or in the off position. Right now I have the off position centered so that I can fly it like a rgular plane, when I throw it into vector the nozzle is not centered and is positioned or facing downwards. Chrisper27p
Old Oct 20, 2009, 02:50 AM
Joined Jun 2008
vtol f16
Does anyone want to chime in on how to set the radio for vtol futaba 10chp?
Old Nov 10, 2009, 04:49 PM
awayne's Avatar
Pacifica,CA
Joined Oct 2006
Does anyone know if the wemo mini pro fan will fit?
awayne is offline Find More Posts by awayne
Old Nov 14, 2009, 08:07 AM
The Netherlands
Joined Sep 2009
any more updates on this beauty??..
On rc-castle it says it has a 70mm fan in it.
You can also buy the plane only version incl servo's and upgrade it with a cyclone power motor and besc.
Looks good and the price is good, it seems...
Not many video's on youtube.. and would like to know more about the setup you guys use..
crashburn2 is offline Find More Posts by crashburn2
Old Nov 14, 2009, 02:03 PM
awayne's Avatar
Pacifica,CA
Joined Oct 2006
Ductedfans.com says he has them in stock. Red white and blue one too.
"In stock @ Ductedfans.com Item #FWF16VT01 $129.99 Page not up yet but in stock. "
Fed Ex ground is aprox 35.00 to ship.
Old Nov 18, 2009, 07:27 AM
awayne's Avatar
Pacifica,CA
Joined Oct 2006
oops
Old Nov 27, 2009, 04:26 PM
awayne's Avatar
Pacifica,CA
Joined Oct 2006
Anybody have theirs up and flying? How well do they fly? What sort of set up are you useing? Anybody, anybody, .......beuller......beuller......beuler???
New Product New Panther 70 mm with retracts velyter Foamy EDFs 2 Sep 21, 2008 08:19 PM
Sold New in box Kyosho F-16 DF55 PIP $165.00 PatternFlyer Aircraft - Electric - Jets (FS/W) 2 Aug 29, 2008 08:40 AM
Discussion F-15 Vector Thrust gws-tommy GWS (Grand Wing Servo) 1 Oct 29, 2007 11:48 AM
Picture of New Elevator - UF's F-16 Electric Junkie Pusher Prop Jet Models 16 Aug 31, 2005 01:53 PM
New Flying Styro Arf F-16 @ EJF acarp997 Electric Ducted Fan Jet Talk 7 Dec 06, 2001 03:29 AM
