Old Jun 10, 2010, 10:18 AM
bluefisherking is offline
Find More Posts by bluefisherking
bluefisherking's Avatar
Bray, UK
Joined Aug 2009
Originally Posted by modfly View Post
Where is your COG? what is the AUW? What prop are you using? what is the static current draw @ WOT? Not surprising it won't roll with the 1s setup which is a floater setup not great for aerobatics really. Mine can Fly quite fast with the 1 cell but my motor is fresh and I'm using a 4.40 prop (estimated). My current draw is static 1 amp @ WOT so I can use a 120 mah lipo. the light weight also helps keep the damage down on pavement operations.
Hi Modfly/micman
- COG seems to be at the plastic wing reinforcing bars (the white plastic ones on the top, not the CF).
- AUW about 50g
- Using the GWS 5043 prop that was already on it from my Sukhoi
I don't know what the static current draw is, but it seems to be taking quite a lot - when the LVC kicked in I quickly tried that lipo in a stock Sukhoi, and it still flew with no LVC pulsing (to begin with). The again, that difference is voltage drop could just be the reduced current draw on the stock Sukhoi prop.
Thanks for confirming that it won't roll - I had assumed that the incredible rudder authority present in the 2S version that lets you snap roll in a blink would be present to a degree even in a 1S setup.
I also thought it would be more spirited, given how the Sukhoi can perform with the same setup... but I guess the Sukhoi is lighter, and I am beginning to realise that the degraded performance that I experienced in the Sukhoi was not just down to crumple zones and weight of tape/glue/repairs, but also a tired motor...
I am actually also about to retire my UM p51 - would anyone know if the motor from that be a drop fit into my Sukhoi guts already in this Nataku, or would I need to fit in the P51 gearbox, too?
bluefisherking is offline Find More Posts by bluefisherking
Old Jun 17, 2010, 04:05 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
United States, OH, Cleveland
Joined Dec 2006
Here is my latest mods for the Nataku. This plane uses a Vapor brick with a UM P-51 motor and gearbox with a 4.40 prop and 110 mah lipo. Flys very good with this configuration. You can see in the first pic that the plane can take either JST or PZ connector.
modfly is offline Find More Posts by modfly
Old Jun 28, 2010, 05:49 AM
Add1ct3dd is online now
Find More Posts by Add1ct3dd
Add1ct3dd's Avatar
United Kingdom, England, Worcester
Joined May 2010
hi,
i got this plane today, and the instructions are poor! how do i stick the bent metal pieces to the flaps (elev and rudd) ?
am i meant to be sticking them on? i've got 2 small pieces of fiberglass which are odd shapes and it doesn't mention them in the instructions?
Add1ct3dd is online now Find More Posts by Add1ct3dd
Old Jun 28, 2010, 06:19 AM
micman75 is offline
Find More Posts by micman75
Joined Aug 2009
the odd shaped fiberglass is are the elevator and rudder horns. cut a little slit in them and push them in, and glue them in place.
the metal rods join onto the carbon rods with ca glue, and secured by shrink wrap. the z bends go into the servo horn and the elevator/rudder horns.
micman75 is offline Find More Posts by micman75
Old Jun 28, 2010, 06:26 AM
Add1ct3dd's Avatar
Joined May 2010
ahh yea worked it out cheers saw some pics earlier on! what glue are you using to glue the fiberglass to the foam? i assume CA will melt it?
Old Jun 28, 2010, 07:44 AM
micman75 is offline
Joined Aug 2009
i use water based polyurethane... its called water based cabothane here in Aust
Old Jun 28, 2010, 08:26 AM
Bray, UK
Joined Aug 2009
I used foam-safe CA...
Old Sep 21, 2010, 01:42 AM
Telechat is online now
Find More Posts by Telechat
Telechat's Avatar
Paris, France
Joined Jan 2009
Great plane once modded with ailerons
I'm done with the fiddling of this plane. Last fly was great. The plane handles very good with ailerons. I'll post some pics of my plane later.
Basically, I had this plane laying around for a while and only recently bought adequate batteries from HK. I spent a lot of time building it with regard to its size. First experience with default rudder with very disappointing but once I added the ailerons, it became alive.
Telechat is online now Find More Posts by Telechat
Old Sep 21, 2010, 02:03 AM
micman75 is offline
Joined Aug 2009
agree... it's great with the ailerons. Still enjoy flying the Nataku everynow and then.
Old Sep 21, 2010, 12:36 PM
Telechat's Avatar
Paris, France
Joined Jan 2009
Also the one thing I'm concerned about is the flight time. I would expect a bit more than what I'm getting with my current 2S 138mAh cells from HK:
http://www.hobbycity.com/hobbycity/s...dProduct=10915
Any upgrade recommended over the ones I'm using?
Old Sep 22, 2010, 04:50 AM
Peter Mack is offline
Find More Posts by Peter Mack
Mack
Peter Mack's Avatar
Australia, VIC, Mentone
Joined Jun 2004
HK Cessna Bipe
I have had the HK Cessna for some time. It came with a 2S ESC and flew like a skyrocket - too much for a senior citizen like me! I purchased a 1S ESC and fitted a 300 mah cell, and although it slowed down a little, it was still very slick, so I put it aside.
I picked it up again recently and wondered what it would look like as a biplane - probably quite pretty and a big plus was that it should fly much slower. A top wing was made from 2mm Depron on the same planform as the original wing. The two wings were joined with wide interplane struts made from 3mm Depron reinforced with strips of 1/64 ply. The top wing sits on a pylon glued to the cabin and held by a rubber band. The wings can be removed together as a unit. The 300mah cell has to be placed near the nose to gain the correct CG near the LE of the lower wing. I think that the struts are a little too short as there is less dihedral in the upper wing. I've tried to compensate for this by cutting the airelon sections on both wings and bending the Depron up to create some washout.
The weather around Melbourne has been poor for model flying lately but a few tentative flights in the breeze have been promising though sometimes exciting! The Bicessna does fly, however, and does so in a more gentle manner than the original.
Peter Mack is offline Find More Posts by Peter Mack
Old Sep 22, 2010, 04:59 PM
Bray, UK
Joined Aug 2009
Nice work! - I look forward to hearing how it flies when you get a real chance to try it out..
Old Sep 22, 2010, 05:32 PM
Brent Slensker is offline
Find More Posts by Brent Slensker
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
Brilliant!!
I don't know what guts I'll put in mine, but I know for sure NOT what came in the box!
Brent Slensker is offline Find More Posts by Brent Slensker
Old Sep 22, 2010, 09:11 PM
pops57 is offline
Find More Posts by pops57
Austin TEXAS area
Joined Apr 2008
My first nataku was modded to resemble a FW190D. I just retired what was left of it after nearly 1 year of regular flying. I really enjoyed this airframe. I'm ordering another which I believe I'll mod to resemble an erocoupe. I'll post as I go once it is underway.pops57
pops57 is offline Find More Posts by pops57
Old Sep 22, 2010, 11:17 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Originally Posted by Brent Slensker View Post
Brilliant!!
LOL, you got that right! I used a Vapor rx in mine and flew it as a 3 channel. This airframe will fly slow if its light enough.
Hobby King Cessna DSM2 3 channel (2 min 25 sec)
Discussion micro cessna from park zone foam and tape Micro Ready-to-Fly 5 Apr 19, 2007 12:36 AM
Micro N9M from Simi Air revisited! Thomas B Foamies (Kits) 17 Feb 27, 2006 06:25 PM
Micro X, from Southamerica (Brasil) Tabushi Micro Cars 7 Dec 13, 2002 05:52 AM
New possible micro E-flight micro motors from Elect. Goldmine Looooeeee! Scratchbuilt Indoor and Micro Models 3 May 30, 2002 10:07 PM
Micro Retracts from MPI kelvin Scale Kit/Scratch Built 2 Feb 25, 2002 08:04 PM
