Go Back   RC Groups > Vendors > Hobby Lobby
Old Sep 28, 2009, 10:44 AM   #1
Site Sponsor
Flyboone's Avatar
A-10 Warthog ARF
A-10 Warthog ARF
40" wingspan, 36" long, 258 sq. in. wing area, 36 oz. flying weight. Includes two 75mm ducted fans with two outrunner brushless motors and two 18-amp controllers. Power is supplied by a 3-cell 2200 mAh Lipo battery that is easily accessed under the removable canopy. Construction is all pre-painted and decorated injection-molded foam. The wing is removable and reinforced with a carbon rod.
The two fan units are fairly large (75mm diameter) and produce strong thrust at a moderate speed and low amp draw. The wide stance of the tricycle landing gear gives the A-10 great ground handling for taxiing and take-off and superior control in landing. Assembly is quick; the wing halves need to be glued together, motor nacelles glued to the fuselage (fans and motors are pre-installed). Motors must be plugged into the speed controls and the direction of rotation checked, there is no soldering required.
All servos are pre-installed and all control surfaces are pre-hinged. Charge the 3-cell lithium battery with the included balance charger. Charge is done through the balance plug on the battery and each individual cell is charged independently to reach 4.2V.
Flying the A-10 is where the fun really starts. The steering is precise and not overly sensitive giving you great control on the take-off. Once in the air the climb is strong and the control is smooth and quick. Big loops, fast or slow rolls, inverted flight are all easily done. Flight times are from 6-8 minutes. Landings are best accomplished with a small amount of throttle for a smooth approach.
For more information and to watch the video click HERE
Use this thread to discuss any and all things related to A-10 Warthog ARF
Flyboone is offline Find More Posts by Flyboone   Reply With Quote
Old Oct 02, 2009, 10:22 PM   #2
servos
how many servos are needed? is it E,R,A and motor control? any idea when the A10 will be available?
tks larry
w0pya is offline Find More Posts by w0pya   Reply With Quote
Old Oct 05, 2009, 03:04 PM   #3
Site Sponsor
Flyboone's Avatar
Well, none. It comes with them. It has 4 servos. Two for Ailerons, one for elevator, and one for the nose wheel steering. We might have them by the end of the month.
Jason Cole
Hobby Lobby
Old Oct 05, 2009, 07:04 PM   #4
Trash Hauler emeritus
herk1's Avatar
Instead of offering up yet another ho-hum ~40-inch A-10, I think you folks should find out who makes that 50-inch A-10 that Banana Hobby is about to come out with, and see if you can't requisition a boatload of those airframes. There is a lot of pent-up demand for a larger foamy A-10. It will be a shame if a place like Banana is the only place that will be offering it.
herk1 is offline Find More Posts by herk1   Reply With Quote
Old Oct 06, 2009, 12:47 PM   #5
To me, every day is Saturday
fall666's Avatar
subscribing
fall666 is offline Find More Posts by fall666   Reply With Quote
Old Oct 28, 2009, 07:59 PM   #6
HB Addict's Avatar
Ordered new HL A-10
I ordered one of these A-10 Warthogs without any history based on hobby lobby's reputation and prior experience with them. Flying other single engine EDF models. Hopefully this is a well build bird. Looking forward to hobby lobby carrying individual parts vs. the airframe only for $150 so if/when I crash there are options. Will respond with feedback and start a post on foam edf if happy with this new model.
HB Addict is offline Find More Posts by HB Addict   Reply With Quote
Old Oct 28, 2009, 09:56 PM   #7
fall666's Avatar
Crash? I NEVER crash.
Pterodactyl crash (1 min 26 sec)
Mini Horten Crash (0 min 24 sec)
Soar Jet Crash (1 min 12 sec)
gb
Old Nov 07, 2009, 08:34 PM   #8
HB Addict's Avatar
Got Mine
Maidened my HL A-10 today. Will start thread in foam EDF to discuss.
Old Nov 07, 2009, 10:57 PM   #9
fall666's Avatar
HB Addict, might you provide a link?
Posts #23 and #25 are some of my A-10 observations: http://www.rcgroups.com/forums/showt...3#post13516593
gb
Old Nov 08, 2009, 01:01 PM   #10
HB Addict's Avatar
Thanks for the link fall666. I didn't find that one before when searching for HL A-10 information. Removing the nose gear on this model would require cutting so it would be permanent. Good idea regarding use of the servo rod securing bands, could save a lot of money if it prevents a crash. Also good input on wire routing. Will keep discussing on the foamy EDF thread to help others.
Old Nov 18, 2009, 08:52 PM   #11
Just to add to this thread...I think this is a GREAT EDF. It's slow....don't get me wrong...but it looks VERY nice.
I just wrecked mine REAL BAD (hit a street sign on approach) and I've already ordered a replacement airframe because I fell in love it.
Great Job HL!
djmoose is offline Find More Posts by djmoose   Reply With Quote
Unread Today, 03:08 AM   #12
HB Addict's Avatar
Know the feeling when they go down djmoose. I've hit stuff like street signs on approach but like you just recover and go on. I ordered an airframe today with HL crash sale as have lost orientation a couple of times. See foamy section for more info. on this RC feedback. Best of luck and skill
For Sale Flying Styro A-10 Warthog Twin Ducted Fan ARF Jet velyter Aircraft - Electric - Jets (FS/W) 0 May 08, 2008 05:50 PM
Help! a-10 warthog ARF wiring and electrics??? mutly777 Foamy EDFs 13 Mar 26, 2008 07:55 PM
Wanted Brushless A-10 Warthog RTF or ARF hamcigar Aircraft - Electric - Airplanes (FS/W) 1 Nov 08, 2007 05:47 PM
Discussion is there a gasser A-10 warthog kit or ARF???? parkzonekid Fuel Plane Talk 3 Sep 08, 2006 04:04 PM
A-10 Warthog ARF w/ Ducted Fans ch2s Parkflyers 56 Apr 25, 2003 07:07 AM
Bored? Want to fight?
Join the RCGroups clan!
