Old Oct 06, 2012, 03:46 PM
NiVeL44 is offline
Find More Posts by NiVeL44
Joined Mar 2007
Help needed!!
Hi,
I've been trying to get the airspeed V3 sensor to work with the Arduino. So far without success. I've changed it to run in third party mode.
Could someone post a working code for this.
Big thanks in advance
/Nivel
NiVeL44 is offline Find More Posts by NiVeL44
Old Oct 07, 2012, 02:17 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
here is my code for altimeter v4, but I'm using it with another library, not standard wire library
#define SENSOR_ADDRESS 0xEC
#include <Wire.h>
#include <I2cMaster.h>
TwiMaster ALTIMETER_SENSOR(true);// Defining sensor object
long altimeter_update(void){
static struct {
union {int16_t val; uint8_t raw[2]; } alt16; // 16-bit altitude from ALT-V4
} altv4;
long alt;
if(ALTIMETER_SENSOR.start(SENSOR_ADDRESS | I2C_WRITE))
delay(10);
ALTIMETER_SENSOR.write(0x07);
delay(10);
ALTIMETER_SENSOR.stop();
if(ALTIMETER_SENSOR.restart(SENSOR_ADDRESS | I2C_READ))
delay(10);
altv4.alt16.raw[0]=ALTIMETER_SENSOR.read(false);
delay(10);
altv4.alt16.raw[1]=ALTIMETER_SENSOR.read(true);
delay(10);
alt=altv4.alt16.val;
alt=alt-3000; //Substract 3000decimeters
alt=alt*10; //Convert decimeters to centimeters
return alt; //return altitude in centimeters
in main loop you just call altimeter_update() function. (altitude = altimeter_update()
schumixmd is offline Find More Posts by schumixmd
Old Oct 08, 2012, 01:30 PM
NiVeL44 is offline
Joined Mar 2007
Hi schumixmd and thank you
I downloaded the library, tried your code and got this:
Blink:3: error: 'TwiMaster' does not name a type
Blink.cpp: In function 'long int altimeter_update()':
Blink:15: error: 'ALTIMETER_SENSOR' was not declared in this scope
Blink:23: error: 'ALTIMETER_SENSOR' was not declared in this scope
Here is the code I tried:
#define SENSOR_ADDRESS 0xEA
#include <Wire.h>
#include <i2cmaster.h>
void setup()
static struct {
} altv4;
long alt;
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
void loop()
int altitude = altimeter_update();
Can you help me further?
How necessary is the additional library?
How does the code look like without it?
Yes, I'm a beginner in Arduino
Old Oct 09, 2012, 11:53 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
here's the library that works fine with arduino 1.0 or higher
I2cMaster
Old Oct 09, 2012, 03:26 PM
NiVeL44 is offline
Joined Mar 2007
Thank you!!
Now I'm getting something out from the airspeed sensor!
Here is the code I used:
#include <Wire.h>
TwiMaster AIRSPEED_SENSOR(true);
void setup()
Serial.begin(9600);
long airspeed_update(void)
static struct {
union {int16_t val; uint8_t raw[2]; } airspeed16;
} airspeedv3;
long airsp;
if(AIRSPEED_SENSOR.start(SENSOR_ADDRESS | I2C_WRITE))
delay(10);
AIRSPEED_SENSOR.write(0x07);
delay(10);
AIRSPEED_SENSOR.stop();
if(AIRSPEED_SENSOR.restart(SENSOR_ADDRESS | I2C_READ))
delay(10);
airspeedv3.airspeed16.raw[0]=AIRSPEED_SENSOR.read(false);
delay(10);
airspeedv3.airspeed16.raw[1]=AIRSPEED_SENSOR.read(true);
delay(10);
airsp=airspeedv3.airspeed16.val;
return airsp;
void loop()
int airspeed = airspeed_update();
Serial.println(airspeed);
delay(50);
Old Oct 20, 2012, 02:36 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I have a new Eagle Tree V4 Datalogger, OSD Pro, GPS and Baro Altimeter. I hooked it all up as per instructions. Everything worked except the Altimeter was kind of erratic. When I first booted it up it had a zero in its display. I read near zero altitude in feet when I took off but did not return to near zero and was several feet off even though I probably only went 25 feet high. At some point it started blinking a numerical three digit code that did not clear when I rebooted it. Then it changed to the following code: 5L2 and that has remained for several flights. I have unplugged the altimeter and plugged it in again and rebooted many times. The altimeter continues to behave erratically. I thought maybe it was due to air speed or propwash so I sheilded it in a little razor blade box. This did not help. Please tell me what could be the problem. Thanks.
Edit: humm, now it says 58L. What does this mean?
OK, I was reading the display upside down? It was 572 and 587! I assume that is some type of altitude reading from sea level. My actual altitude is more like 700 feet so I assume it must be corrected to standard barometric pressure or something.
Anyway, I decided that maybe propwash on the multirotor was causing the erratic behavior so I wrapped the sensor in foam. It is much better now, withing a couple feet takeoff and landing.
So what is the story on the numbers on the LCD?
u2builder is offline Find More Posts by u2builder
Old Oct 22, 2012, 03:07 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
Hi u2builder.
This is not the right thread for your question, it is for HOW TO USE altimeter with 3rd parties devices.
Anyway, your question is answered very well in the manual. What are the numbers and how it works.
The altimeter will never show your current altitude, but the maximum altitude reached in last flight, even you restart the sensor it will show max altitude reached from last flight, and will start reading new max altitude only if the altitude where altimeter was restarted and current altitude of altimeter is greater that 18feet.
The altimeter altitude reading can drift depending on many factors, so it is normal that you see 587 instead of 700 you claimed. (check some posts backs where I had the same question).
Old Dec 06, 2012, 08:33 AM
mirolek2 is offline
Find More Posts by mirolek2
Joined Dec 2012
hello
I'm newbie. I want to use these sensors (airspeed V3) in my application in third party mode, but I need connect more than one. Can anyone tell me if there is a possibility to change the address of SENSOR
mirolek2 is offline Find More Posts by mirolek2
Old Dec 10, 2012, 09:15 PM
jymster is offline
Find More Posts by jymster
Australia, NSW, Sydney
Joined Aug 2005
Hi guys, are there any plans to incorporate an input on the ET Guardian stabilizer for the ET Airspeed Sensor, so that the gain can be automatically controlled relative to airspeed? That is, the gain would be reduced for higher airspeeds?
James.
jymster is offline Find More Posts by jymster
Old Dec 12, 2012, 02:15 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
HI James,
That is on our list of potential additions to the Guardian! The Guardian has a connection already for that, so it should "just" be a firmware addition.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Dec 16, 2012, 11:37 PM
Teej is offline
Find More Posts by Teej
Joined Feb 2010
Originally Posted by billpa View Post
HI James,
Ah, the infamous "should" Seen far too many of those.
Good luck!
Teej is offline Find More Posts by Teej
Old Dec 17, 2012, 10:35 AM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
HI James,
Wooohooo!
Silverexpress is offline Find More Posts by Silverexpress
Old Feb 22, 2013, 12:55 AM
greghgradwell is offline
Find More Posts by greghgradwell
Joined Jan 2012
Has anyone got the altimeter or airspeed indicator to work with a Netduino?
UPDATE: It took a bit of trial and error, but I got them both to work with a Netduino 2 Plus. Let me know if you get stuck and I can send you my code.
greghgradwell is offline Find More Posts by greghgradwell
Old May 12, 2013, 10:47 AM
edcannady is offline
Find More Posts by edcannady
Joined Apr 2007
Would like to understand
Hi All!
I notice that when measuring airspeed that a pitot tube is used with both inlet pressure and static pressure. Why both? Would not just the air pressure in a tube be all you need? If you are using both inlet pressure and static pressure are you then having to add or subtract the two pressures?
Thanks in advance.
Ed
edcannady is offline Find More Posts by edcannady
Old May 12, 2013, 05:55 PM
schumixmd's Avatar
Moldova
Joined Jun 2010
for airspeed sensor you don't need do any math as eagletree is providing speed directly. am I wrong?!
Any airspeed indicator need Static and dynamic pressure to measure fluid flow velocity.
In conventional aircraft they both are needed because pressure inside cockpit is different from outside.
in our applications, static pressure is not so critical in my opinion, because our planes are not hermetically closed. The tube can be mounted just for dynamical pressure, but the static port should not be put into airflow directly.
Wanted WTB Eagletree Altitude and Airspeed micro sensors hcopter Aircraft - General - Miscellaneous (FS/W) 0 Oct 20, 2007 12:02 PM
Discussion NOW SHIPPING: Airspeed, Altitude and lots more new sensors for the MicroPower billpa Eagle Tree Systems 41 Jul 31, 2007 02:02 PM
Discussion Eagle Tree announces Airspeed, Altitude and lots more new sensors for the MicroPower billpa Batteries and Chargers 14 May 28, 2007 07:28 PM
Discussion Eagle Tree announces Airspeed, Altitude and lots more new sensors for the MicroPower billpa Product Announcements 4 May 27, 2007 09:56 PM
Alert Caution - Web Page with your info not secure RCTyp HobbyKing 5 Mar 22, 2007 03:25 PM
