Old Sep 27, 2009, 07:58 PM
WessCo is offline
Find More Posts by WessCo
Summerville, GA...USA
Joined Apr 2006
ICE 100 Data Logger
How do you change the prop size, so it'll show the correct RPM's?
WessCo is offline Find More Posts by WessCo
Old Sep 27, 2009, 10:25 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Prop size has nothing to do with it.
You need to input the number of magnets in your motor. That is done with the Castle Link---the same thing you use to download or show the data.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Sep 28, 2009, 05:24 AM
dehicka is offline
Find More Posts by dehicka
Russia
Joined Nov 2007
You can do a little trick to see the rotor RPM insted of the motor RPM: input (number of poles)*(gear ratio) in the log viewer motor poles setting.
Only even number can be entered, so there will be a small error - 1-1.5%
dehicka is offline Find More Posts by dehicka
Old Sep 28, 2009, 04:15 PM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
In the next release you will be able to change the gear ratio to reflect prop rpm with gear boxes and rotor HS on helis. You can still run 1 to 1 for direct drive as well.
Clintstone is offline Find More Posts by Clintstone
Old Sep 28, 2009, 04:28 PM
WessCo is offline
Joined Apr 2006
still can't change the pole count.
Old Sep 28, 2009, 04:34 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Are you running Vista?
Old Sep 30, 2009, 08:47 PM
eMikey is offline
Find More Posts by eMikey
Joined Dec 2008
If you are, right click and run the castlelink as administrator.
eMikey is offline Find More Posts by eMikey
Old Sep 30, 2009, 09:29 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
I also had to go to the graph viewer under the properties and click run as admin. I love XP................I downgraded .
Old Oct 01, 2009, 07:12 AM
WessCo is offline
Joined Apr 2006
Got Vista and now I can change the pole count. Thanks!
Old Oct 01, 2009, 07:18 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Vista can be aa challenge, I am glad it is working for you now....
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I sure hope that the new Windows 7 is better than Vista
Have you guys at CC done any Windows 7 testing yet?
RC Man is offline Find More Posts by RC Man
Old Oct 01, 2009, 02:26 PM
Tim B is online now
Find More Posts by Tim B
Pro Bro ozzy
Tim B's Avatar
United States, WY, Cheyenne
Joined Aug 2004
RC Man,
Quicker from the 3D plane section is a programer. He's been playing with "7" for awhile now. He says it's great.
Tim
Tim B is online now Find More Posts by Tim B
Old Oct 01, 2009, 02:28 PM
Tim B is online now
Pro Bro ozzy
Tim B's Avatar
Joined Aug 2004
Good to hear.
Old Oct 01, 2009, 05:45 PM
WessCo is offline
Joined Apr 2006
Now that I can use it, the 17" prop is down to about 4"....so I might need a new prop!
Discussion Phoenix ICE esc data logger village_idiot Xtreme Power Systems 4 Aug 05, 2009 09:05 AM
Sold Digital Power Recorder 100 - Data Logger - NEW! darkfa8 Aircraft - General - Radio Equipment (FS/W) 1 May 22, 2008 04:07 AM
Motocalc M-100 data crossup Parkflyers 1 Jun 06, 2002 07:22 PM
Motocalc M-100 data please? crossup Foamies (Kits) 0 Jun 06, 2002 12:54 PM
