Old Oct 28, 2009, 09:23 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Stick it to the man then!!!
Wingers unite!
B
fly_boy99 is offline Find More Posts by fly_boy99
Old Oct 29, 2009, 01:42 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
next time get 7 wings up at one time that will get there attention...
PaulVi is offline Find More Posts by PaulVi
Old Oct 29, 2009, 04:05 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
haha , cool thing is, the whole way thru in you hear our wings screaming in the background
matwelli is offline Find More Posts by matwelli
Old Oct 29, 2009, 09:10 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Matt, I notice you and Jacko running larger then average props. Just curious why you choose to go the lower kv bigger prop route as opposed to higher kv small props. What benefits do you see with these setups and what drawbacks? Is there much torque roll?
Atom1025 is offline Find More Posts by Atom1025
Old Oct 29, 2009, 10:47 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Mats 54 has a 9" prop, Seems to have naff all torque roll but is only a 4" pitch, The IYF30 has a 7x5 prop... Torque rolls like crazy with 0 airspeed, buts its fun! All the others are running 6x4's
jackosmeister is offline Find More Posts by jackosmeister
Old Oct 30, 2009, 12:51 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Hey Adam,
Main reason, its what I had to hand that would push the zephy (34 gram micro dan just looked a wee bit small !), plus 9 inches aint much for a big wing like the zephy (54 inches dont describe it, its a solid machine), haven noticed any issues, apart from WAY to much thrust, need more top end,
First motor lower kv , about 1184 on 10 by 5 was also sweet, at about 600 watts
From the VTO you can see not to much tourque issues :-)
Old Nov 06, 2009, 11:52 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Have some Turnigy 1250 kv motors http://www.hobbycity.com/hobbycity/s...idProduct=7072 turned up, will test and report back, should be a nice balance , and will be using them on the 80" Blunt as well
Old Nov 06, 2009, 03:21 PM
aero_k is offline
Find More Posts by aero_k
Canada, QC, Montreal
Joined Apr 2009
Looking forward to seeing how that motor performs, especially at only $17...
aero_k is offline Find More Posts by aero_k
Old Nov 06, 2009, 03:27 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
well when the last one handled 56 amps at 14 volts , im sure this one will do well, expecting closer to 40amps, which is where i want to be. jacko wont agree, he loves the VTO with the current motor
Old Nov 11, 2009, 07:59 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
The Bad news on the motors.
Havent tried the 1200 kv's yet, but both 1400kv's are smoke
And its not like an overheating issue, in each case its one pole has fried.
Not 100% sure it was the motors fault, I have had two of the HK60 esc's die as well, one was at part throttle on bench, lost sync with motor, locked up and fried 2-3 fets.
Next day that motor failed.
The build quality is not that great (to be expected for the price) as two of the mounting holes for the prop adaptor on one of them was stripped, and grub screws on both were loose.
Currently running a waypoint motor on 9 by 4.5 apc e prop, changing to a 9 by 6 shortly. Current ESC is a Scorpion 65 amp
Old Nov 11, 2009, 09:18 PM
aero_k is offline
Joined Apr 2009
Moral of the story: don't expect much from cheap equipment. Too bad it had to be at your expense...
Good to know though. Despite being on a tight budget, I'll have to avoid the cheap Hobby King stuff when carrying $3000 worth of equipment.
Old Nov 11, 2009, 09:37 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Well, ya got to try, sometimes you find some gems in amongst the not so sparkly, take the EMAX motors, $6 bucks each and they are real stars. So are the full sized digital servos from bluebird, and the Turnigy Lipos
Yea definately if its a wing built for a mission such as AP or FPV or whatever, you want to make sure to go a bit more spendy
Old Nov 22, 2011, 05:38 AM
sveininge is offline
Find More Posts by sveininge
sveininge's Avatar
Joined Sep 2007
did you ever find a emax motor that fits the zeph ?
sveininge is offline Find More Posts by sveininge
Old Nov 22, 2011, 03:08 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
i currently run this one http://www.hobbyking.com/hobbycity/s...idProduct=7072 on 4S and a 9 by 6 prop
Old Nov 23, 2011, 07:30 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
page no longer exists! What size and kv? Top speed? Watts? A recent video would be boss
brosius85 is offline Find More Posts by brosius85
Discussion Ritewing Zephyr FPV build thread Matt Gunn FPV Talk 436 Feb 01, 2011 11:01 AM
Ikarus Yak-54 with PPS Build rc-eflyer 3D Flying 94 Oct 06, 2005 12:33 PM
FW-190 54" Scratch Build scratchandbash Scale Kit/Scratch Built 3 May 21, 2005 06:07 AM
Isthmus Models Zephyr II build thread chlee Hand Launch 10 Jan 30, 2005 09:58 PM
Yak 54 beta plans/build DesertRC Foamies (Kits) 237 Jan 15, 2004 10:39 AM
