BM,
I've sent you a PM regarding your question. Paul. |
Latest blog entry: What a change of life. No more R/C.
BM,
Did that elusive 3A BAC finally arrive? Paul. |
Great stuff. You can run it from 1 pack, there's no issues there.
I've found some alternative 3A regulator units, though the specs are slightly different to the beloved one that I wanted to use. I'm going to see if I can make it work in a similar form-factor.
Had any chance to fire yours up? .... not literally
Curse that work which gets in the way of perfectly good hobby time
Steve,
The problem with taking the input from the ESC would be that the voltage (5V) would be too low, since the regulator needs at least 1.2V overhead. To do what you're thinking it might be easier to tap off the main pack directly, before the ESC. Paul. |
Steve,
Yes, you can use the balance plug to do that, no problems there normally since you can safely pull up to about 3A through those pins. |
Not sure as yet - busy respinning a design right now to suit new parts.
| Thread Tools | |
| A question for those who use high cell counts as opposed to higher current | Sal C | Power Systems | 14 | Feb 25, 2006 05:11 PM |
| Charge identical packs in parallel at higher current? | lynnpreston | Batteries and Chargers | 3 | Apr 14, 2004 07:56 AM |
| Question Proportionaly switching to a higher current? | infrared | Indoor and Micro Models | 7 | Mar 30, 2004 08:56 PM |
| Higher current output LiPoly chargers? | RD Blakeslee | Batteries and Chargers | 3 | Oct 28, 2002 03:20 PM |
| lightweight but higher current cells? | t-turley | Batteries and Chargers | 6 | Jul 26, 2002 04:40 AM |
