Old Dec 29, 2009, 06:50 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
good news on the testing mate....
BulletMaster is offline Find More Posts by BulletMaster
Old Dec 29, 2009, 07:02 AM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
BM,
I was wondering if I should seek out a larger heatsink or just leave this one "As is". Anything much larger and you'll not be able to gain access to the mount-holes and I don't suggest hot-gluing the PCB to anything because the board itself dissipates a moderate amount of heat (since the regulator is soldered to the large groundplane).
From my personal experience with inflight demands, even a normal 40 size trainer doesn't idle at more than a couple of hundred mA and only has short peaks which are handled well by the large output decoupling caps and the fast response of the regulator.
Basically the device is ready to sell at this point, I've even added a firmware update that allows you to use it as a LMA device if you leave the 'signal' pin connected, or just as a normal BAC if you leave the signal pin in, without having to actually change jumpers or anything like that.
Paul.
PLD is offline Find More Posts by PLD
Old Jan 01, 2010, 03:17 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Anyone in Australia willing to put one of these 3A BAC units through its paces?
I'm wanting someone who'll use it in a dual-lipo setup. Preferably in a reasonable sized plane (glider or glow).
Paul.
Old Jan 01, 2010, 07:37 AM
Chillaxin dude!
Joined Apr 2003
Paul,
I have a 60 size P51 Mustang that I have converted to electric. It has 4 x 821 digital servos + a retract servo. Happy to test in that unit? Will probably use dual 750 mAHr 2S lipo rx packs with XtremeLink 2.4 Radio system.
Old Jan 01, 2010, 09:56 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
BM,
Sounds like a fairly decent setup - PM me your address and I'll organise to send an eval unit to you.
Paul.
Old Jan 13, 2010, 06:58 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Okay, looks like we're about to hit retail-release.
I changed the heatsink bonding system again to an adhesive paste (looks like normal white thermal compound but it cures after about 12 hours). With the adhesive paste the heatsink gets hotter but that's a good thing since it's drawing more heat away from the regulator.
Before I was getting about 75'C on the heatsink with the 1.6A load but now I get 84'C but where's before the system would shut down at 82'C on the heatisnk, it keeps on going beyond 85'C on the heatsink.
The addition of airflow makes a significant difference to the temperature. With my workshop fan set at minimum (about 1m/s) the heatsink went from 84'C to 44'C, that's a HUGE difference with a moderately low airflow.
Paul.
Old Jan 13, 2010, 08:14 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I've put the BAC3A onto the NQRC site now.
http://www.nqrc.com/?vp=PLD-BAC3A
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Old Jan 14, 2010, 02:41 AM
Chillaxin dude!
Joined Apr 2003
looks good Paul....
Old Jan 14, 2010, 03:17 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Thanks. It's been a bit of a longer-than-normal prototyping run to get to this point, though the delays from Christmas etc couldn't be side-stepped
Now of course, here's the fun bit... will there even be an interested market, always the fun bit.
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Old May 13, 2010, 08:31 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I'm terminating this product - a recent round of price increases from suppliers has made it completely impractical for me to build this (the regulator chip alone is over $12).
Old May 13, 2010, 08:58 PM
Chillaxin dude!
Joined Apr 2003
so did you build any at all?
Old May 13, 2010, 09:11 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Yes, I did. . . . including the one I seem to never send you.
Old May 13, 2010, 09:48 PM
Chillaxin dude!
Joined Apr 2003
how many do you have Paul,
Might be able to do you a deal and take the lot off your hands?
A question for those who use high cell counts as opposed to higher current Sal C Power Systems 14 Feb 25, 2006 05:11 PM
Charge identical packs in parallel at higher current? lynnpreston Batteries and Chargers 3 Apr 14, 2004 07:56 AM
Question Proportionaly switching to a higher current? infrared Scratchbuilt Indoor and Micro Models 7 Mar 30, 2004 08:56 PM
Higher current output LiPoly chargers? RD Blakeslee Batteries and Chargers 3 Oct 28, 2002 03:20 PM
lightweight but higher current cells? t-turley Batteries and Chargers 6 Jul 26, 2002 04:40 AM
