I did a search, but can't find a discussion on the practical upper limit to airframe/wing sizes for KF airfoils. I'm building something like an Albacorde out of 1/2" purple Foamular and was thinking about a KFm4 for the wings. Length: one and a half meters. WS: one and a quarter meters. Kinda big.
Has anybody done any research along these lines? The search phunction here isn't great. |
She flew on a BP21 on 2s Lipo with a 10 x 4.7 SF prop on direct drive and it was a decent flyer on RET. Here's an old Vimeo video.
Dave, Didn't someone build an 8' span Zagnutz??? Steve. |
Windsor, Canada, near Detroit
Joined Jul 2007
where steps are still helping
guys: it is great that you are trying to find out the upper limits where steps are beneficial.
i have been exchanging comments with Dick about this issue. first of all, what do you expect from steps? what are you looking for? more stability? more cargo? faster? more flat glide? i think that the only way to see the difference between using steps-or not-is by building 2 identical models: 1 with, and another without. then you will see which 1 flies better (slower/faster-more stable-higher/lower rate of sink-more cargo lifting-whatever). build 2 of the same model of 6 foot; then 2 of 7 foot, and so on. until then, you will not see when the steps are no longer helping. just because that plane flies fine, or seems to be flying fine, does not prove that it is doing better with steps. it may be that it is just a good design. full scale aviation found out that they don't give them what they need, but where we have to stop? it's up to you, adventurous minds. |
I seem to remember some very big wings flying... Phil you are quite right, without direct build comparisons it is difficult to be certain that the steps improve the flight...however its the simplicity of a KF build that does it for me, every time... I can knock up a KF wing in a fraction of the time that a built up wing would take.. It will be as strong, if not stronger, and it will fly well. The only time now, I would build up a wing, is for a scale jobby.. Would a fancy airfoil fly significantly better?...or not...and even if it was better, would I take the trouble to build it up...I doubt it, I prefer the simple and easy build.. |
Joined Jul 2007
fancy airfoils
you know, Dave, i like all kinds of airplanes. i have discovered foam, and steps, and i realize they go hand-in-hand: are made for each other.
stick-and-tissue is still deep in my heart, and will keep designing and building planes for that. but with foam, building is way faster-and easier, so you are flying in no time, and enjoying it! also, as steps make an aircraft more stable (forget about efficiency-that's beyond the point), it is possible to fly aircraft that otherwise would be unthinkable. take your horten wing, for example. and birds. all kind of wings (flying wings). canards. you name it. for those reasons, with foam there is a better chance that someone will eventually find out how far (in size) an aircraft can go with steps. so, there is room for fancy airfoils, for those inclined to do so (am 1 of them), but we must admit that foam and steps, for all the advantages that they offer, will be used more and more as time goes by. and for the tests that i suggest, perhaps the easiest way could be to build 1 aircraft without the step and flight-test it (if the structure allows for doing it-maybe too weak), then add the step(s) and fly it again, so you don't have to build 2. |
Quote: "I can knock up a KF wing in a fraction of the time that a built up wing would take.. It will be as strong, if not stronger, and it will fly well."
That's my opinion as well !!! I don't see any size restriction on the KF airfoils... just the question of transporting LARGE models .... ![]() Somebody needs to make a KF Hang Glider... BIG!!!
There is a place in the world for KF airfoils but there is also a reason they aren't on commercial planes. Remind yourself of the variety of airfoils available.
http://www.ae.illinois.edu/m-selig/a..._database.html In the slow models that we often build they they fly well. I watch this thread because the variety fascinates me. I particularly like what Steve does because he makes up his own rules as he goes along and isn't afraid to try anything over and over till he gets it right. He is good for the hobby. For Steve and others like Steve the KF airfoil is a blessing. It gives options for design for the kitchen table builder. I was thinking that it might be interesting to cut a clark Y airfoil and run it though my horizontal slicer and separate the top from the bottom, fly with it flat then start adding the top back in pieces first with a notch then complete to see what the difference is but I'm starting to think it doesn't matter. The KF is what it is. Most people understand that and it does adapt well to some odd planes that would be very complex to cut with a conventional airfoil. Look at the Peregrine thread if you don't know what I am talking about. Look at the FFF Eagle linked in post #3. http://www.rcgroups.com/forums/showthread.php?t=950519 Lee |
I can post it, but I think I would like Dick's (Kline) approval first. |
| Thread Tools | |
| Idea 40" Depron Dynamite, Kline fogleman Depron build | dougmontgomery | Hand Launch | 626 | Aug 07, 2012 01:21 AM |
| Discussion ** Kline-Fogleman Airfoiled Flying Wing ** | Tony65x55 | Foamies (Scratchbuilt) | 3938 | Apr 08, 2012 06:07 PM |
| Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) | dougmontgomery | Foamies (Scratchbuilt) | 149 | Feb 16, 2011 12:12 AM |
| Video Kline Fogleman Airfoil on a flying wing | Tony65x55 | Electric Plane Talk | 3 | Jan 30, 2009 07:37 PM |
| Discussion Kline-Fogleman Airfoil on a flying wing | Tony65x55 | Modeling Science | 1 | Aug 20, 2006 11:14 AM |
