This thread is privately moderated by jackerbes, who may elect to delete unwanted replies.
Old Feb 05, 2013, 02:13 PM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
I've been flying for about a month, and I've gotten bored with it.
When you get bored, take all the bits out and build another plane. It's only foam! and there must be a million possible configurations, before you start on uncharted territory.
You're absolutely right about the CoG, Jack. - trim for straight and level, then land and look at the control panels... what could be simpler than that???
Of course, it's true that, before that knee trembling maiden flight, you're sure to be hoping that you will be able to trim for straight and level without going outside the range of what's possible. You need an approximation before you can start. That's when you need a trusted CoG calculator, like this one..
nickchud is offline Find More Posts by nickchud
Old Feb 05, 2013, 02:31 PM
pcaffeldt is offline
Find More Posts by pcaffeldt
Arizona Rim Country
Joined Nov 2001
Glue Idea
I got this link from another thread. It looks pretty good to me.
http://www.youtube.com/watch?feature...v=rnOegaOKu38#!
The stuff is called Glidden Gripper
pcaffeldt is offline Find More Posts by pcaffeldt
Old Feb 05, 2013, 05:26 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
That was the winner? Sort of odd that when you google it the only hits are for a acrylic paint primer.
The test was for gluing styrofoam, most of us are not using that. FFF is an extruded polystyrene foam. For that foam and for me, polyurethane glues that foam when water is present have the best penetration and give the best bond. Epoxy and hot glues have some uses with it but generally don't penetrate at all...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 05, 2013, 08:48 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
I need to look for it and get a price. For KFm wings with a lot of laminating a cheaper glue would be a better choice.
Raften is offline Find More Posts by Raften
Old Feb 06, 2013, 10:21 AM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
For starting C/G I use 25-30% depending on the type of plane and type of wing. However, there are wing shapes out there that are particularly forgiving of C/G; the trapezoid of the Smart Dart XS and its descendents is the best one available. Combine that with the stall-eliminating characteristics of the KFm2 and you've got a sure-fire winner of a trainer plane. I've built a number of trainer planes along those lines and they've all been successful.
A Useless Geek is offline Find More Posts by A Useless Geek
Old Feb 06, 2013, 10:37 AM
Drezed is offline
Find More Posts by Drezed
Drezed's Avatar
United States, VA, Spotsylvania
Joined Jun 2009
The foam in the video is also XPS. It looks like the Owens Corning stuff from Home Depot and such places.
I never would have thought of using a primer as an adhesive, though I've used WBPU and "Polycrylic" for doping. Looks like it would only be good for laminating, and wouldn't give the same stiffness as foaming polyurethane glues, though would sand easier. HobbyKing sells a foam glue(I think is PU based) that is a contact adhesive, that sticks like crazy!
Jeff
Drezed is offline Find More Posts by Drezed
Old Feb 06, 2013, 01:39 PM
Raften is offline
NorCal
Joined Dec 2009
I looked in two stores but haven't found G Grip yet.
Old Feb 06, 2013, 03:14 PM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
We are being protected by our government, R...
Not available in CA and OR...
U might try Reno.
rc
rusty case is offline Find More Posts by rusty case
Old Feb 06, 2013, 03:21 PM
Raften is offline
NorCal
Joined Dec 2009
Thanks rc, I feel so safe.
Old Feb 06, 2013, 03:32 PM
Drezed is offline
Drezed's Avatar
Joined Jun 2009
The Glidden website shows it available through Home Depot, at least for the couple of zip codes I tried.
Old Feb 06, 2013, 03:42 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Are you looking for G Grip? or Glidden Gripper. I checked 2 different Home Depot's inventory online in Northern Cali, one in Sacramento and the other in Yuba City, both of which showed available stock.
Here's what Yuba City shows:
giuseppi is offline Find More Posts by giuseppi
Old Feb 06, 2013, 04:03 PM
Raften is offline
NorCal
Joined Dec 2009
I was just saving a few key strokes. I did not check online, just in person. Didn't find anyone who had heard of it.
Old Feb 06, 2013, 06:21 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Do you mind saying where you checked specifically. Some people might get the idea that you can't get the stuff anywhere in the Golden State. Especially after Rust Case's comment about the govt., and also because of y'all's restrictions that don't exist in the rest of the world.
g
Old Feb 06, 2013, 06:43 PM
KlonWarz
Joined Dec 2012
I DID go to the home Depot website and checked on the exact name mentioned in the vid... Glidden Gripper... and put in my CA zippy code to check my local outlet...
Found the item and it said Not available in CA & OR...
and the only reason I mentioned that to raften is because he couldn't find it, and his address showed Norcal...
don't have much control over what people might think.
rc
Old Feb 06, 2013, 07:40 PM
Dickeroo is online now
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
The RCFoamFighters Bullet Plane with KFm2 hits 136.1 mph.
1600watt EPP Bullet Plane Speed Clock and Crash (6 min 28 sec)
Dickeroo is online now Find More Posts by Dickeroo
Idea 40" Depron Dynamite, Kline fogleman Depron build dougmontgomery Hand Launch 690 Jun 06, 2016 12:49 PM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 09:08 AM
Discussion ** Kline-Fogleman Airfoiled Flying Wing ** Tony65x55 Foamies (Scratchbuilt) 3945 Apr 08, 2014 10:40 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 07:37 PM
Discussion Kline-Fogleman Airfoil on a flying wing Tony65x55 Modeling Science 1 Aug 20, 2006 11:14 AM
