This thread is privately moderated by jackerbes, who may elect to delete unwanted replies.
Old Nov 06, 2012, 05:37 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
whats its glide like ..power off..mine with a forward COG just takes a nose dive.. only with the COG right back does it do an ok hands off flattish glide...
wonder why Ive got the odd results? all my thrust is at Zero.. power up and it doesn't climb, its just a flat and level acceleration
davereap is online now Find More Posts by davereap
Old Nov 06, 2012, 10:15 PM
byrocat is offline
Find More Posts by byrocat
byrocat's Avatar
Aurora, Ontario, Canada
Joined Mar 2002
I spotted the posts for the Regal Bipe.
The juices started to flow and I started thinking Hiperbipe. I've got the plans from FM which were for a bult up wing and fuselage. Thumbing my way through this thread and I'm now thinking that a Hiperbipe rendition is possible with a bit of bashing. Failing that, I'll build from the plans but do the wings using half-inch foam KFm wings.
http://images.rcuniverse.com/forum/u...26/Pi16175.jpg
byrocat is offline Find More Posts by byrocat
Old Nov 07, 2012, 04:34 AM
davereap's Avatar
Joined Feb 2005
That design will make for a good conversion to foam and KF..the originals wings are symetrical in section so a KFm4 wing is what will work best..
I tend to use more thinner foam layers for the wing, and build them up to get to the originals thickness..
Depending on what this original thickness was, you might get restricted to a KFm2 section by using the 1/2 inch foam as obviously in a KFm4 it will give you a 1.5" thick wing..
I did a quick sketchup measurement and the original has wings that are only 1" thick..
An alternative constuct that might be better is a KFm4 using 3x6mm layers with spars of 1x 1/8 balsa at the steps..that getting much closer to the originals wing thickness
A second alternative could use a KFm2 top step for the top wing and a KFm1 bottom step for the bottom wing (or even vice versa)
Old Nov 07, 2012, 03:51 PM
Thomas B. is offline
Find More Posts by Thomas B.
scratchbuilder
Thomas B.'s Avatar
Germany, Nordrhein-Westfalen, Cologne
Joined Mar 2012
Both Radius are quite neutral - especially the Kfm 4 wing has no trim changes between slow and fast flight, but I will check the glide again.
Thomas B. is offline Find More Posts by Thomas B.
Old Nov 08, 2012, 07:18 AM
Dickeroo is offline
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
Trond has done it again.
Here is a very stable platform, the KFm4 FPV, showing the beauty of Norway at sunset. A really spectacular video, in my opinion.
FPV49 v3 New Prop & Motor (7 min 13 sec)
Dickeroo is offline Find More Posts by Dickeroo
Old Nov 08, 2012, 08:51 AM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Stunning!
nickchud is offline Find More Posts by nickchud
Old Nov 09, 2012, 12:57 PM
scratchbuilder
Thomas B.'s Avatar
Joined Mar 2012
Great video!
Dave, I tried the glide of the radius 275: it remains level as long as the speed is high, when it slows down it goes into a shallow dive.
I moved then back the cog to 115 mm - it was more agile at slower speed, but I had to add a bit down trim for high speed and it was less exact on elevator; so I think the optimal cog depends on the desired flight style and flying speed.
Old Nov 09, 2012, 01:03 PM
nicokaufman is offline
Find More Posts by nicokaufman
Joined Dec 2009
Amazor!!!
nicokaufman is offline Find More Posts by nicokaufman
Old Nov 10, 2012, 05:57 AM
davereap's Avatar
Joined Feb 2005
weird cog results... I cant suss out whats going on... mine with your forward COG will go into a steep dive with power off, it needs the power up's prop wash to keep its nose up, or a lot more speed..and yet it flies lovely with the COG back on the step line at the root.. thats at 125mm back from its leading edge.
where did you put your steps exactly? the arcs on my two steps go exactly through that 125mm COG spot.. which is a 50% location on the main part of the wing, but ignoring the tail areas..might that be the reason?... and you didn't put any dimensions on your drawings..
At the end of the day it doesnt really matter as long as it flies how you like it to..but I am puzzled
Ive found another model that appeals... http://www.rcgroups.com/forums/showthread.php?t=1696964
Its been KF'd already, but with winter on its way I might just build one KFm4 style
Old Nov 10, 2012, 06:11 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
And Thomas is using a much heavier motor and lipo combination so, unless his lipo is well back, I'd expect him to be nose heavy compared with you.
Just got the horns & control rods to install and sort out lipo access as I'm using a underslung fuse like Thomas. Pictures to follow once she's ready to go. Hope to maiden tomorrow so will post vid if all goes according to plan
Andy
headlessagain is online now Find More Posts by headlessagain
Old Nov 10, 2012, 06:19 AM
davereap's Avatar
Joined Feb 2005
I think going heavier just makes for a faster flying model.. its COG should stay much the same, although some personal choice on where you put the COG to get it flying how you prefer will let it vary..at least a bit..
Old Nov 10, 2012, 07:30 AM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
You wil love the mako Dave! Its a great flyer.
rcrich is offline Find More Posts by rcrich
Old Nov 10, 2012, 09:11 AM
scratchbuilder
Thomas B.'s Avatar
Joined Mar 2012
The steps of the radius 275 are at 160mm, which is 50 % of chord incl. ailerons. On your radius 250 the step is at 50% of chord excl. ailerons. And your step line is more curved. Maybe here is a reason for different cog location.
I put some dimensions to my sketch:
Old Nov 10, 2012, 12:24 PM
Vance1 is offline
Find More Posts by Vance1
United States, FL, Leesburg
Joined Aug 2010
Second that love the Mako. Built mine with a KFM4.
Vance1 is offline Find More Posts by Vance1
Old Nov 10, 2012, 03:02 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Another Radius
Finished my KFm-4 Radius. 6mm depron with 3mm steps. Wingspan 495mm and total length 495mm including elevator. Motor is the MicroDan 2505 2535kv motor. I will maiden on 3S which should give me 19900rpm, 10.7V, 25A, 25oz thrust on a 6x4 prop. ESC is 40 amp mounted externally for better cooling. Will use a Turnigy nano-tech 1300mAh 3S 45~90C so shouldn't be pushed too much on the proposed set up. Ready to fly weight is 409 grams so I expect she will get a move on
Will maiden at 110mm back from le and see how she goes
Andy
Idea 40" Depron Dynamite, Kline fogleman Depron build dougmontgomery Hand Launch 656 Yesterday 05:35 PM
Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) dougmontgomery Foamies (Scratchbuilt) 151 Apr 21, 2014 10:08 AM
Discussion ** Kline-Fogleman Airfoiled Flying Wing ** Tony65x55 Foamies (Scratchbuilt) 3945 Apr 08, 2014 11:40 AM
Video Kline Fogleman Airfoil on a flying wing Tony65x55 Electric Plane Talk 3 Jan 30, 2009 08:37 PM
Discussion Kline-Fogleman Airfoil on a flying wing Tony65x55 Modeling Science 1 Aug 20, 2006 12:14 PM
