Trond's KFm4 takes to the skies.
After Trond got it dialed in, his KFm4 Flying Wing performed very well.
It tracked straight and true and seemed easy to handle. Great work.
Maidened the radius ...
video below.... 1st section flown at 75% aileron rates second section flown at 40%.. elevator at 80% OK Movement ...Ailerons +- 20mm right out at the pointy tips... Elevator +- 17mm again at the pointy tips COG for the maiden at 105 mm .. measured from the front at the root of the semi circular wing.. power a 1700kv blue wonder..3 cells and a 7x3.5 prop...not bad for whizz about but lacking a bit in static thrust COG definately nose heavy... in flight, as I reduced speed the initial elevator trim was not enough to keep the nose up, and with power off the nose just wanted to drop like mad... However the elevator is very powerfull and gave more than enough flair in the landing, although the landing was quite fast... I tried stalling at height but there were no problems.. I finally managed an unintentional stall at the end of the video, I think that was down to its nose heavy setup, and I hit the ground breaking a prop... It looks like the initial COG I predicted at 125mm obtained from the small scale version is going to be more on the spot.. next time I will be moving the COG till I get a better hands off glide and I am going to change to a 1300kv blue wonder and an 8x4 prop setup . I thought at the start I was on low aileron rates.. so I landed to dial it down , but then found I was flying on my high rates On the second section I was flying slower, you can see the nose dropping as the trim was less effective and hear me dialing in more up..
Radius success
There we are..
I'm extremely lucky to have friends and relations to visit in Laguna!
WS is 500mm and CoG is now at 100m behind the LE at root. LE of the wing to LE of the elevator panel is 500mm. Gyro is set at about 25% gain and I think it helps quite a bit in windier conditions. Tx is a Spektrum DX5, set to High rate. Span of the tailplain is 225mm and the fuse at the waist is 85mm. Fins are 55mm apart and 90mm high. She flies inverted nicely and she rolls slow or fast. If I fly slow and keep the nose up she doesn't stall, just cruises very slowly -- that could be thanks to the gyro, perhaps? Must build one with rudders when I get home. With my 2200 kv motor and 4.7 x4.7 prop, I only get about 4 and a half minutes flying time out of my 800MaHr 3S1P batteries -- should have brought some bigger ones.
| Thread Tools | |
| Idea 40" Depron Dynamite, Kline fogleman Depron build | dougmontgomery | Hand Launch | 626 | Aug 07, 2012 01:21 AM |
| Discussion ** Kline-Fogleman Airfoiled Flying Wing ** | Tony65x55 | Foamies (Scratchbuilt) | 3938 | Apr 08, 2012 06:07 PM |
| Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) | dougmontgomery | Foamies (Scratchbuilt) | 149 | Feb 16, 2011 12:12 AM |
| Video Kline Fogleman Airfoil on a flying wing | Tony65x55 | Electric Plane Talk | 3 | Jan 30, 2009 07:37 PM |
| Discussion Kline-Fogleman Airfoil on a flying wing | Tony65x55 | Modeling Science | 1 | Aug 20, 2006 11:14 AM |
