Never said it was...... but sweep gives effective dihedral... with degrees of sweep having a similar effect to some degree of dihedral
There is a more in depth analysis here http://www.b2streamlines.com/EffectiveDihedral.pdf which I must admit goes over my head a fair ways... Whatever... with a swept wing the rudder makes the model roll ...and with dihedral the rudder makes the model roll... with a circular or seriously curved back leading edge the rudder will also roll the model.. the curved leading edge is a basically a variable sweep back... edit....I do admit I am still puzzled as to why the circle or UFO shape behaves so much in the same fashion.. I tried a circular wing on a 3D body a while back, with rudder both above and below the wing in equal parts and the roll coupling was still there.. With the swept wing I understand the reasoning but I did think a circle might be different |
United Kingdom, Wales
Joined Jul 2009
Cheers jackerbes, exactly what I wanted to know. OD ,yep own design, but as its a delta, its much the same as any other delta. Can't help you on an od thread, may be one around. Its probably incorrect to say my od, as its copied from all I have seen and learn't on this wonderful forum. Into ic for 25years, now you cannot even cover a model for £20. A Depron foamy can be built, plus all the gear and flown for around £25, and free plans too. Cheers and thanks for the help. FB3 ps has a delta got a tip chord, and a root cord ? Told you I was a newbie ha ha.
USA, ME, Ellsworth
Joined May 2008
Enter the sweep as the distance from the nose to trailing edge. http://fwcg.3dzone.dk/ When you get the numbers in right it will look like your delta. For a Delta I would consider 50% of the chord to be 50% of the nose to trailing edge distance. The CG location it gives you might or might not be right but if you don't have one it will be better than nothing. Build a KF flying wing if you can, they are simply lovely flyers and very easy to fly too. Jack |
Radius or Semi Speed 500
With special thanks to Thomas and Dave Reap
On holiday in California, I didn't want to go too far afield looking for materials so I bought balsa, skewers, paper clips from the hardware store here. I brought my electronics in my luggage. Diameter of this version is 500mm, following the drawing of Semi Speed 500 by Dave Reap. As Thomas said, a too far back CoG makes it uncontrollable. Here's my video from day 2, with the CoG set at 95mm from the LE at the root. A great plane indeed, very promising, loads of fun and loads still to learn. So what went wrong?
Thanks for thr COG thomas... that scales up to 10cm for a 500mm span and is exactly where Ive put it.... now all I need is some better weather.
It looked to be fine.. then that great spin in... I normally have a job to get a spin with KFm sections.. the only one of mine that went like that was caused by vertical areas.. the relationship of front to rear areas....I had deepened the fuz on a prop jet and I think it was too deep and the fins didnt have a big enough advantage in area to keep it sorted... It would fly ok at any reasonable speed but spun out just like yours when I slowed it right down.. edit..the location of the fins also matters... by bringing them in more central to the body their effectivness has been reduced.. please show some still pictures, but for now increase the fin depth x2 and try again... an increase in fin area sorted my propjet. I can see I will have to watch my roll rates, as yours rolls a treat....on your loops, was that as tight as it would go? If thats a yes then the COG can be taken back a bit.. |
| Thread Tools | |
| Idea 40" Depron Dynamite, Kline fogleman Depron build | dougmontgomery | Hand Launch | 626 | Aug 07, 2012 01:21 AM |
| Discussion ** Kline-Fogleman Airfoiled Flying Wing ** | Tony65x55 | Foamies (Scratchbuilt) | 3938 | Apr 08, 2012 06:07 PM |
| Cool Here is my KFm-5 DLG GLider (Kline-Fogleman) | dougmontgomery | Foamies (Scratchbuilt) | 149 | Feb 16, 2011 12:12 AM |
| Video Kline Fogleman Airfoil on a flying wing | Tony65x55 | Electric Plane Talk | 3 | Jan 30, 2009 07:37 PM |
| Discussion Kline-Fogleman Airfoil on a flying wing | Tony65x55 | Modeling Science | 1 | Aug 20, 2006 11:14 AM |
